Technika lcd32-207
  • sordids999
    • May 2013
    • 2155
    Technika lcd32-207
    Hi guys
    got this tv it will be ok for about 40 minutes then will shut itself off
    upon testing the voltages all are low
    main cap is 335 volts
    also cant see any caps swollen
    24 volts are 22.5 volts
    5 volts are 3.7 volts
    and so on PSU is 17PW20.1
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Technika lcd32-207
    Originally posted by sordids999
    Hi guys
    Sounds like the pfc isnt working and is causing voltage drop, I have a tonne of vestel 17pw20 power boards if you would like me to send you one as its easier just to replace it.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      The reason why its shutting is because the motherboard or inverter is detecting voltage drop and is triggering the psu to shutdown, Im all but sure that the psu is at fault.
        If the cap voltage stays at 335V when the set is running the PFC circuit is bad, this will cause the set to fail to turn on sometimes or intermittently turn off while running. Replacing or repairing the PSU would fix this.
        • sordids999
          • May 2013
          • 2155
          thanks guys
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            thanks guys
            Your welcome, are you going to replace it or repair it ?
            • sordids999
              • May 2013
              • 2155
              I have a spare so ill replace thanks
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                IF you look at the underside of the PSU, There's three resistors in a diagonal 'row'
                These go dry-jointed making the sets intermittent shut-down.
                TELEFIX
                • sordids999
                  • May 2013
                  • 2155
                  thanks alastair ill look
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Did you get the set working in the end ?
                    • sordids999
                      • May 2013
                      • 2155
                      yes m8 sorry meant to update the thread i replaced the psu
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Ok is the set working fine and is the pfc on that psu running now ?
                        • MisterAIL
                          PS5 digital / No Power / No Beep / Good power supply
                          by MisterAIL
                          Brought a non functionnal PS5. Apparently only a bad PSU...
                          No beep, nothing.
                          After some tests i found this :
                          - PSU is fine (12 volts stable)
                          - 12 volts line is shorted
                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                          - By the way, nothing change. No signal, no power, no beep.
                          Mesuring all rails with my workbench psu (12 volts input)
                          - 0.00 amp drawing
                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                          03-12-2024, 03:24 PM
                        • Mcfeetroy
                          Fishing bite alarm drains battery
                          by Mcfeetroy
                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                          08-01-2025, 03:52 AM
                        • BTubbs200
                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                          by BTubbs200
                          Dell Latitude 5420 P137G
                          Board: LA-K491P REV A01
                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                          Board seems to have no shorts, all power rails are fine and show high resistance.
                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                          01-24-2025, 08:15 PM
                          MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                          by sam_sam_sam
                          I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                          I open it up to find non brands name capacitors in it
                          I am not sure how this switching power supply is set up
                          Could someone please explain how this power supply works
                          Here is the capacitor ESR results
                          (1) 47uf@50 volts 0.46
                          (2) 47uf@50 volts 0.45
                          New 47uf@50 volts 0.35
                          (1) 100uf@25 volts 0.34
                          (2) 100uf@25 volts 0.35
                          New 120uf@50 volts 0.08
                          (1) 220@25 volts 0.13...
                          10-21-2018, 10:02 AM
                        • Superbee_dad
                          Sharp 80” long short flash backlight error - Help
                          by Superbee_dad
                          Hello Sharp TV experts
                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                          01-24-2025, 11:51 PM
