Samsung UE46C7000 Single Verticle Line from Cold boot
  • DemonBG
    • Mar 2012
    • 143
    Hello All,
    Ok so i picked up this set yesterday - All of it seems to work other than one small issue; When the TV is cold i get a single vertical line of pixels about half way down the screen which isnt the correct colors.
    As soon as the set warms up it completely goes away...
    I tried to take a picture but it wasnt cold enough this morning for it to happen.
    May be difficult to say, but is this likely to be a panel issue?
    Regards,
    Demon
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Samsung UE46C7000 Single Verticle Line from Cold boot
    Is the screen cut in half or just a small line? I would remove the shield and push on the tabs.
    • DemonBG
      • Mar 2012
      • 143
      Just a single line of pixels which is a different color. again, it becomes good within 10 seconds or so...
      Is this likely to get worse over time do you think if left untreated or should i tear it down and put some thermal pads on the tab bonds?
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        It will go worse.
        Maybe just leave the tv off and remove the shield. So when its cold and you turn it on you can see if pressing the tabs will fix the problem?
          Yes I have seen this fault before. It will only get worse and other lines will appear shortly afterwards.
          • DemonBG
            • Mar 2012
            • 143
            Well thats dissapointing... Is this a Tab bond issue Tom? Is there anything i can do to get more life out of it or slow down the degredation?
            Thanks,
            Demon
              It is similar to a tab bond issue but it is a failure of the bonding between the IC and the flex that makes the "tab driver". I have tried before to fix it with hot air, but with no luck. It lasted about a 1/2 hour then failed again. (Though on my set the line was there from the start.)
              • DemonBG
                • Mar 2012
                • 143
                from what i hear, they usually run fairl warm... I might try adding some thermal pads onto the IC's to draw some heat out of them. It may at least slow down their degredation...
                Will let you know how it works out.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Tom, you should try a C clamp. Just kidding.
                  C series has panel issues, that is something new.
                    Every Samsung... no every LCD TV has panel issues.
                    Plasma too, but far rarer.
                    • DemonBG
                      • Mar 2012
                      • 143
                      I have had a few C series TV's - the 2D version (C6XXX) usually have good panels and poor main boards, the C7XXX and C8XXX are the 3D models which from what i gather have reliable main boards but unreliable panels...
                      Tom - Will putting Thermal pads between the IC and the frame help prolong the life of the panel? My theory is that it will help both draw the heat out of the IC and put a little pressure on it...
                      Regards,
                      Demon
                        Well, the failure has already occurred, so it might delay the onset of symptoms... but I don't expect it to fix it. It will only go bad later.
                        By the way my brother just sent me a picture of his Samsung UE46EH8000 (top-of-the-line Smart 46" FullHD 3D LED TV)…........ the panel has gone bad. Out of warranty by 18 months. I did tell him not to buy a Samsung, and then he goes out and buys another one to replace it. At least, I think I'll be able to get the old one, if only for the spare parts.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have seen this, with many people.
                          They have a broken TV of a certain brand and they buy the same brand again.
                          • Luke Anders
                            Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                            by Luke Anders
                            A few details about the laptop itself:
                            Name: Lenovo Legion 5
                            Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                            BIOS Version: GKCN60WW
                            EC Version: GKEC65WW
                            Serial Number: PF39AQ7Z
                            Board Model: NM-D562 Rev 3.0
                            RAM: 16GB Installed, DDR4 (brand new)
                            NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                            I bought this laptop recently from eBay as a faulty device....
                            10-12-2024, 05:13 AM
                          • sputnikoff
                            samsung un58tu7050 single vertical line.
                            by sputnikoff
                            Had a friend drop this tv off and initial issue was no power.I could see faint glow when powered up .Lamps all fired up fine.I removed flat lvds cable and reseated it,then tv screen came on.After i reassembled it now has single line pretty well dead center of screen.Is there ongoing display issues anyone is aware of.Any input welcome.
                            02-25-2023, 09:42 AM
                          • ictc
                            Lenovo IdeaPad S145 boot when cold than crash after feew minutes
                            by ictc
                            I received this laptop, which initially boots into Windows normally, but after a few minutes, the system freezes with no display and no response except for power button. When this happens, power consumption rises to about 1A (without the battery connected), and the CPU becomes noticeably hotter compared to when the machine is operating normally.
                            I have already tried removing the additional RAM module, which initially showed some promise, but the issue persisted after a reboot. I also attempted replacing the BIOS, but this did not resolve the problem.
                            When the system crashes,...
                            01-31-2025, 11:29 AM
                          • NolesFan
                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                            by NolesFan
                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                            10-24-2024, 06:36 PM
                          • praveenramavath
                            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                            by praveenramavath
                            Hello All,
                            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                            https://www.hifivision.com/threads/m...-screen.98243/
                            Troubleshooting Summary: Majority Internet Radio - Flash Chip
                            04-26-2025, 09:08 AM
