UMC 39/63G wont power on keep restarting
  • rastaman46
    • Jan 2014
    • 10
    • Lincs
    Hi im new here
    I need bit help to sort out whats wrong with my tv
    I got cheap tv that stop working 12 months old.
    All it does is keeps restarting on then instantly off.
    I checked power supply voltages fine matches prints on board 12v 5v 24v all fine.
    But tv wont turns on once back light kicks in its get instant cutoff and trys to turn again and it doease it constantly.
    Capacotors fine removed all checked all fine
    Can it be eeprom?
    Eeprom i gues is Windbound 25Q31FV
    Thanks for any help
    Kind regards
  • sordids999
    • May 2013
    • 2161
    Re: UMC 39/63G wont power on keep restarting
    i have a 32 UMC version and my problem is the same as yours waiting for a eeprom to arrive to see if it fixes this problem,also all my voltages are ok as well
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Possibly fractured solder at the power input jack. (if an LED-lit LCD)
      Reflow the power input jack and try again.....
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • sordids999
        • May 2013
        • 2161
        Changed the eeprom tv all working again
        • rastaman46
          • Jan 2014
          • 10
          • Lincs
          Can u post me source where to buy eeproom for this my model?
          Regards
          • flocko
            • Nov 2012
            • 1121
            Try Ohm Supplies you need to make sure main board and LCD panel numbers match the replacement EEPROM Flocko
            • rastaman46
              • Jan 2014
              • 10
              • Lincs
              Any way you can share bin file from eeprom?
              • rastaman46
                • Jan 2014
                • 10
                • Lincs
                I will try them thanks
                • rastaman46
                  • Jan 2014
                  • 10
                  • Lincs
                  I got one on order if its fix tv i will post bin file if any one needs it
                  • rastaman46
                    • Jan 2014
                    • 10
                    • Lincs
                    Can any one tell me how to reset Windbound 25Q31FV please
                    • rastaman46
                      • Jan 2014
                      • 10
                      • Lincs
                      Winbond 25Q32FV this is right name
                      • rastaman46
                        • Jan 2014
                        • 10
                        • Lincs
                        Up and running again thanks
                        • rastaman46
                          • Jan 2014
                          • 10
                          • Lincs
                          Bin attached for this model enjoy!!!
                          • comptek
                            • Aug 2013
                            • 606
                            if youre having problems with UMC 39/63g-gb-3b-ftcu-uk, this may help there are 2 files one is for if you tv has (PVR) I.E record tv..... and the other is no/without (PVR) no record
                            i found these through another site, i think the reason a few tvs got bricked as the poster on topic states copy both files to a usb drive which may have been the problem here http://www.techsupportforum.com/foru...ml#post6543417
                            files here>>>>https://www.dropbox.com/sh/r8ux0wnt0...Df-ACuIZa?dl=0
                            • danyby
                              • Apr 2020
                              • Romania
                              Hello guys, i need the files for usb if someone has it .. i have a tv that does the same and i can't find the files anywhere on the web.. can someone help me ?
                              The link on the dropbox is now inactive..
                              Thanks !
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                Thanks !
                                Try sending umc a message they are very helpful
                                http://www.umc-uk.co.uk/feedbackform.php
                                • danyby
                                  • Apr 2020
                                  • Romania
                                  I did it but it seems that they are saying the tv need a physical repair.. and it's not true.. i know that i can fix it with an usb and files for update
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Can you read the EEPROM and copy it to a new EEPROM. There are some very cheap read/writers out there on the market eg CH341. It can sometimes cure the problem if the TV's EEPROM is starting to fail.
                                    Shows video
                                    https://www.youtube.com/watch?v=NHoSB6m9iCM
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      whats the serial number from your tv? i will ask the person who sent me my last files from umc
                                      • comptek
                                        • Aug 2013
                                        • 606
                                        Thanks !
                                        Here you go Vince messaged me the dropbox isnt not mine but here they are
                                        NOTE: 1 is for if the tv has a PVR function and the other is not, also please make sure the correct model numbers before you proceed thanks
                                        regards
                                        Gary
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
