iSymphony LC32iH56 - Shuts Off after On Awhile
  • barryra
    • Aug 2013
    • 107
    I have this I symphony LCD where the owner says it shuts off he mentioned after 15 min to an hour. Caps look good. I do see a wire that brown where it may have gotten hot.
    Any ideas? Thanks
  • barryra
    • Aug 2013
    • 107
    Re: iSymphony LC32iH56 - Shuts Off after On Awhile
    bump... thanks
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Check the processors on the mainboard (the ones with heatsinks on top) and see if any get hot while the TV is on. After several years of use, they age and use more power. On some TVs bigger heatsinks on the processors may be necessary.
      A working TV? How boring!
      • huzo
        HP Omen shuts down when loading OS
        by huzo
        The model is 15ec-1061nm
        Board number is DAG3EDMB8D0​
        SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
        10-29-2024, 12:05 AM
      • brav1ez
        ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
        by brav1ez
        I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
        I’ve tried:
        - CMOS reset
        - Removing the SSD/HDD
        - Reseating RAM (removing each stick individually stops boot completely)
        - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
        With...
        09-07-2025, 10:47 AM
      • chaos-theory
        Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
        by chaos-theory
        I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
        Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
        03-14-2025, 05:37 PM
      • baglaivlad
        A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
        by baglaivlad
        Hello everybody!
        Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
        After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
        11-20-2024, 08:14 AM
      • samuelphirik
        Dell inspiron 15 7567 sudden shuts down
        by samuelphirik
        Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
        During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
        I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
        Now I've noticed that laptop...
        07-02-2023, 05:45 AM
