LG 50PX4D-EB power problem
  • Moggy
    • Oct 2014
    • 21
    I have a problem with this TV. When I plug in the mains, red light comes on, turns to orange, relay clicks TV back to red, and does nothing.
    If I remove the lead to the YSUS board, marked +VA, GND, +VS. Red light, then green light comes on. No picture, but responds to remote ect.
    Any advice please, thankyou. Stuart
  • Moggy
    • Oct 2014
    • 21
    Re: LG 50PX4D-EB power problem
    Sorry forgot to add pictures
    • Caleb
      Smokin IC's
      • Feb 2013
      • 645
      Training manual can be found here, You have to wait a minute for the "Get Manual" link to show up below the picture. but it sounds as if you have something shorted on the ysus or buffers and the protect circuit is shutting off the tv so it isnt damaged further
      Liberating magic smoke one part at a time
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Could be one of the Pass Fets but most likely one of the IPM's--prob the SUS IPM is s/c.....
        TELEFIX
        • Moggy
          • Oct 2014
          • 21
          Hya, thanks Eugene, much as I thought, I have downloaded the manual and will read through that. Thanks for the info.
          Alastair I have had one with a similar problem, another TV, removed the IPM, it measured 0 Ohm so replaced it with one from China, lasted about two weeks or less and pop again.
          What should the modules read across their pins? Assuming its removed from the board.
          • ERICSSON89
            • Oct 2014
            • 46
            • NIGERIA
            SUS IPM where is the voltage located, and what is it function? new to the forum
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Using the boards notifications, there shouldn't be any shorts between those marked, GND, SUS_Up, SUS_Dn, ERC_Up/ERC_Dn or Vs....
              New IPM possibly failed due to those cruddy caps around the DC/DC converter stage drying up, or maybe because it was an old/recycled one anyway. The Chinese sellers are quite good at making them Look new.....
              L.G. IPM's are not available new, they never were-- any that are sold these days are used ones....
              TELEFIX
              • Moggy
                • Oct 2014
                • 21
                OK, I will remove the board and check for shorts, if the IPM is at fault, best route for replacing \ repair please.
                • Moggy
                  • Oct 2014
                  • 21
                  Just a update. No shorts detected between gnd and VA+, +vs. Fuses are fine, inc pcb mount, advise please. Thanks Stuart
                  • Moggy
                    • Oct 2014
                    • 21
                    I have checked shorts on, GND, SUS_Up, SUS_Dn, ERC_Up/ERC_Dn or Vs, all OK there. Is it posible to be power supply rather than YSUS board?
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      The Ipm can fail open circuit as well, you can test the power supply voltages with the ysus harness unplugged. To load test it you can use a pair of 100 watt light bulbs wired in series across vs and ground. But the most likely failure is the ysus and buffers. Maybe Tom will be along soon to offer up some set specific advice.
                      • Moggy
                        • Oct 2014
                        • 21
                        Ok thanks, will try load test shortly.
                        • Moggy
                          • Oct 2014
                          • 21
                          Hya, thanks for the help so far, tried load testing the psu with light bulb, runs nice and bright no trouble. Have tried disconnecting buffer boards, both from YSUS board, still the same. Please can I have some pointers of what to check on YSUS board. Thankyou.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Don't forget there's 4 IPMs and from what I've read(Coppell TV blog) I think it's good practice to replace the lot. I think they mention it's not unusual to repair the Ysus and then have the Zsus fail shortly after.
                            Also I've read the module rev needs to match the partner IPM on the same board. I think there's A,B & C
                            The Zsus is powered from the Ysus, so removing power from the ysus also isolates the Z, could be either board causing trouble.
                            • Moggy
                              • Oct 2014
                              • 21
                              I have tried removing power from the ZSUS board to, as I did notice power comes from the YSUS board.
                              • Moggy
                                • Oct 2014
                                • 21
                                It seems I have been barking up the wrong tree, it is the ZSUS board shorted. VS and ground read short. I can remove the IPMs, then check for shorts.
                                Need advise, there is another board on Ebay for £30-00. Remove the IPMs to confirm its one or more shorting, replace the faulty one, or replace all four on Z and Y SUS boards.
                                • lapfix
                                  HP OMEN NO power no light
                                  by lapfix
                                  HP OMEN : DAG35DMBAD0
                                  NO power ,no short ,no corrusion
                                  Consumption : when charger plg in = 0.004 amp
                                  Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                  when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                  No light at power button led
                                  All coils resistances :
                                  Pl 2001 =3v measured with kohm.
                                  pl 2004 = 5v measured with kohm
                                  pl 6001 = 49.7ohm
                                  pl 4012 = vccsa = 24.4 ohm
                                  pl 3001 =...
                                  11-03-2025, 07:48 AM
                                • ipatch
                                  troubleshooting microsoft surface pro 4 no power no led charge light
                                  by ipatch
                                  hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                  10-05-2023, 11:59 AM
                                • russpall
                                  LG 39ln540v - red light flashes twice, no power to LED driver?
                                  by russpall
                                  Hi there,
                                  I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                  The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                  08-27-2024, 01:07 PM
                                • theone111
                                  by theone111
                                  3. Problem: TV shuts down
                                  07-22-2024, 10:36 AM
                                • Duranitron
                                  Asus x512dk rev 2.1 power on problem
                                  by Duranitron
                                  When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                  Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                  11-26-2024, 10:22 PM
