samsung 50 inch lines on screen
  • finntricky
    • Jan 2014
    • 449
    hi guys
    thinking of buying this tv, what do you think the problem is,
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: samsung 50 inch lines on screen
    Prob control-board....
    TELEFIX
      agreed.
      • finntricky
        • Jan 2014
        • 449
        these line come and go, just found out, but still waiting for model number,
        thank you
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Loose contact? When its cold these lines show and when it gets warm/hot they dissapear?
          • finntricky
            • Jan 2014
            • 449
            ok, got it, PS50B451B2W, i'll let you know when ive got it open and had a look
            • finntricky
              • Jan 2014
              • 449
              had the back off, checked and reseated the ribbon cables, just in case, but still the same.
              the t-con has a led flashing and is a stable flash,
              flash on, then off for a second, then flash on again, is this correct?
              ive ordered another t-con anyway, i should have it buy the end of the week
                This is OK.
                You could rule the T-con in or out by a quick test.
                On the 4 pin connector, jumper pins 3 & 4.
                Unplug LVDS, when you plug TV in it should jump straight to cycling test patterns.
                If test patterns are bad = definitely control board
                If they are not = more likely main board than control board
                • finntricky
                  • Jan 2014
                  • 449
                  yep, tryed that TOM, and still the same lines on screen while running test.
                  so defo t-con at fault
                  • finntricky
                    • Jan 2014
                    • 449
                    got the t-con today and fitted, think its dead, the led flashes the same but tv will not prime or show pic ?
                    is there somethink i have to do, to marry the t-con to the av board ?
                    im confused.
                    • Shinju
                      • Mar 2014
                      • 1239
                      double check your connections, sometimes a misaligned ribbon cable will cause issues!
                      • finntricky
                        • Jan 2014
                        • 449
                        ok, found out what the problem is, stupid mistake, all part and pcb numbers match, but turns out it;s for the 42" model, and it has a different chip.
                        theres a lesson to learn.
                        • sordids999
                          • May 2013
                          • 2161
                          whats the LJ41 LJ92 number i might have one laying around
                          • finntricky
                            • Jan 2014
                            • 449
                            lj41-05903a
                            • flocko
                              • Nov 2012
                              • 1121
                              The LJ41-xxxxxx number is the board pattern number, the part number is all ways the
                              LJ92-xxxxx number and the only one to go by to be sure of getting the right board for you set Flocko
                              • finntricky
                                • Jan 2014
                                • 449
                                UPDATE
                                replaced t-con.
                                tv now up and running, thanks guys,
                                now on to my next one LG 50PS3000
                                • jeyoung12
                                  Samsung QN50Q60t lines on screen
                                  by jeyoung12
                                  Hi all
                                  I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                  My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                  This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                  It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                  So....i don't know what end of the C ribbon to work with...
                                  02-26-2024, 10:38 AM
                                • Stanley1843
                                  by Stanley1843
                                  06-29-2024, 11:54 AM
                                • Chrissygizmo
                                  by Chrissygizmo
                                  02-10-2025, 12:33 AM
                                • Runlinc
                                  Samsung QE50Q60TAU - Horizontal screen lines
                                  by Runlinc
                                  Hi everyone, the tv was in a continuous reboot cycle. To get the best screen image i can I taped the VGH and VSS pins on the left side buffer board joining ribbon.
                                  I am left with a good image apart from the black horizontal lines that I cannot get rid of.
                                  I cannot find anything on the buffer boards that has shorted.
                                  Do you think there is anything i can do to eliminate the lines, or are they caused by an internal panel short and the image cannot be impoved.
                                  Many thanks for your assistance
                                  05-14-2024, 07:40 AM
                                • Chrissygizmo
                                  samsung galaxy ao2s very temperamental after screen replaced
                                  by Chrissygizmo
                                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                  Ive eventually managed to get it on and working but it's very temperamental...
                                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                  05-26-2024, 12:05 AM
