Panasonic TH-42PZ85E --> Completely dead!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TH-42PZ85E --> Completely dead!
    Anyone know the values of the caps on MC501 board?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      I attached a picture of the powersupply and the MC501
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        I bought some freeze and used it on the mc501. Nothing...
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Here a picture of the mc501 board wich is frozen. It was not possible to freeze just this part only....
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Measured:
            D551: 5v
            D606: 0.25v
            D702: 4.8/5v
            D604/603: 0.15v
            L501: 3v
            D505: 0.2v
            D506: 4.85v
            D504: 0v?
            Measuring D504 with diode testing says both sides peeping noise.
            Replace d504?
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #26
              Nobody?
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                if possile remove the diode from the board and retest some times diodes test sc when on a board you remove them and test again there fine.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  #28
                  This diode is fine. I also replaced the 22uf cap but the machine is completely dead....
                  You dont think its SS board?
                    Why would it be SS board?
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      #30
                      Well if 1 of the cables on SS board is not attached to the powersupply the machine wont do anything. ( my experience..i could be wrong).
                      So i thought that if ss board is bad...it wont send a signal to the powersupply? Because the powerbutton cable is also going to SS board.
                        It just acts as a way to route the signal - it doesn't do anything with that signal.
                        Reduces wiring clutter and harness costs.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #32
                          Ok that explains it. Haha.
                          So any thoughts on this tv?
                          Could you check the voltages with your "dead" machine?
                          Pin 9 is still 0v, i used freeze on every part on the PS, the area around the 5v stb diode was the first to be defrossed.
                            Ok, what do you want me to check? List the connector and pin numbers and I'll get you the measurements.
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              #34
                              I use standard 1uF 63V elccy-lytics for the MC boards.....
                              I believe the multi-layer ones go leaky depriving the chip of supply voltage causing the faults these caps are known for....
                              Haven't had any issues with those Ive done. They decouple the supply to the chip, so are not critical, anything from say, 0.1 to 10uF would do it .
                              TELEFIX
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                #35
                                A few posts above are the part numbers with the voltages.
                                I replaced capacitors D506/507/508. C551 and all small capacitors near p25. 470uf/100uf.
                                Machine shows no.sign of life..
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  #36
                                  Could it be that the mainboard is dead? Processor on mainboard is telling the powersupply to turn on right? ( to turn relais on ).
                                    No. The main board does not command the 5V standby to turn on (only AC-DET and main on/off switch do) ... if it did, how could it send the signal, with no power?
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      #38
                                      Ok , makes sense.
                                      So its the power supply , i replaced almost ALL capacitors except the big 450v and 3 small caps next to the small prints.
                                      Btw i also used a different on/off switch from a other panasonic , does not help.
                                        You need to look at the schematic to see what controls the 5V standby, check if that device is getting a signal to turn on, rather than shot-gun replacing parts which doesn't help anything.
                                        BTW, every time you take apart the power supply, you are screwing all the devices back down, and putting the plastic in right... otherwise you risk a very bad failure...
                                        • Moreno83
                                          • Jun 2014
                                          • 2008
                                          • The Netherlands
                                          #40
                                          I understand , ill try and look at the schematic.
                                          No , not all screws. Right now im just waiting for the relais to give a click. I understand what your saying and ofcourse i wont let the tv stay on without all the cooling placed correctly.
                                          The problem is that it doesnt do ANYTHING at all. So i thought i would use the shotgun tactic and replace some caps , you never know.
                                          The problem must be somewhere on the PB and im honest , i dont have the knowledge yet to get a schematic and just point out the problem
                                          Thanks for the advices your giving me Tom , much appreciated but im not that good with tv's yet as you are!
                                          • max-power
                                            Dell E6540 laptop completely dead after dssasembly
                                            by max-power
                                            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                            03-24-2025, 08:49 AM
                                          • wangbreeze
                                            T480s random shutoff and then completely dead
                                            by wangbreeze
                                            Hello Gurus,
                                            I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                                            I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                                            Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                                            charger gave - 20V - ok
                                            U101B
                                            02-03-2024, 04:57 PM
                                          • pavski
                                            Completely dead MSI z490 tomahawk
                                            by pavski
                                            Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                            I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                            t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                            Can you please let me know if this is indeed incorrect and what else should I look at next?
                                            Thanks!
                                            06-02-2024, 02:42 PM
                                            HP EliteBook x360 1030 G4 + Casio G-SHOCK Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 1030 G4 + Casio G-SHOCK Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Casio G-SHOCK boardview and 1030 G4 + Casio G-SHOCK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 11:39 AM
                                            HP ProBook 450 G6 + Casio G-SHOCK Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Casio G-SHOCK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Casio G-SHOCK boardview and 450 G6 + Casio G-SHOCK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 09:53 AM
