Philips/Magnavox lc370wx1 (sl) (04)
  • plbproductions
    • Oct 2014
    • 28
    Philips/Magnavox lc370wx1 (sl) (04) lady was dragging to the street, she said it never been worked on (lied). the power light would come on (green) then flash off every 15 seconds the lcd would flicker at that point. open it up took out the power supply low and behold someone replaced he 2200uf 45v cap badly i may add it was loose barley any soldier round it. quick fix right. soldier it put it back hook it up work for about 5 minutes then did the same thing. so i order all the caps for the board figuring the starter caps might be bad to. got them yesterday replaced all of the caps except for the 2.2uf 45v. plug it in same thing. green light power button 15 seconds flash off flicker then green light again. the reason i didn't replace the 2.2uf 45v is because i order it but it came as a 2.2uf 450v instead of 45v. well i didn't figure it would hurt it so i changed it to. i get the same thing except now i get no flicker from the lcd. it has to inverters a master and a slave the master has a blue light which still comes on when it goes through the 15 second flicker cycle. should i replace the caps on the invertor boards to?
    Re: Philips/Magnavox lc370wx1 (sl) (04)
    "Magnavox lc370wx1" are you sure that is the model number of the TV? That numbers are for the LCD Panel model number.
    • plbproductions
      • Oct 2014
      • 28
      thats what is under the cover the actual model number is 37mf33id/37 that i could be and L or a 1
        OK, upload good clear pictures of the back side of the TV so we can see all the boards and how they are all connected together.
        • plbproductions
          • Oct 2014
          • 28
          here you go
            OK, the picture of the power supply board, please.
            BTW, 45V cap rating does not sound right.
            We need to check the 24V out put and the dimming control line feeding the inverter board to see if they are steady.
            • plbproductions
              • Oct 2014
              • 28
              sorry your right the 2.2uf was 50v I couldn't find a fat stubby cap so i replaced it with the long one you see on the board 180uf 450v
                I forget to ask the pictures of the MASTER and the SLAVE Inverter boards so we can see the pictures of the caps.
                BTW:
                "the reason i didn't replace the 2.2uf 45v is because i order it but it came as a 2.2uf 450v instead of 45v. well i didn't figure it would hurt it so i changed it to. i get the same thing except now i get no flicker from the lcd."
                I am a little confused about the flicker, are you saying that the backlights are flickering and now it stops flickering or the LED indicator light on the front panel is flickering?
                • plbproductions
                  • Oct 2014
                  • 28
                  back light flickering less than a second be right back going to unscrew the invertor boards
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5084
                    • New Zealand
                    Just to clarify, the long skinny capacitor leaning over (that you replaced) is what value and voltage?
                    -David VanHorn
                    • plbproductions
                      • Oct 2014
                      • 28
                      first pic is of the master 2nd is the caps 3 is slave 4th is caps 5th is the logic board i believe and 6th the part number and of course 7th is the amp
                      • plbproductions
                        • Oct 2014
                        • 28
                        that is the 180uf 450v couldn't find a 30mmx36mm
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5084
                          • New Zealand
                          OK, thought for a moment maybe you had used a 2.2uF there which would definitely cause problems.
                          -David VanHorn
                          • plbproductions
                            • Oct 2014
                            • 28
                            These are the caps i replaced doc is the shipping list
                              I see 3 caps on each inverter board, you should replace them unless you have ESR meter to verify them.
                                BTW, do you get pictures on the screen?
                                And the main problem right now is the flickering on the screen but with good pictures, right?
                                • plbproductions
                                  • Oct 2014
                                  • 28
                                  No picture backlight does not even come on
                                  • plbproductions
                                    • Oct 2014
                                    • 28
                                    The blue light on the master inverter flash for a second to blue then goes out at the same time the power button light goes out
                                      OK, that is more than one problem, but I thought you do have backlights but flickering.
                                      I also need the P/N on the inverter board, the pictures of the boards are not clear for me to read numbers, it looks like 662-0283a??
                                      So to get the backlights, we need to find out if it is getting the control signals BL_ON & dim, and 24VDC or not.
                                      • plbproductions
                                        • Oct 2014
                                        • 28
                                        It's 6632L-0283A i did have backlight up until i changed that 2.2ul 450v cap i put the original back in but it still doesn't work
                                        • fixit007
                                          Samsung flicker - BN44-00932T board or else?
                                          by fixit007
                                          I picked up this TV that the prior owner said - just died.
                                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                          05-04-2024, 06:14 PM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • tonybig10
                                          Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                                          by tonybig10
                                          Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                                          the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                                          03-07-2025, 01:03 PM
                                        • howardc64
                                          UN65TU7000 strobing / flicker
                                          by howardc64
                                          Good picture but has ~200Hz+ faint flicker/strobing over entire screen. Also has a single green vertical line. Can mask out t-con signals (2pins) to stop flicker/strobing but 1/12 of screen will be all colorful vertical lines (single green vertical line is in this section)
                                          Since can mask t-con signal to disable part of the screen and stop flicker/strobing. Obviously not backlight.
                                          Panel has 4x driver boards each responsible for 1/4 of the screen. 3 tabs on each board. Each tab responsible for 1/12 of the screen. the 2 outer most tabs has additional horizontal gate control...
                                          03-26-2023, 04:37 PM
