Vizio 32" VO320E Intermittent Issues
  • bahowe1
    • Oct 2014
    • 21
    Hello, first, let me say thank you for all the knowledge that I have already gained from all of you. However, after all my searching, I still can't find a similar problem.
    I was given a Vizio 32" that did not work. I don't own a TV (yet) and have little (no) experience with LCD's but have messed with electronics for years. I can't figure out what's happening with this one.
    When I plug it in and turn it on, sometimes - usually the first time after I plug it in, the backlights will turn on and the logo will turn white. No picture, but I am not sure if there is supposed to be one. I can also turn it off, the backlights will go off and the logo will turn orange. If I try to turn it back on, the logo will turn white, but backlights will not come back on. Sometimes I can unplug it and plug it back in and turn it back on, and the backlights will come on again, sometimes they won't.
    I have done the following tests:
    Large capacitor ON/Off: 405/167. It appears to look good.
    Fuse 1 on Power board off - 0, on - 120VAC
    Fuse on Main Board F1 5.19 on and off
    Fuse 2 on Main Board F2 0-off, 12.21 on
    Regulators - Off (first three numbers)/ On (second three numbers). Also, I should note that I tested the regulators when the backlights were working... should I test them again when they are not working?:
    TU52
    EH13A
    928k80
    0
    0
    0
    .01
    .42
    .1
    U2
    L311
    G1117
    0
    0
    .47
    2.05
    3.3
    5.04
    U8
    L311
    G1117
    0
    0
    0
    .01
    1.25
    3.28
    U9
    L311
    G1117
    0
    0
    .47
    1.26
    2.51
    5.04
    U7
    1084
    0931gL
    0
    0
    .47
    2.07
    3.31
    5.04
    U4
    L311
    G1117
    2.06
    3.3
    5.19
    2.06
    3.31
    5.09
    U5
    L311
    G1117
    0
    0
    .46
    1.38
    2.63
    5.04
    U11
    7805CT
    RAG930G
    0
    0
    0
    12.18
    0
    5.02
    Board numbers are:
    Main: 0171-2271-2846
    Power: 0500-0412-0737
    At the power Supply, when it says 5V, I am getting 5.18 in all locations, at the 12V's I am getting 12.18. The on/off is showing 3.18.
    I am lost in how to move forward. Any help in pointing me to a correct direction/path would be much appreciated!
    Thanks!
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Vizio 32" VO320E Intermittent Issues
    Visio sets seem to have a bad rep as to Mainboard faults--whats causing the issue, I dont know.....
    Some say corrupted F/W others say component failure.....
    TELEFIX
    • bahowe1
      • Oct 2014
      • 21
      Images of the two boards have been added... hoping budm can provide me some help?
        U2 L311 G1117: OK, 1.25 Vref + 2.05 = 3.3
        2.05
        3.3
        5.04
        U8 L311 G1117: OK, 1.25
        .01
        1.25
        3.28
        U9 L311 G1117: OK, 1.25Vref +1.26 = 2.51
        1.26
        2.51
        5.04
        U7 1084 0931gL: Questionable, 1.25Vref +2.07 = 3.57 more than 3% off
        2.07
        3.31
        5.04
        U4 L311 G1117: OK, 1.25Vref +2.06 = 3.31
        2.06
        3.3
        5.19
        U???: OK, 1.25Vref +2.06 = 3.31
        2.06
        3.31
        5.09
        U5 L311 G1117:OK, 1.25Vref +1.38 = 2.63
        1.38
        2.63
        5.04
        U11 7805CT RAG930G: OK, it is 7805 5V Volt regulator
        12.18
        0
        5.02
        You should verify U7 again.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          You may have already done this, but you might want to disconnect the cable going to your screen from your t-con bd. and reconnect it making sure it is completely in the connector before you lock it into place. Sometimes a magnifying light is useful for this. Yes, the white logo means that the TV is on and orange is that it is off. If the TV is on and you are not getting a picture then I would suspect of video problem. You should get either the set up screen or a input number.
          • bahowe1
            • Oct 2014
            • 21
            Budm - thanks, I will re-check U7. One note that I made while checking this one in particular was that there was no 'leg' from the regulator that went to the board for the middle pin. Is there supposed to be? I understand these regulators are connected internally - the tab and the middle pin, so when I tested the board, it had the same reading as the edge of the regulator where the 'leg' would have protruded from the regulator. You can barely see it in the picture that I attached. Does this leg have to be there if it has the big tab?
            Keeney123 - thanks. I have not touched any of the connections, I will check that tonight. Thanks also for letting me know what I will see if it were working correctly - I had no idea what I should be seeing.
            Thank you guys, I am really enjoying learning and am hoping to replace components when we eventually find the problem.
            • bahowe1
              • Oct 2014
              • 21
              Budm - am I missing something? U7 was showing 2.07, so I add the 1.25 and arrive at 3.32, and the middle pin was showing 3.31. Your post calculated 3.57. Could you help me understand?
                Sorry, typo, should be 3.32 not 3.51.
                So I would check the DC Voltage on the T-CON board fuse next.
                • bahowe1
                  • Oct 2014
                  • 21
                  I will check the fuse on the T-CON board tonight. Did you happen to see my comment about the U7 regulator not having a 'leg' at the middle pin? When I checked the board at the solder area where the leg would have landed, it seemed to have the same voltage as the tab and also the part of the leg that was still on the regulator. You can see the missing leg in the picture (barely). It's attached above. Does this make a difference?
                    The Tab and the middle leg are tied together inside the IC.
                    • bahowe1
                      • Oct 2014
                      • 21
                      I think I checked the fuse on the T-CON board and have no power to the board. But, I wasn't sure it was the fuse because it wasn't labelled with a "F" but instead a "C". I took a picture. Can someone verify that the rectangular block right beneath the ribbon cable (sort of left of the middle of the ribbon) be the fuse?
                      If that was the fuse and I have no power, now what do I check?
                      I also disconnected the ribbon at both the t-con and the man board connection and reconnected to make sure it was correct - no change.
                      Also, does anyone know the part number for the fuse labelled F2 on the main board? The writing on it has like an 'L' with an 'F' inside it and a 5A.
                      Ben
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        That looks to me to be a capacitor. It is labeled a C? I am not real familiar with this TV. This is where BudM has knowledge. I take it that the t-con board is on the board running on top of the screen and not on a separate board ahead of this board?
                          OK, you have one of those part of the T-CON is on the main board and part of it integrated into the panel assembly.
                          https://www.badcaps.net/forum/attach...0&d=1414053405
                          Do you see the round copper pad test points with VDD and VCC labels next to them?
                          Check and see what DC Voltage you get on those two pads.
                            "Sometimes I can unplug it and plug it back in and turn it back on, and the backlights will come on again, sometimes they won't. " What worry me beside not having pictures ont he screen, it seems to me you also have other problem with main board functions as well.
                            You may want to contact shopjimmy to see what they think, I believe you will need new main board.
                            • bahowe1
                              • Oct 2014
                              • 21
                              VCC on the T-Conn is 0.12. VDD is 0. Both were zero when I would plug it in and the backlights would not come on (even though the Vizio symbol was white). I could only get VCC to read something if the backlights would come on. I can contact ShopJimmy on Monday (looks like hours are only Mon-Fri). Any other ideas? Did that voltage check on the contact pad give any ideas?
                              Thanks for all your help so far!
                              Ben
                                "Did that voltage check on the contact pad give any ideas?" Yes, the main board is not sending out the Voltage.
                                I would send an E-MAIL.
                                  OK, I just remember another VIZIO that I help another OP. there is a fuse for the T-CON section on the main board, fuse TF1, see if you get the Voltage on both end using chassis as the GND Ref.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Another thing you might what to try is once the backlights come up, take the connectors that are not one of the ribbon cable connectors and apply pressure first one side and then the other. Grab the insulated part of the connector making sure your fingers of hands do not touch any components and not a lot of pressure. See if you can get the backlights to go out.
                                    • bahowe1
                                      • Oct 2014
                                      • 21
                                      I checked voltage at TF1 when the backlights were on and have no voltage on either side of the fuse.
                                      I also checked all connectors as kenney123 suggested and could not get the backlights to go out.
                                      • ERICSSON89
                                        • Oct 2014
                                        • 46
                                        • NIGERIA
                                        then I think the main board might be the problem. can you replace the fuse with another to see if there's a change? and if not, suspect the mainboard is not getting a voltage.
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • servobillŕ
                                          vizio VO320E-M BIN FILE (lg)
                                          by servobillŕ
                                          HELLO FRENDS
                                          I AM LOOKING FOR THE FILE FOR THIS VIZIO TV 32" since it is corrupt can you help me I can't find it on the net
                                          thanks for your reply
                                          11-11-2022, 11:48 AM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • ChillingCicada
                                          Vizio VO42L Issues: Need Guidance
                                          by ChillingCicada
                                          We've had our Vizio VO42L since before 2010, and it's worked flawlessly this entire time. However, just recently it started emitting a high-pitched buzzing/humming sound. I followed the basic troubleshooting tips of just unplugging it for a moment, and even holding down the power button while doing so, all to no avail.
                                          Furthermore, after I attempted these basic steps and powered the TV back on it would always begin visually flickering while the sound stuttered. After a few moments of being turned on this would go away, but it still periodically comes back.
                                          I also...
                                          06-09-2021, 05:47 PM
