magnavox 32mf231d/37 no power backlights flicker
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i know this was a thread before but there was no fix
    i have this tv it does not power on...no power light...no picture..no sound....whats really odd is that when plugged in the backlight immedialtey turns on and flickers on and off and i hear a buzzing sound coming from power supply......i have replaced the 1200uf and 2200 uf caps....no change
    i do get 16v and 24v going to scaler board....when i check voltages going to inverter board the voltage fluctuates as the bl flicker ....low to high voltage....
    as the backlight flickers there is a blue led light on the inverter board that flickers also.....
    if i unplug the power cable to the inverter board i get no voltages coming from power supply.to the inverter cable...i only get voltages going to inverter when i have the cable actually plugged in to the inverter board.........
    im looking for any help.....i got help frokm this forum last month and ended up fixing the tv so i hope i can get some help again....i learn from you guys and i appreciate it
    i also checked 5 diodes located near the large transformer on the power supply using ohms and on 4 of them i get no reading one way and a reading the other way.........but on one i get a low reading both ways.....suspect?
    thank you
  • football0062
    • Dec 2011
    • 98
    Re: magnavox 32mf231d/37 no power backlights flicker
    do you have voltage at fuse 1U01 on the scaler board? next to the big coils for your audio circuit? if not flip the board over and check IC 7003 in the audio circuit. its an 8 pic surface mount with a center pad underneath.
    • shelby5041
      • Feb 2009
      • 1505
      ill check for voltage and get back in a few min
      • shelby5041
        • Feb 2009
        • 1505
        no voltage at all....0v
        the fuse is good
        • shelby5041
          • Feb 2009
          • 1505
          what am i checking on the ic7003?
          • football0062
            • Dec 2011
            • 98
            ya fuse should be fine. unplug and check resistance from fuse to ground
            • football0062
              • Dec 2011
              • 98
              checking for shorts or physical defect(blown open)
              • shelby5041
                • Feb 2009
                • 1505
                not sure how to check for shorts on the ic
                • football0062
                  • Dec 2011
                  • 98
                  whats your resistance from that fuse to ground? use tuner housing as a good ground
                  • shelby5041
                    • Feb 2009
                    • 1505
                    does it matter which end of fuse?? ill do both ends and give you readings
                    • football0062
                      • Dec 2011
                      • 98
                      not if the fuse is good it wont matter lol
                      • shelby5041
                        • Feb 2009
                        • 1505
                        if i touch black to top fuse and red to tuner ground i get 76 ohms
                        if i touch black to bottom fuse and red to tuner i get .3 ohms
                        • shelby5041
                          • Feb 2009
                          • 1505
                          oh let me use red on fuse one sec
                          • shelby5041
                            • Feb 2009
                            • 1505
                            sorry did it wrong first time..i get 20 ohms both ways....
                            • football0062
                              • Dec 2011
                              • 98
                              same thing that happen to mine. i have a new board on its way i will let u know how it works out, but my IC 7003 on the bottom was cooooked. black carbon all over. fuse is fine and resistance is around same as what your getting on your board. i dont have a schematic but i know most boards will shut the unit down if its not receiving the correct voltage to the audio circuit, which would be where that fuse is. im guessing your screen lights up for 2 sec max then shut back off?
                              • shelby5041
                                • Feb 2009
                                • 1505
                                do you suspect its a bad power supply or bad main board?
                                any ideas?
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  backlight flickers on and off....tv does not actually power on at all..i get no led power light at all....no picture ......just backlight flickering on and off
                                  i got a great price on a power supply board and main board tonite
                                  i got the power suppply for 22.95 shipped
                                  and i got the main board for only 34.00 shipped
                                  two diff ebayers.....i guess i cant go wrong....the one i dont need i just can resell and maybe even make a little profit since i got incredible price
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    ill let you know also on my results when i install the boards i ordered in a few days
                                    • football0062
                                      • Dec 2011
                                      • 98
                                      ive replaced with 4 different power supplies, still flickers on ever single one of them. finally got a 4am 24v LED driver for $12 and ran the inveters off that and no flicker but still shuts off. thats when i noticed the main board issue. will let u know when i receive the main board. also ive replaced the inverters on this set too. still flickers. this main board is the only thing left really. ive actually torn it down to the bulbs and they are fine as well.
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        the main board on this tv is a very common issue.....so im thinking the same but for such a cheap price i got both...that way i can be for sure....i got the tv for 10.00 so it would be worth fixing i think....even though its getting more and more not worth fixing any lcd tv anymore since a brand new 32 inch is 149.00 at walmart
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • fixit007
                                          Samsung flicker - BN44-00932T board or else?
                                          by fixit007
                                          I picked up this TV that the prior owner said - just died.
                                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                          05-04-2024, 06:14 PM
                                        • Storyteller12
                                          Vizio M801D-A3 backlights flicker
                                          by Storyteller12
                                          Need a little help here.
                                          the backlights flicker when watching tv. Everything else works as it should. Also it's not the picture that's flickering just the leds.
                                          I tested the leds and all light up and measure 77.5v volts. I took the tv apart to double check leds and they all work and light up perfectly.
                                          I believe it's the power board causing the issue however I cannot find a replacement board so I'm stuck to finding the bad component. The power board has a sizzling sound coming from the backlight transformer. I replaced that and problem persist....
                                          05-25-2021, 11:17 AM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • Jackching
                                          LG 50LF5800-UA Backlights flicker on and off
                                          by Jackching
                                          So i ran tests on the power supply and all of the voltages going to the main board are fine. I tested all of the capacitors on the psu with an esr reader and they all pass. All diodes pass also. But when a reading is done on the 4 pin white led connector on the top of the board, the voltages will flicker to 5Vdc for a fraction of a second and go out again. For that fraction, the LED backlights light up. Anyone have any clues to this situation?...
                                          02-04-2021, 04:24 PM
