Panasonic Plasma horizontal lines after repair attempts
  • dolt
    • Oct 2014
    • 6
    Greetings all,
    I've been trying to repair a Panasonic plasma TC-50PS14 for some time now. I originally got the dreaded "bang" and 10 blink flash code. Well I'm a glutton for punishment and have replaced many of the main boards in the back, including the SC board, SU, and SD (among others). I did notice that there was a burn mark on the old SC board, so replacing that was probably a good idea.
    I now can turn the TV on without any blink codes, but there are some horizontal lines through the picture. I'm really at a loss as to what to do next. I've triple checked that the ribbon cables are correctly seated into the SD and SU boards and have no idea what else to do.
    Please, someone help before I throw this thing out the window. Here's a crappy picture of what the TV screen now looks like:
    Re: Panasonic Plasma horizontal lines after repair attempts
    I all but guarantee you the ribbon cables are bad. Panasonic ribbon cables are a bastard to get right. This is exactly what many people's sets look like with loose/poorly seated ribbons.
    My favourite method: remove all the dodgy ones (power off while making any connector changes!) Install the cable making sure you do not bend or twist the cable and making sure it is perfectly aligned. You should hear or feel a faint click when it is in right. There are two positions, and one is the wrong one, the other gives the click.
    • dolt
      • Oct 2014
      • 6
      Tom,
      Thanks for the reply. I'll try again to reseat those ribbon cables. If it is indeed the ribbon cables not being seated correctly, do the locations of the vertical lines roughly coincide with the bastard ribbons?
      Also, if I somehow damaged one or more ribbons, am I correct to assume the TV is basically destroyed and should be parted out?
      • Shinju
        • Mar 2014
        • 1239
        I would also clean those ribbon cable ends too with some contact cleaner for electronics. Sometimes debris get in there and corrosion builds up and could use a good cleaning.
        • jbfr_54
          • Dec 2012
          • 52
          • France
          I recently had the same issue after resetting the Y buffer boards, it took me several tries for each connector to find the right insertion position after cleaning thouroughly both cable ends (gold plated parts) and connector pins.
          The cables must go far inside the connector but are reluctant to do so.
          Identify each connector involved by the position of black lines on the screen and work ONE connector at a time to progress step by step, make sure the cables are inserted perpendicularily with the connector, tolerate no shift on position.
          Once they are correctly set, the problem never appears agin as long as you do not remove those cables. Good luck.
          Jean
          • dolt
            • Oct 2014
            • 6
            Update:
            YEEESSSSSSSSSSSSS!!!!!
            I purchased some electronic contact cleaner and cleaned the ribbon ends. I inserted one ribbon per time per jbfr's suggestion and turned the TV on to try each one.
            Some of the ribbons took a few tries, but eventually all the horizontal lines went away. It is incredibly difficult to get those damn things seated correctly.
            Many, many thanks to the people that replied.
            • jbfr_54
              • Dec 2012
              • 52
              • France
              Glad you succeed ! Cheers. Jean
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Ihandyrepair
                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                by Ihandyrepair
                Hi guys
                I just started fixing 4k TV few months ago. so I am still learning a lot
                I got this tv from friend complaint is ghosting or horizontal lines on image.
                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                then it started to show the ghosting white image.
                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                it has 3 thin small boards at the bottom of the...
                12-05-2022, 04:18 PM
              • busted&disgusted
                Panasonic Plasma TC-P50ST30 Horizontal Black Lines
                by busted&disgusted
                I have a 2011 Panasonic Plasma HD 3D Viera model notorious for the SC board failure. As per a Google for the dreaded 14 blink code I discovered from info on this forum about isolating suspect boards by disconnecting the power cables and using an ohmmeter on the power terminals and this led me to the SC board. I had it repaired by a nearby technician who replaced the shorted transistors and before I got the board back I wondered if any of the buffer boards are damaged and a YouTube showed how to test these by using the ohmmeter and removing the copper colored ribbon cables to the display and use...
                10-05-2019, 09:51 AM
              • ggil44
                Sony XBR-65X750D Horizontal lines bottom of screen
                by ggil44
                Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                05-30-2023, 07:51 PM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
