Yeah, 1st post. Yeah, not a component fixing kinda guy, not scared to work a soldering iron, but ain't done it much, and ill equipped for such things. But I'm hoping you guys can point me in the right direction on this tv...
I've determined the backlight on my 46142 shuts off when it chooses, I've replaced the backlight inverter board/led driver and have the same issue.
TV powers on and will work for a varying amount of time, then the backlight goes out, picture and sound remain, tested by the flashlight test.
Since swapping the new inverter/driver out and putting the old one back in, the tv will run the backlight for a varying amount of time, about 1-1.5hrs then backlight shuts off. If I power off the tv and repower it, the backlight comes back on for anywhere from a few min to just over an hour. Then shutting it off and turning it on will only result in the backlight just flashing once while it's starting up.
Troubleshooting indicates it's the inverter/driver. The replacement was supposedly seller refurbished, so I gotta wonder if thats the issue, but the tv does the same thing with both boards so I also gotta wonder if something else is causing the backlight to kick off.
Just looking for ideas as to what to look at next or any insight. I'm working on returning the refurbed board, not sure if I should exchange for another one or go for the refund.
Many thanks.
Many thanks.
