MOV Replacement
  • Ed Hall
    • Sep 2014
    • 30
    MOV Replacement
    Time for me to query something:
    Apparently, this set caught a surge. The Fuse and MOV on the left valliantly gave their lives to save it. As can be seen, there is a breach around the perimeter of the MOV on the left, which allowed the magic smoke to exit forcefully, staining the MOV on the right. I think the right MOV is still OK, but will probably replace it as well, for good practice. The one on the left was connected hot to ground and the one on the right was connected neutral to ground.
    But, concerns arise:
    1. the MOVs have different numbers and I can't find the specs or a source for either
    2. are these not MOVs
    3. should I be concerned with obtaining matching parts
    4. I can see where there could be a different protection value for hot vs. neutral, but would it be that big a concern as to use precise components
    The top numbers on the MOVs are 10E241 and 10E271
    Thanks! (If this thread belongs elsewhere, please feel free to move it.)
    Re: MOV Replacement
    10E241 = 10mm Diameter, 150Vac RMS.
    10E271 = 10mm Diameter, 180Vac RMS.
    You can get them from digikey or mouser, just match dia and voltage.
    • retiredcaps
      • Apr 2010
      • 9271
      Re: MOV Replacement
      A good MOV should measure 0L ohms on your multimeter.
      I agree that you should replace it because they are relatively inexpensive.
      --- begin sig file ---
      --- end sig file ---
      • Ed Hall
        • Sep 2014
        • 30
        Re: MOV Replacement
        Thanks much.
        Does the diameter play a critical role?
          Re: MOV Replacement
          The Dia (bigger size) will handle more surge current.
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
          • nobbnobb1
            Upgrading Whole Home Surge Protector MOVs (Eaton CHSPT2SURGE)
            by nobbnobb1
            I have a whole home surge protector (Eaton CHSPT2SURGE). This is the lower end model as compared to the CHSPT2ULTRA. When I took it apart, I noticed it's basically the same PCB as the higher end model, just missing the extra MOVs for higher capacity. Coincidentally, I have a pack of brand new Bourns 20D241K MOVs laying around:
            https://www.digikey.ca/en/products/d...0D241K/2799098
            The only thing I noticed is that these Bourns MOVs are not thermally protected with a fuse. I'm wondering if it's safe to just simply install these extra MOVs for extra capacity,...
            06-04-2025, 08:40 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • nicktasios
            Macintosh Quadra 840AV PSU
            by nicktasios
            I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
            12-22-2024, 05:07 AM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
