Panasonic tx-p50x50b
  • sordids999
    • May 2013
    • 2161
    Right got this tv tonight was totally dead after a power cut so tested some voltages firstly disconnected the ysus board cable on the power supply then after i connected it back the tv came back to life ?
    so maybe a intermittent fault on the psu ?
    Re: Panasonic tx-p50x50b
    see here
    https://www.badcaps.net/forum/showthread.php?t=36055
    • sordids999
      • May 2013
      • 2161
      thanks tom ill order one now and update later
      • sordids999
        • May 2013
        • 2161
        ok replaced the psu tv now working but if i put it into standby then when i try and press the power on the remote nothing it just flashes once with a red led,but if i keep my finger on the remote the standby light goes to green with about 10-12 green flashes then turns on fine ?
        any ideas or is this normal for panasonic remotes to work ?
        • Hombre
          • Jul 2013
          • 231
          • Croatia
          That's normal, if you just press power button on remote it won't turn it on, you have to hold it for 2-3 seconds.
            Basically every Panasonic TV I have fixed does this. Some of the older ones also require it to turn off. I guess it's to reduce the chance of accidental button presses.
            • tw2005
              • Oct 2011
              • 6458
              Are you putting the TV into standy with remote then trying to turn it back on straight away?
              If so that's normal, give the A board a chance to reset.
              • sordids999
                • May 2013
                • 2161
                @tv2005 yes i was
                tv still ok not heard from my m8 as of yet
                thanks for your help guys
                • ijam
                  • Oct 2014
                  • 6
                  Sorry to hijack the thread, but can I ask where you ordered your replacement power supply from? Mine has failed and I'm not sure where to get one from.
                  Details here:
                  https://www.badcaps.net/forum/showthread.php?t=41113
                  Ian
                  • sordids999
                    • May 2013
                    • 2161
                    Hello
                    i got mine from Ebay or you could try Google or wait for more help supplying pictures of the back of the tv might help you more plus pictures of the boards
                    thanks
                    • ijam
                      • Oct 2014
                      • 6
                      Thanks mate
                        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                        by sam_sam_sam
                        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                        I am comparing them to a brand new one that I installed
                        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                        I going to let it run for several days before I remount back on the wall next to the...
                        09-05-2024, 06:48 PM
                      • BigPete
                        Panasonic Heatpump Dryer Repair
                        by BigPete
                        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                        Unfortunately the whole machine has to come apart to fix it.
                        I have...
                        11-01-2025, 06:40 PM
                        HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                        This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-12-2024, 02:30 PM
                        HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                        HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        09-06-2024, 08:10 PM
