Tips to making your TV last longer?
    Sadly, new TV's just aren't as reliable as old CRT's. I'll admit, my TV's are pretty cheap (because I figure I could just fix them when they break), my two main sets are an Emerson 39" LCD (Funai) and a Westinghouse with an AUO panel.
    The Emerson gets the most use, which is in my room which I use for things such as browsing the internet, and playing videos for background noise.
    So, what are the best things you can do to prolong the life of an LCD TV?
    As of right now, the Funai set has ~3,500 power on hours with an average running time of 7 hours per power cycle. The longest it's ever been on in one power cycle is 72 hours. Are power cycles what wears them down the most? Besides the summer, I like my room cold so the average ambient temperature is 18C. I turned the backlight to 65%, and brightness to 60% Does this sort of thing increase the life span? I've already replaced all the capacitors (They were all GP 85C caps)
    Attached is the power board in the Emerson before I recapped it. It's definitely poorly designed. The heatsinks could use an upgrade, would something this simple help it out significantly?
    Also, when there is a power rating (in W) on the back of the set such as 153W, is this a "typical" power consumption rating, or the absolute maximum such as full 1080P with full brightness? Thanks for any input
    Re: Tips to making your TV last longer?
    Certainly changing the 85C caps to quality 105C helps. Try not to mount the TV too close to the wall so some airflow can get in there.
    I personally don't use my TV for Internet browsing. It is all mainly done on a 19 inch or 22 inch monitor.
    The power board looks generic enough and possibly the easiest thing to repair? The t-con and main board will probably be the hardest to repair.
    --- begin sig file ---
    --- end sig file ---
      Yeah the TV seems to actually run pretty cool, and it's away from the wall by 3 feet. I haven't looked at the T-con, but the main board looks well built (At least much better than the power board anyways), and surprisingly uses nichicon polymers.
        Sorry to say that those brands mentioned are poor build and for that matter alone they won't last long and pic Q couldn't be any worse.
          You know, the picture quality really isn't that bad. Maybe it's just because this was my upgrade from a 24" tube, but still, 720p looks pretty good on it. Of course though, I miss the blacks from my tube.
            As for plasmas, is it the same or more important to limit how hot they run?
            I just got my LG 60PA6500-UA back from warranty work, I want it to last until the new tech TVs become affordable.
            I've seen areas in mine that looked like it ran hot, brown tints on boards. Also blackish areas on the adjacent back cover.
            What about spacing my back cover out about 1/4" or so for more airflow?
            Is it possible to over cool and cause problems?
            Thanks!
            From my favoritest movie ever!:
            Cledus Snow: Can I ask you a question?
            Bo Darville: Sure, ask me what?
            Cleedus: What the Hell do we want to go to Texas for and haul beer back here? What is that?
            Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money.
              You could install fans to suck air through the set.
              Plasma TV heat and power consumption is proportional to the displayed content, brighter = more heat and power.
                Tom,
                It is true then, cooler means more life?
                Also, can it be cooled too much and cause a problem?
                Thanks!
                  Yes, in general electronics last longer when cool.
                  That being said, I wouldn't fret. You should try and enjoy your TV. That's what plasmas are for - enjoying great picture quality.
                    Thanks again Tom!
                      Ventilation Ventilation, Ventilation!
                      Keep away from water and never I mean NEVER feed it after midnight!
                        Thanks!
                        It is always a good Idea to keep the Electronics running cool, heat causes electronic components to break down quicker. All electronic products have an optimal operating temperature and creating that air space for airflow is great! You obviously are not going to place your TV in frigid conditions, so you cannot over cool it. The only other thing that might crap out on you are the relays! Try not to turn your TV on/off so much. Ever wondered why TVs in stores last so long? They turn their TVs on once in the morning, then off at night and because stores are so large, there's plenty air flow, just be mindful of dust!^IV
                          I think that keeping it in the box from new should extend the life the longest
                            Thanks, Shinju & LGElectronics!
                            shovenose, you're funny!, but I'll chance running it, I plan on this tv and I staring at each other a lot this winter!
                              Originally posted by retiredcaps View Post
                              retiredcaps,
                              I tend to screw up at times, posting, could you explain posting inline and offsite?
                              Thanks!, I'm learning!
                                retiredcaps,
                                The reasons ...
                                https://www.badcaps.net/forum/showpo...5&postcount=12
                                https://www.badcaps.net/forum/showpo...95&postcount=6
                                  Hopefully I haven't done either, yet.
                                  I'll try reading up on pic attaching. I assume if I've done it wrong, someone would have told me by now. Thanks retiredcaps!
                                    I won't say it is wrong, but it is enough to make me ignore posts.
                                    Today, I only participate in certain sections and certain posts now. Posts without any homework or clearly focused pictures are ignored.
                                    When I was more actively helping, I would easily read over 100+ posts a day and maybe participate in over 65% of them. When working on multiple PCs, large inline images would slow me down a lot.
                                    Today, I might only respond to 1 or 2 posts (if that) here. I'm more active on eevblog.com now, but again only in certain subforums.
                                      The way I see it, if a person finds a group of people who are willing and kind enough to help, the very least a person needing the help should do is do what they ask!
                                      Thanks again!
