65pfl9708s no HDMI5 in menu
  • Roman Lut
    Roman
    • Jan 2025
    • 6
    Hello everyone!
    I recently had to replace the SSB in my Philips 65PFL9708S/12.
    Fortunately, I managed to find a board with the exact same part numbers:
    • 3104 303 54946 B
    • 3104 313 66186 B
    The TV works fine after the replacement, except for one issue: the “HDMI 5” input no longer appears in the menu.
    I could live without it, but on this model HDMI 5 is the only port capable of handling 4K.
    Here is what I’ve already checked:
    • Updated to the latest firmware (173.67)
    • Double-checked both rows of Option Codes — they match the original board:
      • 33347 04648 52943 00707
      • 63408 65202 24636 00000
    • Changed Display Type to 432 using the remote
    • Entered all 12NC codes in the SAM menu
    Has anyone experienced the same issue?
    The 4K upscaler (Novatek NT68361) is functioning, and Ambilight works too (it’s on the upscaler board), so HDMI5 should be operational.
    With the previous SSB, HDMI5 worked normally.
    The only difference I noticed is that new SSB was from 65pfl9708s/60(according to Type in SAM) but I have 65pfl9807s/12.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4546
    • Italy - Milan
    why "08" in place of a "07"? them are different series, what i remember is 08 was Full hd
    • Diah
      • Feb 2013
      • 6614
      both UHD 3D Passive series 9000, but where you got the 12NC data ? on sam there are option how many USB HDMI ports, did you check it USB 3 HDMI 5?
      • Roman Lut
        Roman
        • Jan 2025
        • 6
        Sorry for the confusion, there is a typo in the last sentence — it should be “I have 65PFL9708S/12.” So the only difference is /60 vs /12 only.
        • Roman Lut
          Roman
          • Jan 2025
          • 6
          I've got numbers from stickers:
          I do not see any option to change number of USB or HDMI ports in SAM.
          Also I guess 12NC numbers does not really mater, the features are higly likely controlled by Option Codes.​​​
          • Roman Lut
            Roman
            • Jan 2025
            • 6
            Got bootlog:
            5P04.26168 plfapp:441 vlib/diversity:0095 OPT_CODE: 33347 04648 52943 00707 63408 65202 24636 00000
            5P04.26196 plfapp:441 ty/plfdiv_mdiv:0772 Region : 0
            5P04.26650 plfapp:441 ty/plfdiv_mdiv:0773 NXP BoardVersion : 6
            5P04.26666 plfapp:441 ty/plfdiv_mdiv:0775 CabinetNumber : 2
            5P04.26685 plfapp:441 ty/plfdiv_mdiv:0776 FpgaPQPresent : FALSE
            5P04.26698 plfapp:441 ty/plfdiv_mdiv:0777 FpgaDimmingPresent : FALSE
            5P04.26711 plfapp:441 ty/plfdiv_mdiv:0784 Hdmi2Present : TRUE
            5P04.26724 plfapp:441 ty/plfdiv_mdiv:0785 Hdmi3Present : TRUE
            5P04.26737 plfapp:441 ty/plfdiv_mdiv:0786 Hdmi4Present : TRUE
            5P04.26754 plfapp:441 ty/plfdiv_mdiv:0787 Hdmi5Present : TRUE
            5P04.26767 plfapp:441 ty/plfdiv_mdiv:0790 S_VideoPresent : TRUE
            5P04.26779 plfapp:441 ty/plfdiv_mdiv:0791 DVBS2Supported : TRUE
            5P04.26792 plfapp:441 ty/plfdiv_mdiv:0792 DvbsDecoderType : SILAB2166
            5P04.26809 plfapp:441 ty/plfdiv_mdiv:0793 DVBT2Supported : TRUE
            5P04.26824 plfapp:441 ty/plfdiv_mdiv:0794 VgaPresent : FALSE
            5P04.26836 plfapp:441 ty/plfdiv_mdiv:0796 Av1SourceType : SCART
            5P04.26848 plfapp:441 ty/plfdiv_mdiv:0805 AmbientLightTopology : 3 Sided ( x 9, y 4 )
            5P04.26867 plfapp:441 ty/plfdiv_mdiv:0806 EthernetSupported : TRUE
            5P04.26880 plfapp:441 ty/plfdiv_mdiv:0807 WifiSupported : TRUE
            5P04.26892 plfapp:441 ty/plfdiv_mdiv:0808 LightGuideSupported : FALSE
            5P04.27058 plfapp:441 ty/plfdiv_mdiv:0809 SplashScreenEnabled : TRUE
            5P04.27072 plfapp:441 ty/plfdiv_mdiv:0810 SplashScreenSupported : TRUE
            5P04.27091 plfapp:441 ty/plfdiv_mdiv:0820 ThreeD : 3D_Passive
            5P04.27104 plfapp:441 ty/plfdiv_mdiv:0830 ThreeDGoggles : Expand
            5P04.27117 plfapp:441 ty/plfdiv_mdiv:0838 DigitalNaturalMotion : Full
            5P04.27129 plfapp:441 ty/plfdiv_mdiv:0839 AlShopMode : 0
            5P04.27143 plfapp:441 ty/plfdiv_mdiv:0840 AlProfile : 3
            5P04.27156 plfapp:441 ty/plfdiv_mdiv:0841 Overdrive3DLut : 0
            5P04.27168 plfapp:441 ty/plfdiv_mdiv:0842 IsfSupported : TRUE
            5P04.27181 plfapp:441 ty/plfdiv_mdiv:0843 LightSensorType : 3
            5P04.27194 plfapp:441 ty/plfdiv_mdiv:0849 LightSensorDevice : I2c
            5P04.27212 plfapp:441 ty/plfdiv_mdiv:0854 QfhdInputSupport : QFHD Hdmi and JPEG
            5P04.27225 plfapp:441 ty/plfdiv_mdiv:0860
            5P04.28141 plfapp:441 ty/plfdiv_mdiv:0867 SetType : 65PFL9708S/12
            5P04.28437 plfapp:441 ty/plfdiv_mdiv:0874 Service12NcSsb : 310432881031
            5P04.29212 plfapp:441 ty/plfdiv_mdiv:0881 ProductionCode : ZH1B1335002604
            5P04.96871 plfapp:441 es/hdmi4k/mdrv:0119 HDMI 4K idrvpow_Init
            5P05.38278 plfapp:441 es/hdmi4k/mdrv:0693 DeviceVersion == NT361_V2.26
            5P05.40217 plfapp:441 s/hdmi4k/mctrl:1152 DevicePowerOn() powN_OnTurnedOn
            • Roman Lut
              Roman
              • Jan 2025
              • 6
              Ok, so far I’ve “resolved” it in the following way:
              • got a high-quality HDMI cable
              • Enabled HDMI-CEC on the Android TV box
              Now I can turn on the TV using the Android TV Box remote, and the TV automatically switches to HDMI5. However, the HDMI5 option is still missing from the TV’s Source menu. If I switch to HDMI1, there's no way to return to HDMI5 except by powering the TV off and on again.
              The repair took quite a while, so I’m not 100% sure whether the previous SSB behaved exactly the same, but I believe the HDMI5 option was present in the menu before.
              Looks like I just have to live with it.
              Bootlog:
              5P05.25571 plfapp:442 es/hdmi4k/mdrv:0693 DeviceVersion == NT361_V2.26
              5P05.30248 plfapp:442 s/hdmi4k/mctrl:1524 m_signalPresence == 1
              5P05.30262 plfapp:442 s/hdmi4k/mctrl:1525 m_videoPresence == 1
              5P05.30272 plfapp:442 s/hdmi4k/mctrl:1526 m_fieldFrequency == 60
              5P05.30283 plfapp:442 s/hdmi4k/mctrl:1527 m_scanType == 1
              5P05.30293 plfapp:442 s/hdmi4k/mctrl:1528 m_numberOfLines == 1080
              5P05.30303 plfapp:442 s/hdmi4k/mctrl:1529 m_numberOfPixels == 1920
              5P05.30314 plfapp:442 s/hdmi4k/mctrl:1530 m_videoCoding == 11
              5P05.30326 plfapp:442 s/hdmi4k/mctrl:1531 m_imageFormat == 9
              5P05.30337 plfapp:442 s/hdmi4k/mctrl:1532 m_IsPCFormat == 0
              5P05.30684 plfapp:442 s/hdmi4k/mctrl:1543 Signal present, HDMI input connected
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4546
                • Italy - Milan
                Which repair you are talking of? The spare SSB has been repaired? Check the Silicon Image chip with loupe to see if a bad soldering exists, check if near the hdmi 5 connector there is a small IC where data lines passes through...
                • Diah
                  • Feb 2013
                  • 6614
                  yours Tv normal behavior, from user manual it listed 3 HDMI 1 ARC, the HDMI5 are optional only work with UHD resolution, and act as ARC to switch on, not listed at Source menu... because this PORT HDMI 5 have UHD ARC.. in other words you cant use it to stream HD or SD source. so every things are normal.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4546
                    • Italy - Milan
                    I suggest a service menu reset (shipping condition)
                    • Roman Lut
                      Roman
                      • Jan 2025
                      • 6
                      https://www.youtube.com/watch?v=Tr7pM4yr_X8
                      So I did remember correctly — HDMI 5 should be there. I still do not see it on my TV.
                        LCD LED TV Service Menu Codes
                        ALL LCD LED TV SERVICE MENU CODES
                        Service Menu Code with Board Name
                        China Universal Board / Jumper Board Service Menu Code
                        Changhong Ruba Service Menu Code
                        Ecostar LED TV Service Menu Code
                        Orient LED TV Service Menu Code
                        Haier LED TV Service Menu Code
                        TCL LED TV Service Menu Code
                        Samsung LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        Videocon LED TV Service Menu Code
                        Supra LED TV Service Menu Code
                        Toshiba LED TV Service Menu Code
                        Symphony LED TV Service Menu Code
                        Veste/ LED TV Service Menu Code...
                        10-31-2024, 03:58 AM
                      • Robby-Gr
                        TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                        by Robby-Gr
                        I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                        However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                        The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                        Additional issues:...
                        09-27-2025, 12:02 AM
                      • Retro140
                        Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                        by Retro140
                        So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                        To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                        06-18-2023, 06:13 PM
                      • Ierwin
                        Philips 58PUS7805 Menu working but no/weird picture from video sources
                        by Ierwin
                        I got a 58pus7805 that shows some weird behavior.
                        The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                        However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                        I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                        I managed to install the latest official firmware by holding the control button while plugging...
                        03-10-2024, 12:50 PM
                      • vf fa
                        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                        by vf fa
                        Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                        01-31-2024, 01:40 PM
