Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
  • jason123
    • Oct 2015
    • 1099
    Hi there,
    I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
    So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
    I see 2 posts that are relevant:
    https://www.badcaps.net/forum/troubl...j-oled-5-blink
    https://www.badcaps.net/forum/troubl...grade-possible
    So I disconnected the Main board from the circuit. Added a jumper between PWR_ON, TCON_12_ON and EVDD_ON and STBY
    Now all I get on the screen is backlight (screen lit up) but no colors on the screen.
    The EVDD on the TCON is 18.8 V
    The TCON_12 is 12.76 V
    Note that with TCON disconnected, the above voltages don't change much.
    I saw in other posts that EVDD should be higher? but I don't know maybe the 55" (Smaller) can live with lower voltage?
    Any suggestions on how to proceed?
    Thank you
  • Diah
    • Feb 2013
    • 6470
    Originally posted by jason123
    Hi there,
    Thank you
    OLED had no BL , put the the original T-CON and do the test again, post photo of your screen
    • jason123
      • Oct 2015
      • 1099
      This is the original TCON and Main board, I'm told. He bought them and when they didn't fix the TV he returned them.
      Yes, I'm aware there is no BL in the light-bulb sense, but I wasn't sure how to describe. I can provide photo shortly, but there is no hint of color or any activity other than you can tell it's on
      • jason123
        • Oct 2015
        • 1099
        Here is a photo of the TV with it on - just brighter screen, no color
        • lotas
          • Jan 2016
          • 4787
          • Russia
          You forgot to connect one LVDS cable. We tried replacing these two LVDS cables with others; they're a common problem with Sony.
          • jason123
            • Oct 2015
            • 1099
            Sorry, just so I understand... I need to connect the upper LVDS between the main board and the TCON or connect both LVDS cables? Even with the main board not powered?
            So to speed things up... I tried with one lvds cables connected at a time then with both and no change. Nothing is coming on the screen other than being lit up
            • Diah
              • Feb 2013
              • 6470
              connecting LVDS not required , because the MB already disconnected from PSU.
              yours T-CON didnt start to make the Pattern , you need OLED Tester.. which will feed 3.3V via the lower 51Pins LVDS an T-CON
              one things more... if you remove the jumpers. and connect MB to PSU. just unplug the lower 51Pin LVDS from MB Side, turn on... did yours set come on and the Optic Port lit red ?
              • Diah
                • Feb 2013
                • 6470
                if the test above you have Optic port lit red and remain the set OB.( screen stay black) do the second steps
                connect the LVDS 51 OIN back, disconnect only the EVDD socket ( black) from T-CON side.. turn on if the OPTIC lit red and set remain ON, then plug the TV from Wall, press power on set pull it down if you have Joystick,, keep pressing then plug the set back to wall... release the pressing only after the front LED change from White to green... leave the set in this state it will hard reset... could reboot 2-3 time... give time for it till you start to hear the Melody of first install and remain on for about 10 minute or more.... at this state while its on and you hear the Melody plug back the EVDD socket at its place the screen will come on... give attention on it or record it to sea if it clear or not
                • jason123
                  • Oct 2015
                  • 1099
                  Ok, when I remove all jumpers and disconnect the 51pin LVDS, the Optic port is lit red and remains red
                  I should buy a OLED tester? any recommendation? this TV is 2022 manufacture date. Any specific tester I need?
                  • jason123
                    • Oct 2015
                    • 1099
                    So with everything connected normally, except for EVDD (Black) connector disconnected from TCON, the TV starts (No White front LED) rather goes directly to 5 Red Blinks.
                    I proceeded to second step just to try, however the TV never goes into "Green" Color. I pressed the power button close to minutes, but no luck. No Melody either.
                    • Diah
                      • Feb 2013
                      • 6470
                      so yours MB OK, we have SOS signal coming from T-CON because of T-CON or Panel.. plesae upload close photo of yours T-CON
                      • jason123
                        • Oct 2015
                        • 1099
                        Here you go
                        • Diah
                          • Feb 2013
                          • 6470
                          ok thx, this version of T-CON are stable.. so the issue i guess 99.9% at the Panel EVSS,
                          disconnect all 4 Ribbon cable Just from Panel buffer boards side.. give attention on the first left you will have 2 caps title bigger than other , one of them could be have short or leak... also check all other three same size of the Caps.. if one shorted , you can compare over all 4 places
                          • jason123
                            • Oct 2015
                            • 1099
                            Ok... what's the best way to test these? I have and ESR meter and I have a capacitance meter. Test in-circuit or remove them test?
                            Would putting the jumpers back in and check for heat be best?
                            • Diah
                              • Feb 2013
                              • 6470
                              test and compare them with resistance low Ohm bad
                              • jason123
                                • Oct 2015
                                • 1099
                                Here are the measurements. I found that the resistance of these caps is polarized - as in, different reading if negative probe is lower pad and positive on upper pad of the caps. So on the photos the upper numbers are bottom Negative top positive, and lower numbers are bottom positive and top negative probe.
                                Anything that's labeled "open" is over 100 Mohm. Anything that has > or < sign, the reading is not stable. These are approximate numbers.
                                The lowest cluster I'm seeing is on the right hand side the first 4 caps. 370 Ohm one polarity, and 270 Ohm Positive Polarity.
                                Thoughts?
                                • Diah
                                  • Feb 2013
                                  • 6470
                                  yours Photo disconnect both ribbon from Panel side and do the measurements again
                                  • jason123
                                    • Oct 2015
                                    • 1099
                                    All 4 ribbons are disconnected. The ribbons are tucked under the board so they look like they're connected but they are not
                                    • Diah
                                      • Feb 2013
                                      • 6470
                                      start with these 4 caps one after one take out and check Ohm and Capacity, also after you have all 4 out check the track of them if remain same value you have before
                                      our talking on C662 663 & 398 399
                                      • jason123
                                        • Oct 2015
                                        • 1099
                                        Unfortunately, all these 4 caps are good. High impedance when removed and board still has low impedance.
                                        • matwan
                                          Sony XR-55X90J 5 blinks
                                          by matwan
                                          I have problem with SONY 55X90J. After several check status is as below;
                                          1. Running power board as stand alone:
                                          TCON_12V =~ 12.6V
                                          EVDD V On Max 24V= 19V.
                                          2.
                                          Running power board with TCON as stand alone:
                                          Effect as below, attched.
                                          3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                          "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                          Best regards....
                                          09-28-2025, 04:26 AM
                                        • Dogindelusion
                                          Sony XR-77A80K 5 Red Blinks Troubleshooting
                                          by Dogindelusion
                                          Hi everyone! I am a new member and am new to electronics repair. I have a background in electrical engineering, but little experience in electronics.
                                          I have a Sony XR-77A80K which will not turn on and has 5 blinking red lights in the stand-by light. I had previously done a forced factory reset, which removed the error code, and the TV regained functionality for a few weeks. I repeated the factory reset and again regained functionality. This happened a few times until I so I had to begin troubleshooting the error.
                                          Observations:
                                          1) I noticed I was not getting...
                                          08-09-2023, 09:44 PM
                                        • GoodCapDude
                                          Sony XBR-75X940E intermittent 6 blinks error code
                                          by GoodCapDude
                                          Hi everyone. First post on Badcaps!
                                          I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                          09-20-2025, 06:07 AM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                        • Glaval
                                          Sony OLED XBR-65A8G 4 flashes
                                          by Glaval
                                          Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                                          01-23-2025, 04:04 PM
