Vizio XVT473SV mainboard question (w/ pics)
  • Alderweis
    • Sep 2014
    • 18
    So during the first Patriot's game of the NFL season on sunday, about 5 minutes into the 2nd quarter, my TV lost its picture. Still saw back light, still had sound, but no picture. I powered it off, and waited a minute and powered it back on. Still no picture (no start logo, nothing) but definetely had back light, and sound.
    I was able to change inputs, channels, etc. Sound on different inputs, but no signal at all. I've since let it sit for 3-4 hours unplugged, plugged it in, and powered it on with same behavior (sound, black light, no picture).
    I took it apart, to see if there was anything amiss, and I found the attached pictures: a square black cap (?) with 220 marked on it, slightly off kilter.
    Anybody know what this is? Can I remove it and replace it?
  • Alderweis
    • Sep 2014
    • 18
    Re: Vizio XVT473SV mainboard question (w/ pics)
    OK, so its possible that the mainboard came like that from the factory? Not sure. Continuity tests fine on it.
    Meanwhile, I could not see the forest for the trees. I had previously inspected each cap and tested the continuity of the fuse on the tcon, but had missed that the entire damn thing was cooked!
    New (refurb) tcon is on the way, hopefully resolving my issue. (First thing I'll do is rip the heatsink off and clean/reapply thermal paste.)
    • ecking767
      • Oct 2009
      • 492
      Check the fuses on your T-CON board by making sure you have +12v on both ends of the fuse. or ohm the fuses out
      If you have a magnifying glass examine the contacts and or ohm out your flat ribbon cable going to and from the T-CON and main-board. Then re-seating the flat ribbon cable on both ends (main-board and T-CON). post your results
        "I took it apart, to see if there was anything amiss, and I found the attached pictures: a square black cap (?) with 220 marked on it, slightly off kilter.
        Anybody know what this is? Can I remove it and replace it?"
        They are inductors for the Class D amplifier output filters.
        • Alderweis
          • Sep 2014
          • 18
          Well, as that board is completely cooked, I'm going to be replacing the entire thing... so no need for further testing and thus no results
          • Alderweis
            • Sep 2014
            • 18
            OK. Should I worry about this (now that I know with certainty that it was the burned up tcon)? Is it possible it came from the factory cock-eyed? I can't really move it... so its not like its lose or anything.
            • ecking767
              • Oct 2009
              • 492
              which board? How did you conclude your board is bad?
              • Alderweis
                • Sep 2014
                • 18
                Check out the pictures I posted in the 2nd post. The tcon board is completely fried. I concluded this based on visual inspection of burned/melted wires.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4953
                  • New Zealand
                  I see no burnt wiring.
                  -David VanHorn
                  • Alderweis
                    • Sep 2014
                    • 18
                    Perhaps you are not expanding the pictures to the original size?
                    I'm including a detailed image.
                    Additionally, if you look at the image of the entire tcon I posted, you will see the white square outline around the heatsink/gpu area (could be misidentified as a shadow, but trust me.. it is absolutely not a shadow). On the right side of the image, the outline is white, turning to brown as you move left. Brown = burnt.
                    • ecking767
                      • Oct 2009
                      • 492
                      That very unusual, that can't be a wire going underneath the BGA chip, can you clean that area with alcohol?
                      Its maybe a challenge finding this board in stock and very expensive board when you do.
                      • Alderweis
                        • Sep 2014
                        • 18
                        The refurb replacement ($37 USD shipped) was shipped yesterday, should arrive the first of the week. I assure you it is a wire.
                        • Ijustwanttoseethepics
                          • Sep 2014
                          Can you please post up black and white pics as well? Or mess with the sepia or something...
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4953
                            • New Zealand
                            Ah, I see it now. When you said wiring I thought you meant the flat flex ribbon cables etc.
                            From the flux residue I suspect that BGA has been reworked. That wire you say is burnt looks like a jumper wire someone has installed to repair a trace\pad under the BGA. The brown around the chip is just used flux that was not cleaned off.
                            It may even have come like that from the factory, possibly a manufacturing defect that was repaired.
                            That chip *does* have a heatsink. That means it will get hot during normal operation. Some discolouration of circuit boards is to be expected around hot running parts. It may also just be more flux residue or discolouration from the BGA rework machine.
                            -David VanHorn
                            • Alderweis
                              • Sep 2014
                              • 18
                              Well dang, that is crazy. Yeah, I'm the original owner so any rework would have been done prior to boxing. Crazy.
                              I did some additional scrubbing of the chip itself and that wire. I scrubbed pretty hard with a q-tip and alcohol and broke the little "jumper" wire off. Additionally, the ceramic chip die is coated with a waxy residue that came off when I scratched at it with my fingernail. If this was all from a rework, they sure left a mess. There is a ton of residue coating both the chip and the surrounding area.
                              I've included a picture of the wire/jumper/whatever after I cleaned it (before it came off... the white stuff is my q-tip cotton getting shredded). Also a before/after of the die surface, when I scrubbed it with a q-tip and some alcohol.
                              • Alderweis
                                • Sep 2014
                                • 18
                                Additionally, I've been building PC's since mid-late 90's (The first CPU I cracked was my first 1ghz AMD T-bird, because of a badly installed heatsink ). My opinion of this is that the thermal paste used was of poor quality and very badly applied. They used too much, as is evidenced with the globs of it covering all sides of the chip on the die itself. This, coupled with the most likely below budget quality of the paste, over time caused the heating function of the heatsink and paste to degrade to the point of thermal failure.
                                • Alderweis
                                  • Sep 2014
                                  • 18
                                  OK, so the TCON got there yesterday and (aside from it being improperly shipped, in a too small box, with ZERO padding) it works!
                                  So thanks for all for reading, sorry about misdirection with that off-kilter inductor (which I can now confidently assume came like that from the factory).
                                  If you are like me and have no picture but DO have backlight and DO have sound and CAN switch inputs, there is a good chance it is your tcon. I got mine for $37 ebay refurb but it looks clean enough to be brand new.
                                  • Ierwin
                                    by Ierwin
                                    05-13-2025, 03:31 PM
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • Devonavar
                                    Vizio M43-C1 - How closely do I need to match the mainboard number?
                                    by Devonavar
                                    I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                    I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                    Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                    So, I've ruled out the PSU for now.
                                    The reboot loop...
                                    08-14-2022, 08:46 PM
                                  • maricm
                                    Vizio P65 with P55 mainboard
                                    by maricm
                                    IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
                                    Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
                                    And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
                                    04-23-2024, 08:25 AM
