Oscilloscope
  • tech2014
    • Aug 2014
    • 807
    Oscilloscope
    Just wondering what type of scope I need to fix consumer electronics. 50MHZ, 100MHZ, digital or analog.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Oscilloscope
    I have the Rigol DS1052E which I have hacked(EEV blog) and now it's a 100Mhz scope.
    • magneh
      • Apr 2014
      • 596
      • Portugal
      Re: Oscilloscope
      It's a good equipment for laptops, LCD's and other consumer electronics?
      Need to buy one and found this option interesting!
      Nice price and a 100Mhz hack ... seems good!
      Do your recommend it?
      • mattstolte
        • Dec 2013
        • 612
        • usa
        Re: Oscilloscope
        Can anyone tell me what these even are good for?
        • tibimakai
          • Jan 2012
          • 3680
          Re: Oscilloscope
          I'm a beginner myself, but with help from some forum members, I have used it a couple of times on TVs and amps.
          I have got mine for $315 shipped. They had a questionnaire at the check out and I have saved $15(if I remember well) answering some questions, but it's not available now.
          The only "bad" thing about it, is that the fan is a bit loud. Since my warranty has expired, I have used, a silent fan and I can't hear it anymore.
          • repair-it
            Need advice testing a samsung power supply board with scope
            by repair-it
            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
            07-12-2025, 11:00 AM
          • Tarot Superstars
            How not to Damage an Oscilloscope
            by Tarot Superstars
            Hello.
            I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
            I want to learn how not to damage it, and I found instructions on the internet obscure.
            They talk about ground, earth, floating ground, this, that....
            But they don't actually say anything anything useful so far.
            I want to know:
            Don't connect exactly this to exactly there or it blows up.
            For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
            I want to know what not to connect...
            08-29-2023, 02:27 PM
          • Evets
            Dynamco analogue oscilloscope
            by Evets
            I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
            08-30-2024, 06:54 AM
          • SolomonMan
            Vintage BK Precision 1403 Oscilloscope....
            by SolomonMan
            All,
            Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
            Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
            I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
            12-03-2023, 10:39 PM
          • EasyGoing1
            Reading input and output of bridge rectifier on the same scope?
            by EasyGoing1
            I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
            When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
            06-26-2022, 12:52 AM
