  • kca
    • Feb 2016
    • 548
    Hello all ~
    I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped off, no particular configuration led to 100% success.
    Question is, based on the following information and accompanying pictures, is this most likely a TCON issue (solved with a replacement TCON board) or is it housed in the panel display itself?
    Other info:
    ~ The power supply board, main board, WiFi, backlights, and audio (including Bluetooth functionality) all seem to be working perfectly fine.
    ~ Depending on the TCON trace tape-off configuration, I get a range of outcomes including full black screen, half black / half white screen, full picture but washed-out colors on left half of screen, normal coloration across the whole screen but then has overtly obvious horizontal lines (see pictures) and these lines are usually accompanied by faint but noticeable flashing of entire screen every 2 seconds or so.
    ~ I can get both the repetitive flashing and the horizontal lines to go away, but then the color is washed out on left-hand side of the screen.
    ~ When I do get the half black / half white, the white (left-hand) side is completely and quite uniformly white ~ leading me to conclude that the backlights themselves are a non-issue.
    ~ The half black / half white presentation only happens when I purposefully unhook one of the TCON's ribbon cables or if it doesn't close and lock fully after one of my change attempts.
    ~ Never do I get a half screen black (or white) with the other half functioning perfectly as is often the case with a faulty TCON.
    ~ It's apparent that the washed out colors begin at the halfway line and gradually get worse as you move to the left onscreen. There, at the vertical dividing line in the middle, the color washout is barely perceptible. But by the time you get to the left-hand side of the screen it is extremely washed out and, with certain trace configurations taped off, completely gray and void of any color. This "half and half" reality seems to lend credence to the faulty TCON theory.
    ~ It is at its worst in the lower-left hand corner (as evidenced quite clearly by the attached photos).
    Hoping it's the TCON, of course, and there is quite a bit of evidence that points to that (especially the fact that the entire right-hand side of the screen's image seems perfectly normal).
    Thanks for reading. Any advice or insights from previous experience(s) is very much appreciated.
  • EazyBone
    • Jun 2023
    • 1351
    • United states
    If taping is successful it's generally a panel issue. By successful I mean your getting picture like you are. There is generally lost picture as you experience with tape
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4380
      • Italy - Milan
      99% panel issue, you have also horizontal lines, typical of gate drivers not working as they should, try to blow hot air, then let it cool then spry freeze air to the bad area, back on the panel strip board, if you have it then turn on and see if the defect decrease temporarily... try at your own risk, but i know freeze air have not to be conductive, thus..
      • kca
        • Feb 2016
        • 548
        Thanks for the quick reply.
        I thought so too with the panel usually being the culprit when forced to tape off TCON to Panel ribbon traces.
        Unusually, though, there are no vertical lines at play and the fact that I can achieve full coloration across the entire screen with a minimal adjustment to the number and position of the trace tape-offs gave me great pause to call it a definitive panel issue.
        Wouldn't the fact that I can manipulate the scenario to eliminate the washed-out color effect indicate that the panel itself might be okay?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4380
          • Italy - Milan
          It's not so easy to answer... At the time you haven't been able to eliminate washed out colors, by showing only white , the image data are not been sent to the source Cofs and so the entrire screen, what you see is bad side disconnected by the direct circuitry but gate drivers already connected tho whose of the good and connected side along the pixels rows, the connected side will produce black screen.because tcon disables data sending to the source cofs, because of half screen disconnected, but the gate drivers arre still working and opening the pixel mosfet channels on the disconnected side, this tied probably to the missing vcom and pixels seeing a charge on the gates that opens the channels, maybe the white slowly fades to black, or any other reason with energized gates but without drain signals being opening channels and showing full backlight... I annoyed you i guess.. :-)
          • kca
            • Feb 2016
            • 548
            Not annoyed at all.
            I'm learning from all of you.
            Important Update:
            For some reason, about 10 minutes ago when I disconnected the left-side (aka, the "bad" side) ribbon cable leading from TCON to panel, then I did get the more typical half picture ok and half out response. Please see pics.
            As you just mentioned, the side where the picture is out started off pretty white but has been fading to darker and darker shades of gray over the last 10 to 15 minutes.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4380
              • Italy - Milan
              yes, you see first white because of the capacitance of the pixel gates, that remain charged for some time after disconnection
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4380
                • Italy - Milan
                I thought another thing, from which year is this beast Tv? If until, say, 2016/7, then it can possibly have verical side Cofs, instead.of CoGs, in that case is more esplicable the type of fault, and is because of corroded bottom left Cof, the spray test that way had to be made on that vertical area...
                • kca
                  • Feb 2016
                  • 548
                  The tv itself was manufactured in April of 2021 and the TCon board has a design date of May of 2019.
                  • howardc64
                    • Jun 2017
                    • 634
                    Seems mostly likely buffer board, COF, or the panel.
                    Check for shorts on caps (multimeter in diode mode on both end of cap) on the bad 1/2 buffer board. If have shorts will need to do voltage injection method to find what gets hot first.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4380
                      • Italy - Milan
                      NEVER do voltage injection on the panel strip boards because AVDD line need to be energized after the voltage application on Cof Vcc, otherwise damage at the horizon.. there is an easier and much more reliable method..
                      • Daren87
                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                        by Daren87
                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                        08-13-2023, 03:25 PM
                      • x_orange90_x
                        TCL 50S535 bad tcon or panel issue?
                        by x_orange90_x
                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                        03-29-2025, 11:02 PM
                      • harp
                        White screen repairs
                        by harp
                        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                        05-13-2024, 03:43 AM
                      • Megan0
                        Sharp LC-70UD1U Half screen Normal half screen is white
                        by Megan0
                        My Sharp LC-70UD1U Screen is black and flashing, "I attached the video"
                        Well, I opened the back cover and as you can see in the picture, I unplugged 2 L (left) ribbon, TV turned ON, but half of screen (Right) is normal, and the other side (Left) is white. I continued to test...
                        Result:
                        I swapped the ribbons L<-->R = Blinking 2x power light, 5x timer light
                        Unplugged 2 R Plug 2 L = Blinking 2x power light, 5x timer light
                        Unplugged 2 L Plug 2 R = Blinking 2x power light, 5x timer light
                        Only in the first test, where I did not
                        01-19-2022, 11:20 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
