Vizio E701i-A3 fixed but now has red vertical line
  • otaku_nut
    • Aug 2025
    • 6
    Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from the t-con to the lower driver boards to see if the stripe would move. I pressed on the connections on the t-con and the panel and driver board to try getting a reaction out of the stripe. I have factory reset the tv. None of these affected the red line. The red line is only there when the TV is on, it does go away when it is turned off. I can't seem to figure out how to do a firmware update via the menu and haven't pursued it much doubting that will fix this. Any suggestions of things to check, I'm a capable DIYer but have no formal training on boards and repairs so please don't be afraid to dumb things down a bit. At this point I'm guessing a fault in the t-con, bad tab on the panel (but would have expected a reaction from pressing on the tab if this was the case), or a bad connection somewhere. Thanks in advance for any advice anyone can offer. The guy I got the tv from said there were no lines before the screen went black so I don't know when the line issues was caused.
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
  • tmhobadcap
    VIZIO M60-C3 Can the vertical line be fixed?
    by tmhobadcap
    I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
    02-05-2023, 03:37 AM
  • Daren87
    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
    by Daren87
    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
    08-13-2023, 03:25 PM
  • Gootch46
    Vizio E60-c3 blue vertical line (dead center)
    by Gootch46
    My Father called me he has a Vizio E60-c3 that's probably 3-4-5 years old but it has a thin blue line running down the center of the screen (photo) I tried a couple things but I'm sure one of you all have seen this already. Been a while since I've been here hope all is well. Thank you in advance....
    05-26-2023, 05:42 PM
  • TrueSword88
    Kogan - KALED65XU9220STB - Blue Vertical Line
    by TrueSword88
    Hi all.
    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
    The line just happens to coincide with the end of COF and start of the next COF (attached).
    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
    Hoping to fix...
    05-05-2023, 04:28 PM
