Panasonic tc-p42s30 TNPA5349 SN board
  • andyb1712
    • Oct 2018
    • 41
    #41
    Re: Panasonic tc-p42s30 TNPA5349 SN board
    Finally got it working - removed all the blown up Chinese components and scrapped a spare x-sus from a TX-P50ST30B, which yielded the IGBTs I needed to fix it.
    I fitted RJP30H2s in place of the DG302s as the 4 x DG302s I removed from the scrapper also tested as capacitors. I'm not sure if they are dead or my transistor tester is telling lies about them.
    My Chinese supplier e-best_trade has been good for supplying the dual driver transistors and the buffer chips but the FGD4536s I bought were clearly not up to the job and must be fakes.
    Re-fitting all the screen ribbons took about 6 attempts before I got a picture free of horizontal lines but it looks good now.
    Another high usage set that shows 32,000+ hours before the loose screws took out the y-sus so pretty good. Picture is still as sharp as ever, even with my salvage parts repair
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      After all of...
      07-13-2024, 08:14 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
