Panasonic AX902B
  • John Rowbotham
    • Mar 2024
    Panasonic AX902B
    Hi everyone, I’m trying to source a working main board for a TX65AX902B. I believe it was also used in the 58 inch version. The board is a TNPH1101 1A.
    Currently have the 13 blink code.
    Many Thanks
  • lotas
    • Jan 2016
    • 4752
    • Russia
    This one doesn't fit? https://www.ebay.co.uk/itm/355890126098
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      After all of...
      07-13-2024, 08:14 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
    • tiku
      Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
      by tiku
      Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
      I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
      09-05-2021, 05:02 AM
