Samsung PN58C550 No Power question
  • kanescubs
    • Aug 2014
    • 9
    I just picked up this tv and I'm trying to fix it to give it to a family in need. I took the back off the tv and replaced the blown fuses. I took all the connections off the power supply board and plugged the tv in and the fuses were ok. I then proceeded to plug one board at a time into the power supply to see if it would blow the fuses. All the boards were ok except the component board or main board (part BN41-01344A). Do you think if I replaced the part that's blowing the fuses it will fix my problem? I'm very new to this so any advice is greatly appreciated!
  • MagicSmoke
    • Feb 2011
    • 275
    Re: Samsung PN58C550 No Power question
    Main board sends signal to PSU to turn on, Logic board then sends signal to bring up X & Y main boards. I don't think the Main board has any component on it that would draw enough current to blow the PSU fuse. X & Y mains do though.
    Have you tried the jumper test on PSU with it disconnected from all other boards to see if it is making the correct VS & VA voltages without blowing fuse.
    BTW posting a pic of front and back of PSU will help as someone may spot a problem that you might have missed.
    • kanescubs
      • Aug 2014
      • 9
      I'm not sure how to do the jumper test. Can you help me through it? Why do you think I'm blowing a fuse when I connect the main board? The back of the main board doesn't look great. I don't see burns but there is wearing on it. My power supply looks good I don't see anything visual but I know that doesn't necessarily mean anything.
      • MagicSmoke
        • Feb 2011
        • 275
        Pics Of PSU will help, particularly the power connectors so we are able to see what pins are where and the specified voltage they are supposed to have.
        Do you have a suitable multimeter to test for DC volts???
        To test, if this is your PSU in link below, then unplug upper left wires to Y main, middle wires to X main, lowest right bottom wires to logic and the wires connecting to main board. Leave the connection at PSU unplug this one from Main board.
        You will need this cable to jumper with a bread tie or suitably small gauge wire.
        Really need pics of the connector legend to main board to be sure which pins to jumper.
        https://www.badcaps.net/forum/attach...8&d=1362347385
        • MagicSmoke
          • Feb 2011
          • 275
          Are you trying to turn on TV after each connection or just plugging them in then connecting power cable??
          Because main board tells PSU to power up. Without it being connected the only DC output voltage on PSU should be 5V or whatever STBY volts are for your unit.
          • kanescubs
            • Aug 2014
            • 9
            I just plugged them into the power supply then plugged the tv cord into the outlet. This may sound dumb but I can't figure out how to post pictures.
            • kanescubs
              • Aug 2014
              • 9
              The picture you sent me looks like the same set. I do have a good tester but I'm not good at understanding it. I will try to test the psu tomorrow to see what the board reads. Thanks a lot for your help it's greatly appreciated!
              • mmartell
                • Oct 2013
                • 3189
                ... I'm stuck on the part where you said a family *needs* a 58" television...
                • kanescubs
                  • Aug 2014
                  • 9
                  I'm trying to help out a family who doesn't have and can't afford a tv. It just happens to be a 58"tv that I picked up for free. They don't need it but I would like to help.
                  • MagicSmoke
                    • Feb 2011
                    • 275
                    What is the P/N on the bar code on the PSU so I can see if I can get an idea of which pins to jumper. It should have a number on it similar to this BN44-00331A.
                    • kanescubs
                      • Aug 2014
                      • 9
                      I checked the board and that is the number on the psu. I really appreciate you taking the time to help.
                      • kanescubs
                        • Aug 2014
                        • 9
                        I just received my other main board and I put it into the tv and tried it out and the fuses blew again right away. It must be the psu or something else.
                        • MagicSmoke
                          • Feb 2011
                          • 275
                          First question, what meter do you have? Are the settings for DC volts separate 2, 20,200,600 or is it auto ranging ( just one position for DC volts )?? Actually 2 questions.
                          BTW here are the instructions for adding pics to the thread.>https://www.badcaps.net/forum/showthread.php?t=1868
                          When you click on the upload button you have to wait until it finishes the upload, it is not instantaneous.
                          • kanescubs
                            • Aug 2014
                            • 9
                            I just wanted to say thanks for reaching out to me and helping to is greatly appreciated! I just found a power supply board on eBay and picked it up for under 30.00 and tested the tv and I had success. The tv looks great! Thanks again
                            • Destroyer-Br
                              [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                              by Destroyer-Br
                              I'm working on an Acer Nitro 5 unit with the following specs:
                              • Motherboard: LA-J871P Rev: 1B
                              • Model: Acer AN515-55-59MT
                              • S/N: NHQ7JAL00403906A973400
                              • SNID: 03902728734
                              Initial Issue
                              The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                              After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                              04-17-2025, 08:18 PM
                            • Nicktronic
                              Samsung Power Supply Board BN44-00874F
                              by Nicktronic
                              Hey everyone,
                              This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                              Anybody...
                              03-17-2025, 06:20 AM
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
                            • repair-it
                              Need advice testing a samsung power supply board with scope
                              by repair-it
                              I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                              07-12-2025, 11:00 AM
