Samsung QE50Q60AAUXXH turns off as soon as backlight turns on
  • kalemaroni
    • Jun 2016
    • 189
    Plugging the power in will turn on the backlight after about 5 seconds and then immediately shuts down.
    If I unplug either of the two cables with the yellow outline in the picture the backlight stays on and the startup sound plays but no image. Any ideas how to proceed with this please?
  • lotas
    • Jan 2016
    • 4797
    • Russia
    And how did you manage to disconnect them, they don't have a connector? You tore them off the buffer board, now how are you going to solder them back in place?
    • mrtek
      • Oct 2010
      • 65
      Did you remove the cable connecting the buffer boards instead of the cables marked in the image?
      • Diah
        • Feb 2013
        • 6484
        Lotas the are U ribbon easy to disconnect one half as usual,
        OP you have 2 solder points, on main boards close to the sockets which come from power supply, make bridge between them , then you disconnect the U ribbon you did early at puffer boards , you will see picture and could know which side are defect at panel.. 50 size always i wrote , they are rubbish panel
        • kalemaroni
          • Jun 2016
          • 189
          Oh damn, yes you're right of course, the buffer boards cable is what I should've outlined.
          • mrtek
            • Oct 2010
            • 65
            Can you please show how the buffer boards are connected? I am assuming there is only one flex cable. You can apply the tape method on either end of the flex cable. I had similar situation with a 65 inch Samsung TV.
            • kalemaroni
              • Jun 2016
              • 189
              • kalemaroni
                • Jun 2016
                • 189
                Here you go:
                • howardc64
                  • Jun 2017
                  • 651
                  Here you go:
                  This connection path is harder to diagnose which side is bad because right side (looking from back) buffer boards signal goes through the left side. So no way to disconnect the left side and see if right side imagine is okay. Only if the fault is on the right side, then disconnecting it can potentially it’s the half containing the failure.
                  • mrtek
                    • Oct 2010
                    • 65
                    I would apply the tape method on the right side and see what happens. I did the same thing on my 50 inch Samsung.
                    https://www.badcaps.net/filedata/fet...3&d=1752628126
                    • kalemaroni
                      • Jun 2016
                      • 189
                      I'll try this method, thanks for the suggestion. The picture is quite blurry which pins have you taped off exactly?
                      • mrtek
                        • Oct 2010
                        • 65
                        These are the pins I have masked but in your case it may be different.
                        • mrtek
                          • Oct 2010
                          • 65
                          pin 17, 18, 19, counting from the left side, as shown in the image
                            09-07-2024, 05:50 AM
                          • C152Heavy
                            by C152Heavy
                            Summary for TL-DR readers:
                            • VCC pin (18) of PFC...
                            01-11-2023, 02:53 PM
                          • www
                            LG L192WS-BN backlight turns off after 1 second
                            by www
                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                            03-24-2024, 05:26 PM
                          • frannyjunk
                            Hisense 40H4F no backlight but turns off after splash screen
                            by frannyjunk
                            So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                            TIA.
                            09-24-2025, 10:59 AM
                          • sansanpartida
                            Samsung QE82Q70RAT no backlight
                            by sansanpartida
                            Hi everyone!
                            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                            My issue: No backlight.
                            Model: QE82Q70RAT
                            Type No: QE82Q70RAT
                            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                            So hopefully, I can fix this cheaper.
                            05-22-2024, 06:56 AM
