Sony Bravia 55 KDL-55EX640 no backlight / flashes once
    Re: Sony Bravia 55 KDL-55EX640 no backlight / flashes once
    Well, one way to be sure is to have spare LED strips (4) to verify. We do not have the diagram to really dig deep into component level on the board, other than that you can buy the board and take a chance that it will fix the problem. From what I have seen in other threads regarding to the LED backlights TV, common failures are in the LED strips not in the LED driver board.
    • triplefour
      • May 2014
      • 1747
      where can i get the spare LED strips? the client might be convinced to buy these to do the test before buying the psu which is 90 dollars
      would i have to take apart the panel to find out which LED strips i need to buy to test with?
      Don't fear the repair...
      • Ltank
        • Jun 2013
        • 776
        LED steps are considered part of the screen. Most Recyclers
        Remove boards and discard the screens. Too time and labor to disassemble the screen s
        • triplefour
          • May 2014
          • 1747
          so basically they cant be found unless i get lucky and find the same exact TV with a cracked screen?
          • triplefour
            • May 2014
            • 1747
            and is buying a new panel even an option? the TV is worth 900$ as far as i can tell
            • Clydeuk
              • Jan 2012
              • 193
              #46
              Not many TV's can justify the cost of a replacement panel, these are generally priced as expensive as the entire set, sometimes more than the set cost.
              • triplefour
                • May 2014
                • 1747
                yeah thats what i was figuring. i cant find anyone selling a panel for it. gonna try get them to buy this one with a cracked screen on ebay for 150$ and swap the boards. and if that doesnt work, then swap the LED strips.
                what im more irritated about though is why i was not able to see any amps going to the backlight (even though i know it was getting current because i saw it flash)
                i tried it with my analog meter as well and saw no change in the needle except when i put it on the lowest setting (.5 miliamps)
                and even then the only thing the needle did was slightly deflect to the left (what does that even mean???)
                  If the analog meter deflect to the left then you need to reverse the probes. Also are you saying all four wires none of them show activity?
                    "This might work, you can have just one of the four wire connected and see which one does not show a flash of backlights for seconds, you should observe it in dark room."
                    Did you do this test as I suggested?
                    • triplefour
                      • May 2014
                      • 1747
                      yeah that is exactly the test i did. with just one wire at a time, both white wires wont make a flash no matter what pin i put them in. the black and blue wires will make a flash on any pin, but if i turn off and restart the tv the flash gets dimmer and dimmer until i cant see it at all (even in a completely dark room) only with the black wire on pin3 do i get consistent backlight flashing. is there a way i can bypass the system's need, or trick the other pins into thinking they are drawing current so i can just power one LED strip at a time without it going into auto shutoff mode? i know it will be dim but at least it would show something...
                      dont know why they cant set it up that way to begin with. this "one goes out they all go out" shit is BULL
                      details of the testing i did were in post 37
                      • triplefour
                        • May 2014
                        • 1747
                        please... " is there a way i can bypass the system's need, or trick the other pins into thinking they are drawing current so i can just power one LED strip at a time without it going into auto shutoff mode? "
                        • triplefour
                          • May 2014
                          • 1747
                          someone on Ebay is offering to sell me the strips for 125 plus shipping. that seems like way too much... is it?
                          • triplefour
                            • May 2014
                            • 1747
                            little help? please
                            • triplefour
                              • May 2014
                              • 1747
                              why has this thread seemingly died on the operating table??? not to be a squeaky wheel but i only have so much space in my house for dead TV's...if i dont fix some of these and get em out i wont have room to fix any more!
                                To simulate the LED strip, we will need to know how many LED there are on the strip to get the total voltage drop on the string, then you may able to calculate the resistor value based on Guessing the driving current the LED string is using. So unless you know how many LEDs you have in the string you will not be able to use the resistor as the dummy load. You will have to take the panel apart to get to the LED strings. Right now per your test in post 37, you do have two bad strings so I do not see any reason to go further and since the LED string is not cheap, two already gone out, so the other will more likely to go out later. So is it worth spending lots of money on USED LED strips?
                                • triplefour
                                  • May 2014
                                  • 1747
                                  i can get all 4 strips from a guy named marcos on ebay for 100 bucks he says... that could be worth it, right?
                                  ive asked him how many LED are in the strip so i can make this resistor test you speak of.
                                  i know it seems like i do have 2 bad strips for sure but i would still like to see if i can make the other 2 light up on their own.
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    also this is for a client and i think they would be willing to pay 100 for a chance at fixing this tv
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      Salesmarcos never did get back to me with how many led per strip so I had to ask someone else...he said there are 7 led per strip. So how do I make the dummy resistor using this knowledge?
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        well i went ahead and bought some LED strips from the other guy on ebay "patch1stripe" who actually was nice enough to tell me there were 7 on each strip.
                                        however, he listed the item as NEW
                                        and when i finally got it, i notice one of the strips is missing an LED!
                                        i already sent him a message about it. because obviously they are not NEW!
                                        the other troubling thing is that while i thought we had decided that i should only have 4 LED strips in this panel,
                                        he sent me pairs enough to make 7 strips!
                                        without having opened the panel i have no idea now how many strips there actually are in there but 7 cant be right, can it?
                                        oh and also, i was hoping they would come with the wiring so i could just plug them directly into the power supply without opening the panel, but they are just the strips!
                                        is there a way i can hook these up externally to test my internal LED strips?
                                        and howabout trying to make a dummy load with some resistors based on what we now know about these LED strips?
                                        please help!
                                        • triplefour
                                          • May 2014
                                          • 1747
                                          boy its awful quiet in here....
                                          • thstuff
                                            SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                                            by thstuff
                                            This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                                            Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                                            1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                                            2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                                            01-30-2023, 05:01 PM
                                          • odie34
                                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                            by odie34
                                            I am a hobbyist (not a professional) so please be gentle...
                                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                            02-18-2024, 09:11 AM
                                          • justin35
                                            Sony bravia kdl-43w755c - boot loop
                                            by justin35
                                            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                            from what i read online it looks to be an emmc issue…
                                            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                            i took out the board and say an samsung 16gb emmc
                                            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                            i could try to put one instead of the 16gb one, but will it work?
                                            where do i get the software from?
                                            any help will be much appreciated!...
                                            03-06-2024, 12:26 PM
                                          • Dangerousk
                                            Sony Android TV KD-49XE9005 4 red flashes
                                            by Dangerousk
                                            Hi there
                                            Have Sony KD-49XE9005 that has been working fine for some time now. switched on this AM and after a few seconds screen blank and red LED flashing 4 times. Tried resets and all responding as expected expected and after booting up, after few seconds of displaying normal broadcast picture, screen goes blank red led flashes 4 times in sequence.
                                            Anyone have schematics/service manual for this series. have checked the obvious items and caps test OK, voltages etc appear correct onwards.
                                            thanks
                                            D
                                            10-27-2024, 06:10 AM
                                            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                                            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                                            10-16-2024, 05:15 AM
