Samsung HP-S4253 Power supply repair
  • cedward138
    • Jul 2012
    • 57
    • usa
    #41
    Re: Samsung HP-S4253 Power supply repair
    The pair against the upper heatsink are Q401, Q402 They bear the following: Toshiba k3911 .631
    The pair against the lower heat sink are U501, U601 Marked 7M0880 G31
    Hope this helps
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #42
      theres about 13 transistors/fets on all the heatsinks resolder them all and try powering on the board.
      • cedward138
        • Jul 2012
        • 57
        • usa
        #43
        The K3911 are FET'S according to Google.
        Resoldering joints soon
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #44
          If it dont work here is a test for mosfets
          Mosfets
          If you have a manual range multimeter, set it to 200 ohms (two hundred). This is for 3 pin ICs only. You can test a mosfet (Q, IC designation) "in circuit" by (power off and unplugged)
          a) black on pin 1- red on pin 2 - record ohms
          b) black on pin 1- red on pin 3 - record ohms
          c) black on pin 2- red on pin 3 - record ohms
          If any reading is less than 30 ohms you might have shorted mosfet. Remove from circuit and repeat the tests to verify.
          • cedward138
            • Jul 2012
            • 57
            • usa
            #45
            Resoldering did not breathe new life to the board.
            The mosfets read open/infinite between all pins all directions while in circuit.
            Though unscrewed from heatsink, mosfets are so firmly bound to it that I'm not sure they will come off in one piece for retesting out of circuit.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #46
              Mosfet Test is only for shorts so they are ok
              • cedward138
                • Jul 2012
                • 57
                • usa
                #47
                I set the meter on 1KV and probed various (random) points on the board. Seem to get a range of voltages (5, 15, 18) within the area marked hot but nothing on the cold side.
                Hope this sparks some idea for someone
                • cedward138
                  • Jul 2012
                  • 57
                  • usa
                  #48
                  I have a working identical power supply in another tv.
                  With guidance, I may be able to check corresponding components if that will help narrow down the problem(s)
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #49
                    Obvious thing, though you might not want to do it would be to try the working PSU
                    in the non-working machine.
                    • cedward138
                      • Jul 2012
                      • 57
                      • usa
                      #50
                      Actually, the psu came from the other machine which has sound but no picture. I've started a separate thread for that problem.
                      What I meant was that I could take voltage measurements at specific components of the working and bad psu for comparison if that would help. Not a board swap.
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #51
                        Problem is that the boards are interactive so in the set we are testing it in it may not be working due to a problem on any of the other boards having a problem, causing a protection circuit to switch it off.
                        You are in the enviable position of being able to try a different psu to see if
                        the other boards are working correctly.
                        The alternative would be to sit down and physically check every component
                        on both boards to try and find the dud ones. I realise that it may come to that anyway but it would be a great step forward to know the fault is actually on the board and not elsewhere.
                        What is the part number on U404 - top of the board just below the yellow transformer
                        • cedward138
                          • Jul 2012
                          • 57
                          • usa
                          #52
                          There is a cap directly in front of it so one of them has to come off to get the number. Just give me a few minutes
                          • cedward138
                            • Jul 2012
                            • 57
                            • usa
                            #53
                            Its KA7815
                            Btw it was 1 of 2 components that desoldered during use
                              • 31195
                              that's a voltage regulator.
                              if it got hot enough to desolder itself then either it's fucked, or something it's connected to is shorted out.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #55
                                Voltage regulators (U designation) can be bad. They can be shorted or output the incorrect voltage. The test described below only tests the former.
                                If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test voltage regulators "in circuit" for shorts by (power off and unplugged)
                                If any ohm reading is less than 30 ohm you might have shorted voltage regulator. Remove from circuit and repeat the tests to verify.
                                If it is out - test the solder points for shorts as well
                                • cedward138
                                  • Jul 2012
                                  • 57
                                  • usa
                                  #56
                                  I had to remove it to see the part number. I tested it as described while it was out of the board and all test reported "open"
                                    • 31195
                                    well the center pin & tab are ground,
                                    the rightmost pin is the output - and should be 15v
                                    hence the part number ending in 15
                                    • cedward138
                                      • Jul 2012
                                      • 57
                                      • usa
                                      #58
                                      I'm getting -ve 48 to -ve 56 on pin 1 (fluctuates repeatedly) and -ve 40 to -ve 46 on the other pins. Black lead connected to RTN peg on board.
                                      Found ?transistor on cold side (Q252) with 13.4 v to center pin and 0 v on the other pins. Part number not written or may have 'burned off' the component. no voltages are found beyond this part.
                                        • 31195
                                        what voltage between pin1 and the tab/pin2?
                                        and what voltage between pin3 and the tab/pin2?
                                        • cedward138
                                          • Jul 2012
                                          • 57
                                          • usa
                                          #60
                                          Pin 1 to pin 2 = 0 v
                                          Pin 3 to pin 2 = 0 v
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • cheeky2
                                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                            by cheeky2
                                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                            06-15-2025, 05:12 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
