Panasonic TX-P42S21BA - 7 red flashes
  • Nurbit
    • 16
    Hi guys
    I've recently acquired the TV mentioned in the title.
    When turned on, it flashes the green light quickly and then flashes the red light 7 times.
    I've looked at several other threads about Panasonic TVs and was going to try one of Tom66's solutions but because the boards have different SD,SU,SS names, I thought I'd post on here first to see if anyone can help.
    From what I can gather, the 2 boards on the left (sometimes call SU and SD on certain models) are called SM and SC on this TV.
    I'm happy to isolate the boards but could do with knowing where the jumper wire needs to go to and from on this particular model.
    I can add photos of the TV's guts if needed.
    Any help would be greatly appreciated.
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Re: Panasonic TX-P42S21BA - 7 red flashes
    I think 7 blinks almost always requires a panel replace and/or indicates a repair that requires panel replacement. I have a similar post above yours We'll see what the other say. Good luck.
    • Nurbit
      • 16
      Hi Tucocaps
      I'm still playing with the TV and have found that sometimes, it does display a distorted image which quickly fades before the red flashing starts.
      I'm starting to suspect that it's a fault with one of the MOSFETS on the SC board...... but I could and probably will be wrong :/
      • Shinju
        • Mar 2014
        • 1239
        7 blinks is SOS for SC board, I have a Panny here with no damage to the screen at all and I get a 3 blink when everything is connected and a 7 when the SC board is the only thing connected.
        SC boards for these are NOT CHEAP, so test everything before sticking a new board in so that you dont blow that one up too
        Tom66 or TW2005 will probably chime in, they know a ton about plasma panels, TW2005 seems to be the Panny expert
        • Nurbit
          • 16
          Quick update -
          After power cycling the TV a few times, it's now working perfectly....
          I've tried leaving it a while and then turning it back on thinking that the fault would re-appear and it hasn't yet.
          I'm going to leave it alone over night and try it again in the morning. I suspect it will fail again.
          Usually, I'd suspect a bad capacitor or two to cause this kind of fault but I read Tom66's statement in another thread about Panasonics not having cap problems.
          I'll see what happens in the morning, if it's dead again, I may start pulling caps and testing them with my ESR meter.
          Until then, if anyone has any other ideas I'd love to hear them.
          • Nurbit
            • 16
            Replacing the board?? That's cheating
            I'll be attempting a repair on mine instead
            • Shinju
              • Mar 2014
              • 1239
              replace/repair either or. the kits for some of these SC boards are hard to get too. the one for mine has been unavailable for months.
              So it sits
              • Shinju
                • Mar 2014
                • 1239
                Oh and snap photos of everything and post em, it will help diagnose stuff better if they can see it.
                • Nurbit
                  • 16
                  So it sits
                  Have you tried looking for the components individually?
                  You might be better off making your own "kit" up. It might cost you slightly more if you have to buy a 10 pack of some parts but at least you'll have them on stock :-)
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    Quick update -
                    from what ive read most sc boards fail with shorted/blown parts as your set works intermitantly it maybe ok lets see what toms and tw2005 thaughts/advice is.
                    • tw2005
                      • Oct 2011
                      • 6458
                      So the board is a TXNSC11DEK, tnpa5105ad. I'd measure all the voltages if it's running on the SC board.
                      One may be close to the threshold of shutdown.
                      TPVSUS,TPVAD,TPVSCN,TPVe
                      If it becomes more consistant faulting, then next step would be to isolate the buffer board and jumper SC50 and see if it fixes it straight away or still there indicating SC.
                      I have had a 2009 HD which had 7 blinks and could get it to fire intermittently. I think VAD was low and on that SC it had an adjustment pot which made no difference.
                      Never went any further with it, board swap, that waws before I got interested in saving these boards.
                      Not sure where you'd start for SC that has not blown the transistors, but getting some reading may help give a clue.
                      I've also had a bad octal buffer IC at SC20 cause 7 blink.
                      So when running the picture is good?
                      • Nurbit
                        • 16
                        Thanks for the reply.
                        Came to the TV tonight and it worked on the second power cycle.... now is still working.
                        The picture is absolutely perfect so far although I've only tested it with a raspberry pi as that's all I had near me.
                        • Nurbit
                          • 16
                          Quick update on this TV.
                          After a couple of weeks of having to power cycle the TV a few times, the problem went away.
                          I've been using daily ever since and the problem hasn't returned... yet
                          • tw2005
                            • Oct 2011
                            • 6458
                            Amazing, may it live on
                            Funny thing is the moment you make a statement like this it'll go caput.
                            Like last week I was having a cold one with a mate I revived a panasoic 2006 from the dump for $20. we were just amazed how good and bright that SD picture was. He's had it for months
                            Next day , he said bugger, we jinxed it. Died today just shutdown.
                            Sounded terminal like the main board, so he invested in a 4yr LG, his choice.
                            Not much to pick from where we are.
                            • Andre Gilbert
                              by Andre Gilbert
                              11-20-2024, 08:52 PM
                            • AquaMan Ua
                              Problem with PANASONIC CF53 laptop after changing BIOS settings
                              by AquaMan Ua
                              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                              05-17-2025, 09:40 AM
                            • odie34
                              Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                              by odie34
                              I am a hobbyist (not a professional) so please be gentle...
                              I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                              I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                              02-18-2024, 09:11 AM
                            • ItepK
                              Panasonic TX-P42G30E green light blinking, no video, no audio
                              by ItepK
                              Hey everyone!
                              I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                              This post describes my entire troubleshooting process of this TV.
                              When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                              I've taken the unit apart, and I've started to check some voltages:
                              • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                              12-22-2023, 05:06 AM
                            • Paft
                              Panasonic Viera TX-P42S21B - 7 Red Flashes
                              by Paft
                              My Panasonic Viera TX-P42S21B 42" 1080p HD Plasma developed a fault a few days ago.
                              It looks like it's going to come on, makes that click sound but then goes off. Doesn't turn on via remote.
                              So, obviously it's likely one or more of the components/boards. I don’t see any results for my model or a service manual anywhere, but I’ve briefly looked into it with similar models and apparently it is the SC and or SM board(s.)
                              How accurate are the fault blink codes? I don’t see any glaringly obvious damage on the SC/SM boards but the power supply has some markings....
                              10-21-2020, 07:58 AM
