Scoping the LVDS Connector
  • mmartell
    • Oct 2013
    • 3189
    I am working on a Toshiba 32HL86 which has sound and backlight but no pic. The tcon is buried and looks to be a pita to get at.
    I was wondering if there was a way to reliably ascertain if the video signal was reaching the lvds connector. Seems like it might come in handy whether or not your tcon is readily accessible.
  • popeye
    • May 2011
    • 155
    Re: Scoping the LVDS Connector
    You may have signal at pcg but that will not tell you if lvsd lead or tcon faulty.
    • mmartell
      • Oct 2013
      • 3189
      Good way to differentiate between a bad main or a bad tcon though.
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • Tomylee
        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
        by Tomylee
        Sorry for the person who’s going to read all this !
        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
        07-11-2025, 11:52 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • corrize
        Best way to solder LVDS connector for beginner (and qfn) ?
        by corrize
        Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
        I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
        I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
        See the test :
        https://youtu.be/bNAzC-EvqHs?t=1767
        With hot air from bellow the board, that's...
        03-09-2023, 02:57 AM
      • advant
        by advant
        02-03-2020, 12:25 AM
