RCA L32WD12 Power Supply Problems
  • aonomus
    • Jul 2014
    So, this is probably very similar to a number of threads regarding similar L##WD12 series RCA TVs with bum power supplies but I just want to confirm my initial diagnosis.
    What I know:
    - Pressing power button causes 1W SMPS relay to switch over, power LED blinks red.
    - 1W SMPS 5.3V standby voltage appears to be good, drops to zero though when relay clicks
    - Main PSU is getting AC when relay switches
    - Main PSU PS_ON rail is getting 3.13V, neither 5V or 24V rails are coming up though.
    - Applying 3.3V to PS_ON on the main SMPS does not cause the backlight or display to come on.
    - No caps on 1W or main SMPS board are bulged or deformed in any way. Murphy's law dictates that my LCR meter needs a new battery, and I don't have an ESR meter either.
    What I think is the problem:
    - Could be the 1W SMPS output dropping when the mainboard tries to power up the main PSU, or it could be just an effect of it not having the main SMPS to back the 5V rail when it should.
    - Main SMPS more likely the problem, since it still should power up once you apply voltage to PS_ON.
    - Could potentially be either the 150uF 450V cap, or the +5V/+24V output caps that are bad since they're probably the most likely to be underspecced for ripple current/ESR. I have Digikey PN's for replacements with better specs than the SAMXON capacitors used but I'm holding off until I have a clearer idea if its the caps or not.
    Now, I really hope it isn't another component buried in the SMPS since I only took this TV off a coworkers hands for free - he'd rather see it repaired and not landfilled. I'm only able to put so much time and money into it before I'll wash my hands of it as well though. Hoping the community here has some more specific thoughts.
    Re: RCA L32WD12 Power Supply Problems
    Can you supply a picture of the 1W PSU.... I do not think it should drop when the relay clicks over.
    • aonomus
      • Jul 2014
      Images:
      http://aonomus.com/img/RCA_L32WD12_1W_Bottom.jpg
      http://aonomus.com/img/RCA_L32WD12_1W_Top.jpg
      So the initial diagnosis of 'output drops to zero' was somewhat incorrect. It appears to drop from 5.3V stable to around 2.8V (I had probed the wrong pins on the standby board). At the very least I'll be able to come up with appropriate part numbers for the caps on the 1W SMPS board, though will even the small ceramic HV caps require replacement?
        I'd replace all the electrolytics with the exception of the 400V one. Even 2.8V is much too low and could be causing issues.
        • JELittleton
          • Sep 2014
          This is an FYI for anyone troubleshooting an RCA L32WD12:
          My symptoms were as described: TV powers on (relay clicks) and after about 4 seconds, just as the picture is about to appear, the TV powers off (relay clicks again). The process repeats unattended until A) the TV locks up, powered on with noise on the screen or B) the faulty component warms up enough for the TV to remain on, usually after 3-5 minutes of unattended on/off/on power cycling.
          Replacing CP616, plus the other electrolytic capacitors (CP611, CP613, CP614) on the SMPS 1 Watt board resolved this issue for me. I could have replaced just CP616 but none of the capacitors looked bad on this board. To make this a cost-effective repair, I replaced all for less than $5 (including shipping) from Digi-Key.
          Also, capacitors on the SMPS Main power supply board (located in the lower right from the back) were bulging on the top. I replaced all caps in the 12 vdc (CS7, CS8, CS32) and 24 vdc section (CS2, CS3, CS43). Replacing these caps did NOT resolve the power on/off/on issue but they required replacement anyway.
          Caps replaced on SMPS 1 Watt board
          CP616: 470 uf, 16v
          CP611: 47 uf 200v
          CP613: 22 uf 50v
          CP 614: 10 uf 63v
          Caps replaced on SMPS Main power supply
          CS2, CS3, CS43: 1000 uf 35v
          CS7, CS8, CS32: 1000 uf 16v
          Total repair cost: $12.61 (from Digi-Key, including shipping).
          Schematics (requires registration to view)
          SMPS 1 Watt Board - https://www.badcaps.net/forum/attach...3&d=1336172937
          L32WD12 schematics - https://www.badcaps.net/forum/attach...6&d=1398264681
          • freakaftr8
            • Oct 2012
            • 3743
            Good job! Another one for the records
            • JCS8274
              • Jan 2015
              I Need A Schematic Diag of the Power Supply Board for A Rca L32WD12>>Thanks, Jon
                The 5V TSBY power supply?
                • JCS8274
                  • Jan 2015
                  Thanks__budm--The problem was in the Main AMPS Board (12v Caps--cs7,cs8 cs32 ) & the ( 24v Caps--cs2, cs3, cs43 ) listed by JELittleton Above. After looking more closely at his
                  Listing of Schematics ( Approx 30 ) I found it. Since I had Drilled out some of the Apparently Plated-Through Holes--I needed to run wires back through the holes to complete the circuit--I am not a complete Novice , but almost missed this.___JCS8274
                  • BurtL
                    BurtL
                    • Dec 2015
                    Hello all,
                    A friend of mine gave me an RCA flat screen TV for parts but it looks
                    too good to scrap so am attempting to repair it. The model is L32WD12
                    and it looks like the power supply is bad. The standby supply seems OK
                    and the 12 and 24 volt outputs are pulsing up to about half voltage. I put a
                    load on the 12 volt output and the 12 volt bulb pulses as about twice a second
                    and the 24 volt part seems to be doing the same thing. I went over the board
                    with my VOM and could not find any parts that I could detect as defective. I
                    suspect faulty capacitors so am heading that way unless there is a better
                    path to follow. I'm wondering if there may be some way to diagnose this thing
                    using test points possibly. I know the supply is generating some high voltage
                    as the 400 volt electrolytic charges up nicely. I don't have much experience
                    with switching supplies so expect it will be a learning experience. I will be
                    doing some study on switching supplies but in the meantime would welcome
                    comments from the forum.
                    I'm new here but not new to electronics so am comfortable working with this unit
                    even though switching supplies are new to me.
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                    • semiRocket
                      Toshiba 37bv701b power supply main rails
                      by semiRocket
                      The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                      I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                      Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                      10-26-2025, 01:55 AM
                      03-31-2024, 02:12 PM
                    • alltvrepairs
                      Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                      by alltvrepairs
                      I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                      I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                      Any one met this problem in the past?...
                      10-08-2025, 07:34 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
