Hisense H55U7B vertical stripes
  • Davi.p
    • Sep 2009
    • 4273
    • Italy - Milan
    #41
    Check the uClamp6514P (UCLAMP6514P.TNT) or uClamp4014P
      • 12085
      • U.S.
      #42
      Come on now, davi did not solve anything. Posts 9, 11 and 13 told you what was wrong. He is pretty well known for echoing the solution when someone already posted it tho, so nothing new.
      • Davi.p
        • Sep 2009
        • 4273
        • Italy - Milan
        #43
        You are here only to say that stupid bar things, you make me tenderness, a man with no art no part.. you are trying find friends to do a war.. you are the s** of s**s in electronics and you are here commenting, this is an easy repair and old case type, i saw it back in 2019 or earlier.. not a scientist needed to solve this, i'm interested in new cases, not repeating things like the poor emplyee with no money earn..
          • 12085
          • U.S.
          #44
          Nah, you're just here to try to take credit for other peoples solves, not to worry, we ALL know it.
          • Davi.p
            • Sep 2009
            • 4273
            • Italy - Milan
            #45
            man of s*** , you said you was out of here so get out here instead of criticize the web site, nobody will remember you , stop saying fool things of a paranoyd
              • 12085
              • U.S.
              #46
              Not wasting time responding to you pee, I'll let the others point out the problems with you. They won't let you harm anyone's devices with your little "experiments"
              • Davi.p
                • Sep 2009
                • 4273
                • Italy - Milan
                #47
                you was searching for users ban, not? what you are waiting for? stop telling your personal lies to hide your incapability...
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • ahoonid
                  MacBook A1990 vertical stripes on external screen
                  by ahoonid
                  Hey everyone,
                  I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                  The board is neat. Not opened before for sure. Just a little dust, nothing more.
                  Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                  06-20-2025, 08:54 AM
                • kevinman
                  KD-55X9005A Vertical Stripes Right Side Mirrored Vertically At Start
                  by kevinman
                  Hi, TV boots with distorted image right side mirrored verticaly sometimes vertical stripes making off-on turns picture to normal and "perfect" (netflix image) that I highly doubt this is something related with t-con signal lines?? rather it looks software corruption bad mem chips voltage collapse or an intantaneous fault with fluctuating powerboard voltages?? As it happens usually when TV is cold sometimes fault comes back after a full day use should I check powerboard voltages with oscilloscope??
                  12-17-2023, 06:22 AM
                • mopenstein
                  Looking for Vertical IC for RCA Chassis CTC159L CRT
                  by mopenstein
                  I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                  Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                  I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                  09-24-2023, 10:41 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
