Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
  • cheeky2
    • Dec 2012
    • 337
    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets Q1820 and Q1821 ( FDPF7N50U) however they blew again (these Mosfets replaced could have been fake ones from China). I did replace the diodes (D1830, D1831, D1832, D1833) with KDS184 as I did find one blown. However the schematic doesn't show Q1811 and Q1810 and I suspect the KDS184 (D1830, D1831, D1832, D1833) might be wrong as well!
    The Mosfets Q1820 and Q1821 ( FDPF7N50U) are circled in red on the images.
    So does anyone know what these diodes and transistors should be D1830, D1831, D1832, D1833, Q1811 & Q1810 ? Circled in white for diodes and blue for Transistors on the back of the pcb.
    This repair has been on the back burner for a while and I would like to see the back of it!
    All help will be appreciated.
  • cheeky2
    • Dec 2012
    • 337
    Just managed to find an image of the schematic see attached file.
    Which turns out D1830, D1831, D1832, D1833 are KDS184 and Q1811 & Q1810 are MMBT2907A
    • EazyBone
      • Jun 2023
      • 1340
      • United states
      You have to change the blue caps next to them also
      • cheeky2
        • Dec 2012
        • 337
        Thanks I assume you mean C1890 and the C1891 the 220pf 1KV if they are 1KV I may just uprate them to 2KV as I have some.
        • EazyBone
          • Jun 2023
          • 1340
          • United states
          Yes, when the mosfets go or vice versa it blows the other one. And if they didn't blow, they probably will soon. Yes change the caps and see what happens, of course the mosfets again now
          • cheeky2
            • Dec 2012
            • 337
            The Mosfets were changed a while back from a different supplier. I am just going the check the diodes and transistors this coming week as I will really have to remove them as there are a few components that will affect testing if I don't! Hopefully I will report success later on this coming week!
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4333
              • Italy - Milan
              Hi, you have to check every elctrolytic cap esr+capacity before change other parts, and also the pulse control chip that belongs to the two mosfets is prone to break, especially if you measure D-G short on the mosfets..
              • cmlewis89
                LG 47LB5DF blown power supply board
                by cmlewis89
                Hi folks,
                I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                09-03-2024, 07:50 PM
              • Rodalco
                Samsung LCD TV Q1820-Q1821 mosfets blown
                by Rodalco
                Hello, Just trying to repair my sons LCD TV which stopped working. Samsung T370HW03
                Found the 3.15 Amp fuse blown ( FM802S ).
                Nothing obvious like bulged electrolytics or toasted R's or burnt tracks.
                Did a recheck with a 500 Watt lamp in place of fuse FM802S to limit current to 2.5 Amps, something lit up on the board which I captured on video camera.
                That appeared it was Q1821 mosfet.
                Testing the mosfets and they appear shorted out on the diode tester.
                There are SMD R's on the other side of the board which look alright, and I have never removed those as they...
                02-06-2019, 10:15 PM
              • drscoot
                HP X360 convertible battery blown fuse error, not charging
                by drscoot
                HP Modelnumber: 14-dh0061nb​
                This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                All these 3 batteries are charging...
                12-15-2023, 05:54 AM
              • swerg
                Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                by swerg
                Hey everyone,
                I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                06-06-2024, 03:39 PM
              • MrzPdlch
                Blown fuses on Gigabyte GTX 980TI 6GB
                by MrzPdlch
                Hey everyone,
                I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                Find some pictures of the actual GPU together with a picture of how it should look like.
                I also wonder whther it might be a problem that there...
                03-10-2024, 04:14 PM
