Is there a good way to wire fans to turn on with tv?
+ More Options
Posts
    Re: Is there a good way to wire fans to turn on with tv?
    You can run a 12V fan on 15V. It will run faster. Most of them are rated something like 7~16VDC. You can also use a resistor in series to drop the operating voltage which will be far simpler than a linear regulator.
    • davep911
      • Jul 2014
      • 35
      • US
      After 2 weeks running 2 thermister fans at about 50% I have decided they are too loud. Fans unmounted are really quiet but when screwed to the large, thin back cover they create noise. With the fans the temp is about 110 deg F. Without them it is about 150 deg and with the back cover and fans off it is about 130 deg.
      I don't have kids or any random people around this tv so is there any reason why I couldn't just keep the back cover off?
      Is 150 deg F ok and I am worrying about nothing?
        Oddly, running with the cover off can be worse. With no ducting for the air, the TV may run hotter than before. I've noticed this on certain Panasonic plasmas.
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          yeah agreed, seen this issue also,when the tv back is removed, its exposed to ambient temps which are higher than a duct vented fan which obviously has forced cooling, = lower temps.
          fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
          please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
          • tibimakai
            • Jan 2012
            • 3680
            You should use, those push in rubber feet for the fan.
            • davep911
              • Jul 2014
              • 35
              • US
              #26
              Right, the tv almost seems to move as much air with the fans off as with them on. I think the reason it's cooler with the cover off is because the tv is near an A/C vent that is on most of the time.
              Tried with and without rubber feet and the screws loose and tight but there is not much difference. I think 1 of the fans is a little unbalanced and it is being amplified at a large unsupported area of the back cover.
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
                by momaka
                03-15-2023, 10:17 PM
              • irepair559
                Ps4 1215a hdmi diode readings good everything good but no pic??
                by irepair559
                PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                01-05-2023, 12:32 AM
              • xdever
                MacbookPro 14 820-02098 liquid damage internal LCD not working
                by xdever
                I have an A2442 MacBook with 820-02098 board. It had water damage, and some service already worked on the board and removed the HDMI connector.
                When I got it, the machine worked fine, except for half of the keyboard, which needed to be replaced because it got liquid. The back side of the fans had some sticky liquid, so I guess the board had to have some at some point in the past as well, but it seems to be cleaned by the service who tried to repair it. There is no sign of any oxidation or trace of liquid on the board or the connectors. Everything is as clean...
                11-03-2022, 11:39 AM
              • technicalspecialist
                Vintage fan repair, copper wire question
                by technicalspecialist
                I currently have a customer's vintage fan on the work bench to repair.
                It uses an induction motor with 4 poles. One of the poles is open.
                I couldn't find the break so i cut off the original wire.
                I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                The enamelled copper...
                03-16-2023, 12:54 PM
