how to fix plama lg 42pt350 help?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    need help i cant fix a plasma if my life depended on it. Where should i begin. Tv had red power light on outside, when i press power it just clicks like its trying to turn on. I started unplugging cables and ribbons and still trying but cant get any change
  • Hamie
    • Apr 2014
    • 1383
    Re: how to fix plama lg 42pt350 help?
    What have you unplugged?
    Probably a powersupply issue.
    Unplug the y and x main.
    Any change?
      Use a volt meter to check Vs and Va on power board.
      • selldoor
        Slow Learner
        • 7870
        Hope you at least know enough to know that the set must be off when plugging
        unplugging cables
        • mattstolte
          • Dec 2013
          • 612
          • usa
          Vs and va go up when i press power but then goes right back down
          • mattstolte
            • Dec 2013
            • 612
            • usa
            The power clicks off right when the vs and va go up the power supply clicks off
              Do Vs and Va rise to normal voltages?
              Check the white ceramic resistors near top of PSU - they can sometimes fail on this model
              • mattstolte
                • Dec 2013
                • 612
                • usa
                Tom how do i check them
                  Like any resistor - check they meet printed specifications. I think they are usually 22 ohm or 10 ohm. So they should measure about 22 ohm or 10 ohm.
                  • mattstolte
                    • Dec 2013
                    • 612
                    • usa
                    Im not sure which ceramic ur talking about, im learning so bare with me, are u talking about the red ones in the top right
                    • tw2005
                      • Oct 2011
                      • 6458
                      • mattstolte
                        • Dec 2013
                        • 612
                        • usa
                        Ok so i unplugged z sus and ysus. And power supply will turn on and stay on with va and vs power voltages at correct readings. So as soon as i plug in zsus it will cut off, and i cant plug ysus in or out direct cause it runs from zsus. So is it bad zsus?
                          That is a possibility, if you remove it, you can check it for shorts. But I am confused, you said you had brief Vs/Va. If it were shorted you could not have that.
                          • mattstolte
                            • Dec 2013
                            • 612
                            • usa
                            ok so when I have everything propely connected this is what happens when I turn on when everythings connected the va goes up to 350 when its suppose to be 55, then the vs goes up to 130 when its suppose to be 201,
                            now when I take the connector from the zsus and turn it on the va stays at 55 and the vs stays at 201. so now what?
                              If your Va actually went to 350V, there would be flames coming from the plasma panel module. Is your meter an autoranging meter - if so could you try locking it into the highest DC range (refer to your meter's manual for how to set the range manually.) Some digital meters can over-shoot on rapidly changing voltages especially if they change range.
                              • mattstolte
                                • Dec 2013
                                • 612
                                • usa
                                ok well regardless though tom it works without any of that hooked up, so when I hook vsus back up then it doesn't work, so what else can I check? but it looks like zsus right?
                                  It is a definite possibility. If you remove the board, it can be tested, if you supply good clear photos of the top and bottom sides of the board.
                                  • mattstolte
                                    • Dec 2013
                                    • 612
                                    • usa
                                    Tom here is pictures of top and bottom of board and on bottom there is a burnt up spot on solder where the i think it is a transsitor or whstever it is? I dont know how to test them 3 legged things. So i was thinking that was it.
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      Board looks fine to me, You need to check the MOSFETS etc for shorts....
                                      TELEFIX
                                        MOSFETs/IGBTs are the three legged devices on the heatsink marked Qxxx.
                                        Diodes are usually two legged. In some cases there are three legged diodes with two pins tied together on the board, these are marked Dxxx.
                                        For Qxxx, you want to put your meter across all three combinations of pins (both ways, 6 per device) on diode test and look for a reading less than about 30. In all cases, leave the reading to settle for a few seconds. A low reading indicates a possible short which requires investigation - it should ideally be removed to confirm.
                                        For Dxxx just test both ways across it and look for about 300 to 700 one way, open circuit the other way, note a shorted transistor can make a nearby diode look bad. It is very rare for diodes to fail in a plasma TV.
                                        • chazh
                                          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                                          by chazh
                                          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                                          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                                          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                                          09-01-2025, 08:56 PM
                                        • eccerr0r
                                          lowest current galvanometer/analog meter (passively powered!)
                                          by eccerr0r
                                          Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                          On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                          04-16-2025, 12:41 AM
                                        • Doc38343
                                          LG 42PT350-UD Audio no picture and no prime.
                                          by Doc38343
                                          I read some of the other posts and while similar not the same though. I made a new one to ease the diagnostics. Fellow brought this one and he has already been online and trying to fix it himself. I am not sure what all he had done but the screws were out of the Y-board.
                                          I have just started my diagnostics process so i put everything back.
                                          Have red standby LED. When you press ON on the remote I hear the relays trip once and the red light blinks off then on and slowly fades out.
                                          OK All voltages check right on power supply. INCLUDING VA and VS.
                                          3.3v standby, 5.2 on 5v rail...
                                          08-21-2017, 08:38 PM
                                        • Lavitz
                                          Two LG TVs having issues. 50pc5d and 42pt350.
                                          by Lavitz
                                          I'm not really sure where to start on the 50pc5d. The TV in its current state shows no power is being received at all. When plugged in and the power button is pressed there is no feedback in any way. It was a TV used for karaoke in a bar so there is also no telling how much damage there is from smoke either.
                                          The second TV just went out today. From the research I have already done it sounds as if there is either a power supply issue or an issue with the y sus or z sus. The current status on this TV is that it clicks on, makes a buzzing sound, and the light turns on for a moment...
                                          03-21-2017, 06:42 PM
                                        • 5chematic
                                          Samsung Chromebook XE303C12 recovery OS image
                                          by 5chematic
                                          Hello guys, I have a Samsung Chromebook Model: XE303C12 that needs recovery.
                                          The problem I am having is that I have always depended on the Chrome OS Image Creator, but this time it wont accept anything I put in. I mean the model shown at the bottom of the chromebook screen when you see the "Chrome OS is damaged.
                                          I was reading that a lots of people around the world are affected because critical files needed for chromeos recovery are either empty or incomplete.
                                          If anyone have the .bin OS, will be nice if you can share it. I will really appreciate...
                                          11-25-2020, 04:57 PM
