Celcus lc32s913hd
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Celcus lc32s913hd
    Hi Guys,
    My sisters TV died! we had thunder storms last week and since then if you switch it on it will run OK for around 15-20mins and then turn off and does not even show the red stand by light, if you leave it off for a while it will come back on and work for 15-20mins and switch off.
    Check the Vestel 17PW25-4 for bulging caps and O/C diodes and all seems well, any thought please?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Celcus lc32s913hd
    Its a Vestel 15 minutes is really good !!!
    Just type 17PW25-4 into the search above and check out some threads
    Oh - when its on try heating the boards with a hair dryer see if it goes off quicker.
    Then try a cooling fan see if it stays on longer.
    Possible indication of bad solder joints
      • 31190
      if it was caused by lightning it's probably a fet or chip damaged by static.
      • Andyd1970
        • Feb 2013
        • 374
        • united kingdom
        When you say damaged FET or chip, are you referring to the PSU? or the A board?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Have you tried the heating/cooling yet?
            • 31190
            got any pcb foto's ?
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • France_53
              Vestel tv, how to flip the image?
              by France_53
              Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
              05-12-2024, 05:22 AM
            • FlailingEngineer
              Help with Bush Tv (Vestel 17mb95m Mainboard)
              by FlailingEngineer
              Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
              Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
              05-31-2023, 06:52 AM
            • hazi12
              Vestel main board 17MB140TC
              by hazi12
              Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
              Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
              I can send a dump....
              10-01-2025, 01:28 PM
            • massimomax
              Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
              by massimomax
              Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
              spero che qualcuno può averlo per riprogrammare eprom. grazie
              Post in English !!!
              I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
              02-28-2025, 07:27 AM
