Panasonic TH-P50V20A no screen
  • bradm
    • Jul 2014
    • 30
    I picked up this tv for $50 not working.
    When the power button is pressed the led blinks green then i get 7 blinking red.
    I have the service manual and it says check the sc/su boards.
    Does that mean i need a replacement? Or can i replace some components? (caps)
    I have done plenty of soldering etc so thats not an issue.
    I have some pics of the boards.
    Thank you for you help
  • selldoor
    Slow Learner
    • 7870
    Re: Panasonic TH-P50V20A no screen
    Please can you repost the pictures using manage attachments - jpgs up to 3mb are good
    off site in line take a while to load and when they disappear the thread will have no meaning or be of help in the future
    You can then eit out the ones you have posted
    • bradm
      • Jul 2014
      • 30
      ok will do just need to resize them they are just over 4.77mb
      any quick and easy programs for this?
      • selldoor
        Slow Learner
        • 7870
        Picresize perhaps - i just use Paint or mircrosoft pic manager which is an Office Tool.
        • tw2005
          • Oct 2011
          • 6458
          It's a Panasonic, likelihood of badcaps is much lower than say majority of other brands as the brands inside there are nichicon or rubycon.
          Any way this series has a common fault of SC boards but since this is 7 blink you may be lucky that it's just the SD/SU boards.
          Here's the test to be sure. Disconnect the 3 white connectors on the buffer boards, they're tight but be gentle you don't want to break them.
          then remove the 4 gnd screws that mount those boards.
          Then on the SC board there is a small 2 pin white connector near bottom left SC50. Those pins need to be jumpered together.
          Then turn the TV on, if it goes green LED no SOS blinks then the SC has passed and you need to then test the buffers.
          Other wise it's a bad SC and you still need to test the buffers.
          • tw2005
            • Oct 2011
            • 6458
            Do everyone a favour and resize those pics to 2000x2000 max size and go advanced, manage attachments and upload those pics that way although it's probably too late for you to edit now but if not get rid of them as it's a pain in the ass.
            Maybe a moderator can remove them?
            • bradm
              • Jul 2014
              • 30
              Ive contacted a mod to do that. nothing yet...
              my bad...
              • bradm
                • Jul 2014
                • 30
                ok removed 3 white connectors, ground screws and jumpered sc50.
                still have the flashing green then the 7 red blinks.
                • tw2005
                  • Oct 2011
                  • 6458
                  Ok, so look like bad SC. Normally they fail with the SC2 pins going short cct.
                  Here's a guide you can use for this generation. In there you'll find a buffer board resistance test. As a quick check set the meter in continuity or diode test with buzzer/beep and put one probe on one of those gnd plates the bolts go through and then slide the other slowly across all the output connectors where the ribbons go.
                  you don't want to see anything shorted there, also in the table for resistance check for shorts and then also set meter to appropriate resistance range to check those values.
                  post all results and measurements.
                  on the SC check sc2 resistance and all the transistors and see if dead short across any 2 of the 3 pins. Q661 is a common one that shorts and transistors part numbers, DG502,DG402, 30F125 also commonly short.
                  post results.
                  • bradm
                    • Jul 2014
                    • 30
                    ok so ive got the sc card out on the bench now.
                    the sc2 pins are the power coming in? one short one fine, + and -
                    ok not sure if this is correct but getting shorts on
                    q662, q621, q642, q641 all 3 pins
                    D482, Q452 all 3
                    D401, D402 short on 2
                    D462, D422 short on 2
                    Q661 all 3
                    im seeing quite a few shorts where the ribon cable goes (sc20)
                    • tw2005
                      • Oct 2011
                      • 6458
                      D482, Q452 all 3
                      Q661 all 3
                      Ok, so you're using gnd and then testing pins. Not quite what I wanted but there's a couple of obvious ones there
                      Q661 all 3, D482, Q452 all 3
                      These will be ok, diodes with 2 legs being the same ref point
                      This info is confusing, some of these don't exist so I think you have the location numbers wrong.
                      SC2 i just wanted the probes put across them but sounds like not showing short which is why you got 7 blink. When this shorts causes PSU short and 4 blink, can be 10 blink.
                      At least that's a definite yes for SC board failure.
                      see if you can follow that guide for SD/SU resistance, should be able to do it with them installed.
                      • bradm
                        • Jul 2014
                        • 30
                        yep my bad..
                        Q622
                        Q621, next to q622 ?
                        D642
                        D641
                        all on the same heatsink as D422
                        ok, just trying to get my head around the resistance test reading again...
                        • tw2005
                          • Oct 2011
                          • 6458
                          example of some of the parts.
                          • bradm
                            • Jul 2014
                            • 30
                            SC41 2 914k
                            4 221k
                            8 no reading
                            SC42 1 1051k
                            2 221k
                            6 no reading
                            the ones with no reading would give a resistance then nothing...
                            • bradm
                              • Jul 2014
                              • 30
                              there are some pretty small components there!
                              would any of them need to be replaced?
                              • tw2005
                                • Oct 2011
                                • 6458
                                Was that tiny ribbon that connects the 2 boards disconnected?
                                Given your meter is not really good enough I'm going to say most likely they're ok.
                                first reading they say 2.2m but from memory I got 1.9m.
                                221k is good and the last is higher than your meter can handle so high resistance, no short which is good.
                                Usually you'll find shorts there if bad. i have to duck out for a bit but SC should get this going providing the panel is not cracked which only you can tell.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  yeah, what do you reckon. there's a reason i'm showing you these,
                                  • bradm
                                    • Jul 2014
                                    • 30
                                    yep the ribon was disconnected.
                                    no cracks that i can see...
                                    • bradm
                                      • Jul 2014
                                      • 30
                                      hehe uh oh, the c541 for example.
                                      is that soldered on top of the board or is it plug unplug?
                                      • bradm
                                        • Jul 2014
                                        • 30
                                        they are soldered. ive done quite a bit of soldering but nothing that small. would need a tiny tip and a steady hand
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
