sony kdl-32bx330 shorted out on frame?
  • ValleyEcycling
    • Aug 2013
    • 13
    • canada
    I have a Sony KDL-32bx330 that has just stopped working on me. It was manufactured in february 2012 and as far as I know has not had any power surges to note.
    TV stopped working part way through a movie (didn't hear any popping noises or crackling) it just turned off, when i turned it back on half the display (left) was a vertical rainbow pattern that dissipated from the center back out to the left side facing of the display. The backlight would then shut off then turn itself back on after a few seconds but with no display (not even menu options are visible). Before the backlight turned off then back on again the SONY logo was visible for about 2 seconds.
    I opened up the TV (out of warranty) to reseat the cable connections to the inverter board to ensure that wasn't the cause and I found that one of the bands connecting the panel to the board was burnt up! I have attached pictures below. Looking closer at it i have found that the metal piece holding the panel to the TV also had a lot of scorching and burn marks on it.
    Has anybody else encountered a problem like this? And should I be contacting SONY about this issue? I mean looking at things it doesn't look like I have any repair options available anymore. Any help on the cause and/or solution to this would be greatly appreciated.
  • R_J
    • 9624
    Re: sony kdl-32bx330 shorted out on frame?
    Is that board located at the bottom of the screen by chance?
    • tw2005
      • Oct 2011
      • 6458
      Have you ever used liquid to clean the screen and maybe it ran into that area causing it to corrode and short out?
      https://www.youtube.com/watch?v=yqcqDQFqZHo
      • R_J
        • 9624
        Thats what it looks like to me, water (or cleaning liquid) damage, that why I asked the location of the board.
        • ValleyEcycling
          • Aug 2013
          • 13
          • canada
          Thanks for the replies so far. Yes that board is located flat along the bottom of the TV so i suppose any liquid put on the screen could feasibly drip down onto the board and cause the short. I have only ever used LCD screen cleaning foaming sprays to clean this with, but I can't promise that somebody else didn't use water or liquid to clean without me knowing it. The bezel seal was still intact however, took a fair bit of delicate prying to get it to let go of the panel.
          Going to try cleaning the charred bits off today and will see what happens. I can see this short causing the issue of the rainbow display on screen, but would it cause the picture to go out as well after a few seconds or am i looking at a 2nd potential issue in the mainboard?
          • supravit2000
            Sony PS4 ADP400DR - help needed figuring out shorted pads under capacitor C 31
            by supravit2000
            Hi!
            A friend of mine gave me a dead PS5 to look at. I am totally inexperienced, but when a damage is simple (i.e. failed DAP41 on PS4s, etc.), when replacing just the IC and the other very common failing parts of these consoles, problem is fixed. So I checked the voltage of the PSU - none was present. Model is ADP 400DR. I have a bunch of spare parts around, so first thing I did was to replace the IC DAP 053 (they seem quite expensive, so I put a replacement unit - TEA2016AAT. When plugged to the power outlet, 12V did come present.
            So I reassembled the PS5 and pressed the power...
            07-20-2024, 07:26 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • Kemer
            Graphics Card mounting frame
            by Kemer
            Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
            As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
            I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
            What worries me right now is the possibility that...
            09-14-2024, 08:57 AM
