Philips 50pfp5332d/37 Bad Capacitors and Blown Traces.
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Just got this Philips plasma, said to have "turn on blue led light, but no picture". Thought -- Y-sustain and Y buffers. Plugged in the power cord, and saw a huge spark through the case and something blowing on the power supply. And Finally opened it up and here's what I found.
    Well first thing I tested the Y-sustain and Buffers. Buffers ohm out good, no shorts on either one. Tested the obvious FETs on the sustain, and no dead shorts either! So the Y boards seem to be good in this case.
    On to the power supply. No obvious burnt marking on the PSU at all... but there was a small burnt mark it left behind the panel where the main caps are. I desoldered both caps (450V 270uf) and sure enough both are bad and one is literally exploded from the bottom while burning the board. I also found one shorted diode next to those caps D8020.
    After cleaning up the burnt, the traces are obviously damaged. To fix this I wanted to make sure, my question is, were traces connected together?
  • selldoor
    Slow Learner
    • 7870
    Re: Philips 50pfp5332d/37 Bad Capacitors and Blown Traces.
    Well it looks like it - is it the neg side of a big cap so should be able to ohms test to the DC neg on the bridge rectifier
    • aidanmo
      Philips 43PUS7506/12 - Loud blown out sound
      by aidanmo
      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
      I thought maybe the speakers got damaged, so I replaced them - no dice.
      • Using the internal speakers, it always happens.
      • Using the headphone jack, it never happens.
      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
      02-28-2025, 03:13 PM
    • cmlewis89
      LG 47LB5DF blown power supply board
      by cmlewis89
      Hi folks,
      I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
      09-03-2024, 07:50 PM
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • gatto
      LG 50PC56 keep burn Buffers Boards
      by gatto
      Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
      I have this LG 50PC56 which not display image on screen
      I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
      When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
      My question it is: I disconnect...
      05-04-2022, 01:35 AM
