Quick Resistor Question (Sharp LC-32D43U)
+ More Options
Posts
  • saintlouis74
    • Dec 2013
    • 102
    I came across a Resistor that I can't identify, can anyone tell me the kind of resistor this is? and maybe a link to a replacement part... thanks
    Markings:
    6.8M Ohms
    M1WJ
    Re: Quick Resistor Question (Sharp LC-32D43U)
    Is one leg of the resistor connected to the chassis and another leg connected to Neutral? This is a safety resistor with very high value and high breakdown voltage, it is not needed for the circuit to function. So what is the problem with the unit you are working on? Make and model?
    BTW, those small blue caps are also safety cap (X/Y type).
    • saintlouis74
      • Dec 2013
      • 102
      Its a Sharp LC-32D43, with no power at all, i havent fully diagnose it, just popped the back off checked the fuse, then the resistor i questioned about had no reading, so i stopped to figure why it didnt
        Post good clear pictures of the back side pf the TV and whole picture of this power supply board. There should be big main filter cap in the primary side of the circuit, it should have about 165~170VDC right at the two legs of the cap.
        Was the TV hit by the surge or it just went out by itself?
        • saintlouis74
          • Dec 2013
          • 102
          thanks for the support
            OK, so the fuse did not blow, right? You need o get access to those two brown caps laying on their side to measure the DC Voltages at the two legs of each caps, just be real careful since you are working in the Primary (deadly side) of the circuit.
            • selldoor
              Slow Learner
              • 7870
              Hi Can you post a picture of the whole of the back of the tv.
              and one of the other side of the power supply. Also as we cant see them for the wires close ups of the connectors showing the pin assigment 5v 12v gnd and so on.
                I found good pictures provided by Shopjimmy, and the service manual.
                • saintlouis74
                  • Dec 2013
                  • 102
                  Fuse was not blown, both the big caps read 168.9 VDC... and the picture budm posted are identical to my board..... Only thing i know about the TV is that it was working one day, and tried to turn it on the next and it wouldnt
                  • selldoor
                    Slow Learner
                    • 7870
                    Ok - Can you try for a better picture of the back of your board if its still out.
                    Will help us spot bad joints.
                    If it is back together then testing secondary voltages on the connectors is next. Lodge the black probe of your meter on a ground screw then with the red probe test all the pins in the sockets. Set meter on 200vdc
                    List the results eg
                    GND ......gnd
                    5v......4.99v
                    on/off.... 3.2v and so on
                    • saintlouis74
                      • Dec 2013
                      • 102
                      sorry took so long to get back, but after probing all the pins got 0 Volt from every pin.. I did get 168vdc from the big caps, everything seems dead.. checked all the soldering joints they look good to me.
                      • saintlouis74
                        • Dec 2013
                        • 102
                        i dunno i missed it but i think i solved it, thanks to budm post
                        therdhttps://www.badcaps.net/forum/showthread.php?t=33077&highlight=Sharp+LC-32D42U
                        when part arrive i will post update on repair thanks
                        • saintlouis74
                          • Dec 2013
                          • 102
                          ok Diode was in bad shape, replaced that and found 2 resistor that was shorted out. i got them out and they are for sure blown... i just need guidance in finding a replacement part,
                          Markings:
                          F1J
                          FD774
                          0.12ohms
                          Location on Board:
                          R7933
                          R7626
                            OK, you have more problem. Those two resistors are Fusible resistors that will blow open circuit if the two power MOSFET Q7602, Q7603 are shorted out, you need to test and see if they have low resistance between S (Source) and D (Drain) pins, also the SMPS IC7603 may be also damaged. This is not good news for you.
                            • saintlouis74
                              • Dec 2013
                              • 102
                              MOSFET are goog from my knowledge,
                              i get 110 with red>source & black>drain
                              black>source & red>Drain i get 1
                              when i move Red>Gate then back to Drain i get a reading
                              As for IC7603 i followed :
                              https://www.badcaps.net/forum/showthread.php?t=27615
                              and i tested it and it seems ok also
                              • saintlouis74
                                • Dec 2013
                                • 102
                                Where can I order the Fusible Resistors from? link if possible thanks
                                  That is strange to have two blown fusible resistors in the same circuit.
                                  Digikey sells them but they are non-stock item.
                                  http://www.digikey.com/product-searc...0&pageSize=500
                                  • saintlouis74
                                    • Dec 2013
                                    • 102
                                    how many Watts is it suppose to be?
                                      It looks to be around 1W, you will have to take the measurement on the body and look at the link I gave you for Digikey to see which one matches what you have. Or look at the attached PDF.
                                      • saintlouis74
                                        • Dec 2013
                                        • 102
                                        ohhok thanks
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • chth96
                                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                          by chth96
                                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                          Since then, This AC/DC adaptor have been out of order.
                                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                          And Is there any possibility that it will suddenly explode as well as to be out...
                                          12-03-2023, 04:40 AM
