vizio E470VL unusual question
  • jgrice53
    • Dec 2012
    • 63
    • usa
    Re: vizio E470VL unusual question
    I think you may be right about the resistors, I will double check the bridge too and post my findings.
    • jgrice53
      • Dec 2012
      • 63
      • usa
      yes i think you are right.
      • jgrice53
        • Dec 2012
        • 63
        • usa
        R747 = RES. CF 0ohm 1/16W J 0402
        has anyone ever seen a 0 ohm resister? i have not
          • 30977
          regularly.
          they are used as fuses or to bridge across other tracks.
          sometimes even as option jumpers.
          • jgrice53
            • Dec 2012
            • 63
            • usa
            well that is what R747 is. i knew that it had to be a fuse or something like that.
            • jgrice53
              • Dec 2012
              • 63
              • usa
              #26
              oops ...
              R727 = RES. CF 1Kohm 1/16W J 0402
              • jgrice53
                • Dec 2012
                • 63
                • usa
                #27
                okay, finally got back to it. I cleaned up the solder bridges and now when I plug it in the logo goes from orange to white without pressing the power button. I still only have 5v standby. Is this an indication of a defective eprom?
                • jgrice53
                  • Dec 2012
                  • 63
                  • usa
                  #28
                  .time for an update. after cleaning up the bridged solder joints, i left r727 off and did not replace it because one side went straight to the HDMI chip that I removed. I ordered an eprom and replaced that and still had only 5v with orange logo. so i either should have installed another r727 chip or the main board had other problems. So i found a replacement on ebay for $65 with free shipping It came in today and i intalled it and the tv came right on and is working great.
                  • Bugman1400
                    Vizio E470VL got +5VSB, but no 12V
                    by Bugman1400
                    EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
                    +5VSB= +5.09
                    12V= +12.18
                    PS_ON= +2.25
                    I_ON/OFF= +3.27
                    LAMP= +3.18
                    DIM= +2.97
                    Any more testing I can do on Main board or is it just a replacement?...
                    09-04-2022, 09:19 AM
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    Yesterday, 07:28 PM
                  • dholley
                    Vizio TV E470VL SMPS Flucuation Output Voltage
                    by dholley
                    Would someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
                    1. The 3 main filter caps all have approximately 167 volts steady
                    2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
                    3. I have replaced Fuse F102 with an equivalent
                    4. I have check all diodes and caps and they seem to be ok
                    5. I replaced the 431...
                    01-20-2022, 03:12 PM
