Sanyo CE42FD90-B new PSU Board Confusion
  • immolation
    • Jul 2014
    • 7
    Hi There,
    The above set of mine was working fine until recently when it wouldn't come on or the blue light just flashed. I was advised to buy a new powerboard namely a 17pw26-4 v1.0.
    I received it today and it has an extra power socket on it, my previous one which has a servere case of swollen caps only had the white connector to plug the power connector in.
    This new board also has a black one, when i connect the board up i get nothing, is this because of the black connector (it has nothing attached and is marked PL815!)
    if so, how do i get round this problem, i cannot solder the board has im pretty useless at that.
    Can I short the 2 pins?
    Any advice is gratefully received as I'm currently without a TV until i solve the problem.
  • immolation
    • Jul 2014
    • 7
    Re: Sanyo CE42FD90-B new PSU Board Confusion
    Can anyone help me please?
    Im new to this TV fixing thing and i dont want to cause any damage to the tv.
    Thank you
    Neil
      Can you supply a picture of the top and bottom of your old and new power board. In your case I think one of the connectors needs to be jumpered for it to work but that is all. Most 17PW26-4s are interchangeable.
      • selldoor
        Slow Learner
        • 7870
        Hi - This will be a Vestel board and they rarely seem to produce 2 boards alike
        even when they have the same part number.
        We will need good clear pictures of both sides of the 2 boards.
        If you do not to do any soldering/unsoldering it is probable that we cannot help you. - If you search that board number you will see that there are repair kits readily available which is an indication that the often break down.
        Do you have a multimeter
        • immolation
          • Jul 2014
          • 7
          Thanks for the response
          I have attached pictures, the new board is the yellow coloured one, as you can see from the pictures the new board has a second black power socket (PL815).
          Does PL815 have to be jumpered in order for the board to work?
          if so, can it be done without soldering or by another means.
          the boards seem identical besides this extra PL815 2 pin socket.
          Thanks again
          Neil
            You do need to solder. The connector pins of PL815 need to be joined together. I suppose it would be possible without soldering but I would be cautious with something like wire wrap. It could overheat and start a fire (unlikely but it's still mains voltage so it's good to be cautious)
            • immolation
              • Jul 2014
              • 7
              Thanks tom66
              So if i just solder a piece of wire across the two pins on the black plug, it will work fine?
              Thanks Again
              Neil
                Yes. You should put it on the bottom of the board though.
                • immolation
                  • Jul 2014
                  • 7
                  Thanks Tom66
                  Worked a treat
                  Neil
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • k-krzych
                    Identify board to board connector
                    by k-krzych
                    Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
                    07-08-2025, 12:32 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
