anyone have a source for the 10 amp 300 volt diodes Samsung uses in their power supplies? they are to220 case isolated tab common cathode and common anode. I need one of each and their numbers cross to nothing. I have repaired this set twice using common switching diodes, they just don't last long. they go in a pn50a550.
10 amp 300v diodes
Re: 10 amp 300v diodes
I believe Tom advised in your last post on theis set that Digikey have some or at least one
http://www.digikey.com/product-detai...WGI-ND/1147822
Did you check that out?Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Mouser has ON Semiconductor Ultrafast 600V 10Amp diodes that would work. If the 300v are always failing up the voltage rating
http://www.mouser.com/ProductDetail/...kJxUsojjzf4%3dLast edited by Ltank; 07-14-2014, 09:41 AM.Comment
selldoor, yes I did and I bought the one type 10 of them. the other one fru10uc30 I cant find anything to replace it other than taking 2 singles and butting them with a jumper. and its not a voltage problem really its more heat related. just no where to get a fan close enough to the heatsink rail to do any good.Comment
Those both appear to be common CATHODE types the one he is struggling to find is common ANODE typePlease upload pictures using attachment function when ask for help on the repair
thanks selldoor, the only place I found is a china source which is probally not worth trying. guess I will continue with the fast switching diode, this time I mad a mount from brass where I could at least heatsink these. tha common anode I have 8 more of but when the common cathode goes it takes out one side of the common anode. I have repaired it twice now. Samsung dosent even have them and when they did they were 27.00 us a pop.Comment
I thought you said the other way round ? you have a supply of common CATHODE
from digikey?Please upload pictures using attachment function when ask for help on the repair
yes, I have it backwards, I got distracted by my wife.
steve the plain diodes I have been using to make the dual from have no tab the originals do. I made what I have by back to back switching diodes. common anodes I have I need the common cathodes. with the homemade heatsink these may last a bit longer. thanks for trying to help .Comment
Last edited by selldoor; 07-17-2014, 02:32 AM.Please upload pictures using attachment function when ask for help on the repair
by DvsrHi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
After replacing the caps I started testing out the speaker. It seemed...4 Photos-
09-10-2025, 10:20 AM -
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
by japlyticWith 7 segment LED displays, are common cathode units more common than common anode units?
From what I see, common cathode units have simpler drive circuitry. -
by magistertcThis problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
configured to support the RTC and some volatile RAM (when SMPS is on). What you may...-
Channel: BIOS Requests ONLY!
by madan1Good day.
I'm currently on a vacation and a friend from the camp site asked me to check why his camper power supply does not charge the batteries when hooked to the mains.
The PSU is cramer and from what I've found the same mainboard is used in both cbc-b7 and bcc-b7. The control module/interface panel is Cramer D-5750.
So what I've found so far - the transformer seems to be working fine and the board has no visually damaged components. I tested most of the diodes and transistors with a multimeter (the only tool I got here) and they read fine.
The two thyristors have been... - Loading...
