10 amp 300v diodes
  • awyatt2
    • Feb 2012
    • 407
    • america
    10 amp 300v diodes
    anyone have a source for the 10 amp 300 volt diodes Samsung uses in their power supplies? they are to220 case isolated tab common cathode and common anode. I need one of each and their numbers cross to nothing. I have repaired this set twice using common switching diodes, they just don't last long. they go in a pn50a550.
    Re: 10 amp 300v diodes
    What's the part #?
    • awyatt2
      • Feb 2012
      • 407
      • america
      part numbers are fcu10uc30 and fru10uc30. one is common anode other common cathode. I have the set running again but its only a matter of months
      • selldoor
        Slow Learner
        • 7870
        I believe Tom advised in your last post on theis set that Digikey have some or at least one
        http://www.digikey.com/product-detai...WGI-ND/1147822
        Did you check that out?
        • Ltank
          • Jun 2013
          • 776
          Mouser has ON Semiconductor Ultrafast 600V 10Amp diodes that would work. If the 300v are always failing up the voltage rating
          http://www.mouser.com/ProductDetail/...kJxUsojjzf4%3d
          • Ltank
            • Jun 2013
            • 776
            Sorry I was thinking single ened not dual diodes.
            • awyatt2
              • Feb 2012
              • 407
              • america
              selldoor, yes I did and I bought the one type 10 of them. the other one fru10uc30 I cant find anything to replace it other than taking 2 singles and butting them with a jumper. and its not a voltage problem really its more heat related. just no where to get a fan close enough to the heatsink rail to do any good.
              • flocko
                • Nov 2012
                • 1121
                Try these FFPF20UP60DN and RFU20 TM5S the first one i have used for Samsung Powerboard and Sus board repairs the second are used on a lot of Panisonic/ Samsung/LG boards hope this is of some use Flocko
                • selldoor
                  Slow Learner
                  • 7870
                  Those both appear to be common CATHODE types the one he is struggling to find is common ANODE type
                  • awyatt2
                    • Feb 2012
                    • 407
                    • america
                    thanks selldoor, the only place I found is a china source which is probally not worth trying. guess I will continue with the fast switching diode, this time I mad a mount from brass where I could at least heatsink these. tha common anode I have 8 more of but when the common cathode goes it takes out one side of the common anode. I have repaired it twice now. Samsung dosent even have them and when they did they were 27.00 us a pop.
                    • selldoor
                      Slow Learner
                      • 7870
                      I thought you said the other way round ? you have a supply of common CATHODE
                      from digikey?
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        I'm confused. The diode tabs were not attached to a heatsink?
                        • awyatt2
                          • Feb 2012
                          • 407
                          • america
                          yes, I have it backwards, I got distracted by my wife.
                          steve the plain diodes I have been using to make the dual from have no tab the originals do. I made what I have by back to back switching diodes. common anodes I have I need the common cathodes. with the homemade heatsink these may last a bit longer. thanks for trying to help .
                          • selldoor
                            Slow Learner
                            • 7870
                            Originally posted by awyatt2
                            common anodes I have I need the common cathodes. .
                            Still dont think you have got that right? common cathode ones are at digikey?
                            • tonydix
                              • Dec 2013
                              • 31
                              • Panama
                              did you ever source these two diodes ?
                              • Dvsr
                                On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                by Dvsr
                                Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                After replacing the caps I started testing out the speaker. It seemed...
                                09-10-2025, 10:20 AM
                              • caspian
                                What Zener Diodes on a Linear Power Supply
                                by caspian
                                Dear members,
                                I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                In addition, I discovered that its zener diodes are defective.
                                I can replace the burned transistors.
                                But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                Therefore, I cannot replace the zener diodes.
                                I do not want to test the zener diodes in a test circuit to discover their model or value.
                                no schematics are available...
                                05-26-2025, 12:38 PM
                              • japlytic
                                7 segment LED displays: Common cathode vs. common anode
                                by japlytic
                                With 7 segment LED displays, are common cathode units more common than common anode units?
                                From what I see, common cathode units have simpler drive circuitry.
                                10-29-2019, 06:55 PM
                              • magistertc
                                CMOS battery drains quickly
                                by magistertc
                                This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                                as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                                Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                                Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                                configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                                07-06-2024, 09:55 AM
                              • madan1
                                Troubleshooting Cramer RV power supply
                                by madan1
                                Good day.
                                I'm currently on a vacation and a friend from the camp site asked me to check why his camper power supply does not charge the batteries when hooked to the mains.
                                The PSU is cramer and from what I've found the same mainboard is used in both cbc-b7 and bcc-b7. The control module/interface panel is Cramer D-5750.
                                So what I've found so far - the transformer seems to be working fine and the board has no visually damaged components. I tested most of the diodes and transistors with a multimeter (the only tool I got here) and they read fine.
                                The two thyristors have been...
                                07-12-2025, 11:44 AM
