42PFL7422D/37 Philips Screen Flicker issues
  • deaner00
    • Jul 2014
    • 6
    Hello - I read (or tried to at least) through all the forums for my tv. My set had gone out a while back. After reading through the posts, I decided to replace the inverters. It seemed they were the cause of most problems with this model number. I replaced those this morning. Screen comes back on and has been on for about an hour and a half now. That's all good. The problem now is that the screen flickers. It's especially noticeable and hard on the eyes when viewing light colors like the blue/white Philips menu screen. Also, the over all brightness of the screen seems low and the lower half of the screen is darker than the top. I tried to capture this in a video:
    http://youtu.be/VoMO3CEjCZg
    Any help or suggestions would be greatly appreciated.
    • 31191
    Re: 42PFL7422D/37 Philips Screen Flicker issues
    probably the tubes or tube connections.
    and that probably took out the oringinal invertor circuit.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Did it flicker before it "went out"
      Try turning the brightness down a bit.
      Try a factory reset.
      • deaner00
        • Jul 2014
        • 6
        Hello selldoor - It did not flicker before it went out. The flicker is still present with the brightness all the way down. I've tried quite a few different combinations in the tv settings, but nothing seems to work. I will try a factory reset next.
        • deaner00
          • Jul 2014
          • 6
          Thanks for the reply stj - Is there a way to test/fix the the tubes or tube connections?
          • deaner00
            • Jul 2014
            • 6
            Still the same flicker and lower half darkness after factory reset. Anything I can test?
              • 31191
              if you disconnect the panel from the main board, it may stay on without a picture.
              if it does, does the backlight still flicker?
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Yes but its not easy - there are videos on youtube of changing bulbs and
                several accounts in this forum.
                You can also make up test bulbs from cfls 13w or less see posts by budm
                - link in his signature.
                Please post pictures of the inverters ( were they new or just pulls)
                and (if there is one on this set- cant remember) the distribution board that the cables from the inverters go to.
                • -goodtimes-
                  • Apr 2014
                  • 15
                  I have the same thing happening. My picture went out. I replaced the inverter boards with NEW alternative boards (confirmed compatible replacements). Picture is back with the same exact symptoms as the OP stated. I am considering having ShopJimmy rebuild my original boards, but I am not sure the problem is with the boards as they were brand new. The flicker was definitely not there before I lost my picture. I did notice that if I turn the contrast all the way up to 100 it almost goes away, but the picture does not look so great that way.
                  • jkruns
                    M1 A2338 screen and touchbar issues after cleaning up liquid damage
                    by jkruns
                    This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                    My patient is an A2338 Macbook Pro M1 (late 2020).
                    It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                    04-22-2024, 06:45 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • aazjo
                    A1502 screen only issues
                    by aazjo
                    I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
                    I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
                    1 PPVOUT_SO_LCDBKLT OL
                    3 I2C_BKLT_SCL 9.97M
                    4 I2C_BKLT_SDA 9.89M
                    5 PP3V3_S0_EDP_R 79.10k
                    6 SMBUS_SMC_0_S0_SCL 321k
                    7 SMBUS_SMC_0_S0_SDA 323k
                    8 EDP_BKLT_PWM ...
                    11-04-2021, 11:46 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
