Sony KD - 75XF8596
  • domix
    • Jan 2014
    • 168
    • Slovenia
    Sony KD - 75XF8596
    i have this tv. Now i dont have image only backlight.
    when i turn it on backlight turn on and white led. After a few secodns i get red led blinking 5 times.
    is any common issue, for sony bravia. Panel, board? Before i unmount it from the wall and open it up.
    thanks
  • lotas
    • Jan 2016
    • 4753
    • Russia
    Code error 5
    • Diah
      • Feb 2013
      • 6437
      post high resolution photos of yours TV T-CON with out heat sink.
      • domix
        • Jan 2014
        • 168
        • Slovenia
        Here is the photo. i take the tv it from the wall.
        when i unplug right flat cable (mark it on the image) from T-con i get half screen white. When plug it back and unplug left one. I get 5 blinking red.
        • Diah
          • Feb 2013
          • 6437
          the side with blinking error have short... show us the panel buffer boards of this side, also you will have on this side U ribbon cable at the middle of boards disconnect it and see if you get 3/4 Image on screen
          • domix
            • Jan 2014
            • 168
            • Slovenia
            I have dissconnected it in the middle. I have second 1/4 of screen withe. Here are photos.
            • Diah
              • Feb 2013
              • 6437
              my questions if you see image on the reset of the screen.... or you can hear sound... this is more important that the white you are talking on
              • domix
                • Jan 2014
                • 168
                • Slovenia
                No i dont have sound and no image. I have backlight and 1/2 screen is withe, i i sepparater UCable modules i have only 1/4 screen withe color and 3/4 screen is only backlight. Where is supposed to be image is only bright withe.
                • domix
                  • Jan 2014
                  • 168
                  • Slovenia
                  Should i replace which board?
                  • domix
                    • Jan 2014
                    • 168
                    • Slovenia
                    Anyone?
                    • domix
                      • Jan 2014
                      • 168
                      • Slovenia
                      I get new t-con board. I replace it, and when turn the tv on it turn on only backlight whitout 5 times blinking red.
                      so the problem is almost the same just like wiht orginal t-con board.
                      i didnt get any android sound. If i disconnect u cable from t-con to buffer board. I only get half of screen white color and nothing other on screen.
                      any other solution to check?
                      thanks
                      • tiki66
                        • Jul 2016
                        • 54
                        • Croatia
                        Your panel is bad, it's shorted. You can try "tape fix" eventually, find it on youtube.
                        • domix
                          • Jan 2014
                          • 168
                          • Slovenia
                          Yes i search at net for bloking signals with tape ot paper, but didnt find this model.
                          which pins should i to mask on ribbons cable?
                          • bohaboha
                            • Nov 2012
                            • 1017
                            • sweden
                            start by masking on the right contact of the T-con to the screen just 4 pins at the time from left to right or on the U ribbon on buffer board same way if not ok just go on and search even by pin
                            • domix
                              • Jan 2014
                              • 168
                              • Slovenia
                              I taped al 10 CLK pins, image is like as it should be. Every thing works
                              should inleave it so? Or i will need to find if only one or two pins is making problems? It will be okey if i leave it masked all 10 clk pins?
                              • bohaboha
                                • Nov 2012
                                • 1017
                                • sweden
                                then just leave it that way if you are satisfied some pics does not hurt
                                • domix
                                  • Jan 2014
                                  • 168
                                  • Slovenia
                                  Okey. I will leave it that way. Image is okey.
                                  thanks
                                  • androripara
                                    Sony Bravia 55HX820 - 4 times blinking red standby led
                                    by androripara
                                    i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                    I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                    Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                    10-19-2023, 05:16 AM
                                  • gkolio
                                    Sony Bravia 55w905a - 4 Red LEDs Blinking then Pink Tint
                                    by gkolio
                                    Hi have problem with 4 reds blink take lot help that forum and tell me change led strips and all going very good tv alive now but in down left have pink tint little and see only in white pages what wrong doing?
                                    12-01-2023, 09:09 PM
                                  • YasaCh
                                    Sony kdl 40p5500 red light keeps blinking 3 times
                                    by YasaCh
                                    Hello...
                                    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                    i opened the back cover no sign of damage on the powery suply or motherboard
                                    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                    07-07-2025, 11:53 AM
                                  • PopsCaps
                                    Sony Bravia KDL-40V2500 that will not power on
                                    by PopsCaps
                                    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                    I do not hear any sound and I cannot see any backlight.
                                    I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                    03-25-2025, 11:23 AM
                                  • shahnld
                                    Sony kdl 65xg9505 green amber blinking
                                    by shahnld
                                    Good Day.
                                    I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                    i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                    green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                    01-03-2024, 03:05 PM
