bad screen or control board
+ More Options
Posts
  • finntricky
    • Jan 2014
    • 449
    toshiba 32 inch LCD
    thought it would be easy fix, thought it would be t-con, how wrong was i,
    this goes form perfect to bad in less than a 60 seconds
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: bad screen or control board
    Looks like a bad panel to me, I assume you already tried putting pressure to the tab bonds with no luck?
    • finntricky
      • Jan 2014
      • 449
      oh yes
      • Yanleb
        LG 60PK550 Logic Control Board EBR63450301
        by Yanleb
        Hi all, I just want to share the repair of my 60PK550-UA TV set.
        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
        C57: 3.30V
        C61:...
        07-20-2023, 12:38 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
        Linear Garage Door Opener Control board took a crap install a new control board back normal
        by sam_sam_sam
        I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
        02-08-2025, 06:52 AM
      • maxim2511
        LG 55EC930V OLED - swich on swich of no screen
        by maxim2511
        My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
        Then I get an idea to take it apart and clean boards from dust.
        In side of Tv was not so bad, I take compressed air in can, and gently blow up.
        Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
        05-14-2021, 02:21 AM
