Vizio XVT3D650SV - Help
+ More Options
Posts
  • bammbammfran
    • Apr 2014
    • 476
    Re: Vizio XVT3D650SV - Help
    As I mentioned, your voltage regulators should have a ground pin so you should not get voltage on all 3 pins and of course they should not be almost the same voltage.
    You can confirm the ground with an ohm meter.
    on the voltage regulators
    If you look at them with the largest tab to the left
    On the 1117 adjustable smaller one top pin would be input, center pin and large tab would be output and the lower pin would be ground
    On the larger one, the top pin would be output, the center pin and large tab would be Ground and the lower pin would be input
    While you are retesting the 2 voltage regulators.
    I would remove the wire from the pin 13 out of the 16 pin plug at the power board side and check that wire separately for voltage and then check the actual pin of the power supply too
    To remove the wire, lift slightly on the white tab of the plug at that pin with something pointy and then slide the wire out
    also check pin 1 on one of the larger connectors for voltage at dim-pwm-signal
    • newpey
      • Sep 2013
      • 38
      • usa
      #42
      OK, my board looks a little different from your picture. Please see picture
      R310A: -5.17 on both sides
      A: -5.23
      B: -5.23
      C: 0
      D: 0
      • newpey
        • Sep 2013
        • 38
        • usa
        #43
        OK, I started testing away. THEN I noticed the ground pin is burned through on one of the voltage regulators on the main board when I was testing ohms
        I checked the fuses around it and they all seem to be working fine.
        Writing on it is: 7805CG RKA07. Do I just order one and replace it? IS there an actual part number? Could anything else be messed up from this guy?
        Also, I am really unsure how to test the voltage regulators correctly. If I use the ground wire from the 16 pin plug OR if I use the metal on the TV, my dcv appear to be about the same on all pins and tab. I would like to understand how to correctly test these.
        I am excited to see an actual issue!
        • newpey
          • Sep 2013
          • 38
          • usa
          #44
          I just read https://www.badcaps.net/forum/showthread.php?t=22231 Great thread! Now I understand how to test them.
          How do I find the part number / replacement for the voltage regulator in question? I can't find that info anywhere
          • bammbammfran
            • Apr 2014
            • 476
            Do Not get too excited yet ! That center pin is not supposed to reach the board like the other 2 pins do
            So if you think that is what is wrong ?? Sorry !!
            • newpey
              • Sep 2013
              • 38
              • usa
              #46
              Well then back at it!
              Tested the wires and pins from main board and on power board:
              1 0
              2 0
              3 0
              4 0
              5 -5.18
              6 -5.18
              7 -5.18
              8 -5.18
              9 -5.18
              10 -5.18
              11 -5.18
              12 -5.18
              13 -5.14
              14 -5.13
              15 0
              16 -5.13
              5 volt fuse -5.13 on both sides
              12 volt fuse 0.02 on one side and 0 on the other
              On the 2 voltage regulators, regardless of how I ground the black probe, I see the same or very similar volts across the pins minus ground.
                The regulator 7805 5V regulator is not going to show any input (12V) voltage because you do not have the 12V output from the power supply since the 12V/24V power supply is not working right now.
                You should download that datasheet and look at the pinout of the 1117.
                  A: -5.23
                  B: -5.23
                  C: 0
                  D: 0
                  What do you use for the black probe? Is the reading showing minus 5.23V (-5.23) reading?
                  "R310A: -5.17 on both sides" that will indicate open Base-Emitter junction of that transistor, unless I am wrong, the Emitter is connected to Ground from what I can see on the traces of the board.
                  • newpey
                    • Sep 2013
                    • 38
                    • usa
                    #49
                    Yes it shows minus.. I have the meter set to 20DCV I dont understand what that means as it is not possible to have negative volts?
                    I either put the black probe on pin 1 for ground or use the chassis.
                    • newpey
                      • Sep 2013
                      • 38
                      • usa
                      #50
                      Gotcha. That makes sense
                      • bammbammfran
                        • Apr 2014
                        • 476
                        1 0
                        2 0
                        3 0
                        4 0
                        5 -5.18
                        6 -5.18
                        7 -5.18
                        8 -5.18
                        9 -5.18
                        10 -5.18
                        11 -5.18
                        12 -5.18
                        13 -5.14
                        14 -5.13
                        15 0
                        16 -5.13
                        Well, I don't know how to say it but, this looks all wrong
                        1through4 should be +5
                        5-9 should be grounds
                        10-12 should be 12 but may show zero
                        and on the voltage regulators are you still saying that all the pins are showing 5 volts ??
                        are the batteries in your tester good ?
                        Maybe you have the red and black lead plugged into the tester backwards ?
                        what do the pins at the power supply show with the main board wire disconnected ?
                        • newpey
                          • Sep 2013
                          • 38
                          • usa
                          #52
                          The probe wires are soldered on to the meter. Battery is fine as well. If I am reading the pins correctly then they go like this..
                          back side
                          16, 14, 12, 10, 8, 6, 4, 2
                          front of plug that is facing me
                          15, 13, 11, 9, 7, 5, 3, 1
                            Can you show us the meter?
                            • bammbammfran
                              • Apr 2014
                              • 476
                              back side
                              JUST TO MAKE SURE
                              See the picture
                              ALSO, please check these with the plug from the main board unplugged
                              USE GREEN marked pins for black probe of the tester
                                I think we are are doing wild goose chase with all these wrong readings. The only correct reading is the one on the main filter cap that shows around 160VDC.
                                • newpey
                                  • Sep 2013
                                  • 38
                                  • usa
                                  #56
                                  I am going to get a new tester this morning. Maybe it is the issue. I will post all new readings one I get it.
                                  • newpey
                                    • Sep 2013
                                    • 38
                                    • usa
                                    #57
                                    OK the multimeter I had was defiantly NOT matching the new one. Now maybe we can actually get somewhere! Sorry about that guys!!
                                    Here are the readings:
                                    Power board plug
                                    1 5.1-5.3
                                    2 5.1-5.3
                                    3 5.1-5.3
                                    4 5.1-5.3
                                    5 0
                                    6 0
                                    7 0
                                    8 0
                                    9 0
                                    10 0
                                    11 0
                                    12 0
                                    13 0
                                    14 0
                                    15 0
                                    16 0
                                    caps on power board:
                                    C951A 5.22
                                    C951B 5.22
                                    C951C 5.22
                                    C800A 77.7
                                    C800B 77.7
                                    C800C 77.7
                                    Main board
                                    Fuses
                                    F3 5.1
                                    F1 0
                                    Voltage Regulators
                                    U8
                                    in 0
                                    out 0
                                    gnd 0
                                    tab 0
                                    U38
                                    in 0
                                    out 0
                                    gnd 0
                                    tab 0
                                    • bammbammfran
                                      • Apr 2014
                                      • 476
                                      ok
                                      That is better
                                      Now you can recheck pin 13 that budm wanted to see the value of when powered on and off and connected to the main board
                                      also check it at the power supply with wires to cn202 disconnected
                                      • newpey
                                        • Sep 2013
                                        • 38
                                        • usa
                                        #59
                                        No change on pin 13 when pushing the power button with cn202 connected or disconnected
                                        • newpey
                                          • Sep 2013
                                          • 38
                                          • usa
                                          #60
                                          The TV *normally* goes through a boot up stage when you first plug it in. During that time the vizio logo lights up orange then proceeds to flash orange and white. Once it is complete the logo go back to orange and the power button becomes enabled and you can turn on the TV.
                                          I am guessing the power button will not change the voltage as the tv is not "booted up".
                                          I am not sure I just know that it used to take 1-2 minutes before the power button worked
