Vizio XVT3D650SV - Help
  • newpey
    replied
    Re: Vizio XVT3D650SV - Help
    I will order a main board then! Thanks for all the help guys!
  • bammbammfran
    replied
    well, the controller chip (whichever one it might be) is getting 5 volts and turning it to 3.3 and trying to turn on, but isn't
    It may be the chip under the one heatsink ? or could be somewhere else and trring to figure it out could be rough.
    you would first have to try to figure out where the power button 3.3 volts is coming from to have any clue where to start. even if you find that chip, it could be something else stopping it !
  • newpey
    replied
    Hah figures!
    Both are the same. I just just tested pins 1-16 on main board and power board. Pushing the button doesnt change anything
  • bammbammfran
    replied
    well. I was hoping for an easy fix like a bad button, BUT, NOT !
    do both power supplies give the same results voltage wise?
    Did you recheck pin 13 and pin 14 & 16 to see if they show any signs of a voltage rise wile you push the power button (I think you checked 13 but not sure if you check 14 or 16)
  • newpey
    replied
    I have 1 pin that has power 3.3v on both sides of ribbon. When power button is pushed it drops off to 0 on both sides
  • bammbammfran
    replied
    OK
    I figure it might be multifunction
    check for voltage at the 8 pin plug at the main board side (I think it is a J7 plug)
    Then recheck the voltages at the power button end to make sure they are the same.
    If you find voltage on a pin
    Hold the tester in place so that you can see if the voltage drops when you push the power button. If you have several pins with voltage, keep check them to see if one drops
  • newpey
    replied
    The group of picutes "Round 2" IMG_20140703_133842.jpg is the power switch board. The power switch pushing in to turn on/off. If also rotates to interact with the menus
  • bammbammfran
    replied
    On post 2 with your first set of pictures: Is that the power button shown on the second to last picture ? is it the bottom one in the picture with the 8 pin connector ?
    If it is, does it rotate or push to turn on and off and does it normally do any other functions ?
  • newpey
    replied
    OK, so the main board is not sending the PS_ON signal, so main board is the problem right now.
    Are you saying I should just order a main board from vizio? I would like to try to find the root cause as I can solder. A new main board will cost me around $150 (which may be ok but I need to fully know it is a main board issue cause I'm already -$100 on a new power board that didnt solve it).
    I would scrape the tv but I spent a lot on it and barely had the money at the time to buy it and dont have the money now to replace it
    replied
  • newpey
    replied
    OK so no matter which combination (plug in, pushing power button or plug disconnected) it always stays at 0
  • bammbammfran
    replied
    Originally posted by newpey View Post
    No change on pin 13 when pushing the power button with cn202 connected or disconnected
    Now that we can get a good voltage:
    so, is pin 13 showing voltage even if the main board is disconnected from the plug ? and is it still showing 5 volts ?
    OR
    Is it showing no voltages ?
  • newpey
    replied
    The TV *normally* goes through a boot up stage when you first plug it in. During that time the vizio logo lights up orange then proceeds to flash orange and white. Once it is complete the logo go back to orange and the power button becomes enabled and you can turn on the TV.
    I am guessing the power button will not change the voltage as the tv is not "booted up".
    I am not sure I just know that it used to take 1-2 minutes before the power button worked
  • newpey
    replied
  • bammbammfran
    replied
    ok
    That is better
    Now you can recheck pin 13 that budm wanted to see the value of when powered on and off and connected to the main board
    also check it at the power supply with wires to cn202 disconnected
  • newpey
    replied
    OK the multimeter I had was defiantly NOT matching the new one. Now maybe we can actually get somewhere! Sorry about that guys!!
    Here are the readings:
    Power board plug
    1 5.1-5.3
    2 5.1-5.3
    3 5.1-5.3
    4 5.1-5.3
    5 0
    6 0
    7 0
    8 0
    9 0
    10 0
    11 0
    12 0
    13 0
    14 0
    15 0
    16 0
    caps on power board:
    C951A 5.22
    C951B 5.22
    C951C 5.22
    C800A 77.7
    C800B 77.7
    C800C 77.7
    Main board
    Fuses
    F3 5.1
    F1 0
    Voltage Regulators
    U8
    in 0
    out 0
    gnd 0
    tab 0
    U38
    in 0
    out 0
    gnd 0
    tab 0
  • newpey
    replied
    I think we are are doing wild goose chase with all these wrong readings. The only correct reading is the one on the main filter cap that shows around 160VDC.
    I am going to get a new tester this morning. Maybe it is the issue. I will post all new readings one I get it.
    replied
  • bammbammfran
    replied
    The probe wires are soldered on to the meter. Battery is fine as well. If I am reading the pins correctly then they go like this..
    back side
    16, 14, 12, 10, 8, 6, 4, 2
    front of plug that is facing me
    15, 13, 11, 9, 7, 5, 3, 1
    JUST TO MAKE SURE
    See the picture
    ALSO, please check these with the plug from the main board unplugged
    USE GREEN marked pins for black probe of the tester
    replied
    Can you show us the meter?
