Vizio M420SV Razor LED Smart TV 120hz
  • Shinju
    • Mar 2014
    • 1239
    Hey all!
    I probably know the answer to this but I am going to ask anyway.
    I got this in a bundle lot of panels and when you turn the unit on it comes on the LED lights up and the screen is illuminated, I have audio on all inputs.
    NOW for the problem, when I unplug the left LVDS cable to the panel the left side goes white and the right side displays a picture.
    Now if I plug back in the left LVDS and unplug the right LVDS nothing changes in fact the right side doesn't even go white it stay's blank (all this time audio is present)
    So this could be one of 3 things and I am pretty sure its a bad panel, but could it be a bad mainboard or possible bad LVDS cable?
    I was able to get enough gap between the panel shield and a plastic barrier that hides the bottom tab bonds that I could see and I ran a toothpick over them and nothing changed.
    Re: Vizio M420SV Razor LED Smart TV 120hz
    Have you tried both lvds in but one panel ribbon at a time out?
    • Shinju
      • Mar 2014
      • 1239
      When both are plugged in the screen is lit up but no picture, I don't remember if I did unplug both and turned it on. I can do that tonight.
      Even if its toast it was worth it for the Samsung FP-T5084X/XAA that I got with this and one other Sammy LCD in tow.
      • Shinju
        • Mar 2014
        • 1239
        Tom, I unplugged both cables and the screen was blank, no white like the one side being disconnected.
          My guess is a bad panel.
          • Shinju
            • Mar 2014
            • 1239
            Closing this up.
            This is a dead panel and a victim of Windex, I took the bezel off the screen and the left side TFT buffer board were the tab bonds attached was so corroded by windex/moisture the SMD parts fell off.
            Dead panel! DONT SPRAY your panel with cleaner!
            After cleaning off the corrosion the panel is now shutting down after a few seconds. Not sure if I want to risk selling the power supply/mainboard ect.
            • SS454
              vizio e650i-a2 backlight flashes then turns off
              by SS454
              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
              panel: au optronics T650HVN05.4
              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
              https://www.shopjimmy.com/vizio-56-0...-power-supply/
              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
              08-20-2020, 03:57 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • NolesFan
              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
              by NolesFan
              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
              10-24-2024, 06:36 PM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
