Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
    • 12196
    • U.S.
    I see, somehow I thought that you had already tested all the resistors and diodes, hopefully that's all that's wrong. If that bridge rec. tested ok in circuit, no need to change it.
      • 12196
      • U.S.
      Check Q901, make sure none of the 3 pins are shorted to any of the others.
      • cajoeg
        TV_Newbie
        • Feb 2025
        • 22
        I was about to test all of the capacitors, but while watching the video on testing the bridge rectifier, that other video listed on the right side of the YouTube screen caught my eye.
        No short at Q901. I will put the good bridge rectifier back in since my new ones will not arrive until just before mid-March. The new resistors are expected to arrive on 2/20/2025.
        Thanks for the tips!
        Joe
        • cajoeg
          TV_Newbie
          • Feb 2025
          • 22
          Long story short, I got the new part in, and it also has continuity even before I installed it. I tried it anyways, and the LED quit working all together. So I put the old part back, and the LED came back. So I'm back to where I was before. I have not replaced the bridge rectifier.
          In watching other power board repair videos, one mentioned the optocoupler and its role. So I looked up a video on how to test a optocoupler, and found this one:
          https://www.youtube.com/watch?v=g7ZVk78MR7k
          Per the video, putting the multimeter in diode mode, placing the red probe on pin 1 and the black probe on pin 2 should read about 1000. I get 851. If you reverse the probes, you should get nothing. I get 1015. Then when testing with the black probe on pin 4 and the red probe on pin 3, you should get nothing. I get 823.
          I don't know if this is a valid test given the location of the component. But if it is, it implies that the optocoupler is faulty. Is this a valid test?
          Here's a photo of the optocoupler in the power board:
          Any help is appreciated!
          Joe
          P.S. - I leave tomorrow after for a week away. So I can't reply quickly.
          • cajoeg
            TV_Newbie
            • Feb 2025
            • 22
            The optocoupler turned out to be fine.
            I took the power board out of an identical working TV, and inserted the one I'm working on. The good TV did verify that it's a faulty power board. I did several measurements, and I can't find any difference as off yet. But, going back to testing the Stand-by voltage, I apparently measured the wrong wire. There is no clearly marked STANDBY pin on the connector. I used the DIM wire which appears to be incorrect, unless it is also used as a STANDBY.
            Here's the pinout for the connector from top to bottom:
            Pin 11: +12V
            Pin 10: +12V
            Pin 9:: GND
            Pin 8: GND
            Pin 7: +5V
            Pin 6: +5V
            Pin 5: +5V
            Pin 4:: GND
            Pin 3: GND
            Pin 2: N/F
            Pin 1: DIM
            I "ASS"ume that N/F is On/Off?
            The three +5V leads all go to a SP10100 Schottky Barrier Rectifier
            The DIM lead goes to pin 4 (DIM) on the OZ99338GN Inverter Controller
            The NF lead goes to pin 10 (ENA) on the OZ99338GN Inverter Controller
            The two +12V leads go to pin 1 on a 8958A MOSFET
            Here's a diagram on the components I mention:
            The connector on the main board is as follows (12 pins, :
            Pin 12: +12V
            Pin 11: +12V
            Pin 10: GND
            Pin 9: GND
            Pin 8: +5V
            Pin 7: +5V
            Pin 6: +5V
            Pin 5: GND
            Pin 4: GND
            Pin 3: N/F
            Pin 2: Not Connected
            Pin 1: DIM​
            So this begs the question. Which pin is the STANDBY? I assume it has to be one of the +5V lines, but which one?
            Joe
            • lotas
              • Jan 2016
              • 4606
              • Russia
              #26
              Schematic
              • cajoeg
                TV_Newbie
                • Feb 2025
                • 22
                Thank you for the great schematic version! Much better, and easier to read. It's also accurate versus the service manual.
                I'm still trying to find the issue. Everything I've tested so far seems to test just fine when using the working power board as a baseline comparison for measurements. But I'm a patient learner, and realize that I will make mistakes as well. I also don't quit. I'll find it somewhere.
                Joe
                • cajoeg
                  TV_Newbie
                  • Feb 2025
                  • 22
                  I took the time to install the good power board into the working TV and take power reads at the Main Board connector. I checked the power when "Plugged In", "Power On", "Mid Read" (if any), and "Resting Read". I then did the same with the bad power board installed. Below are the results. Notice the differences of the following - DIM, ON/OFF, all three +5v, and the two +12v reads (not that bad?). Something is pulling down the +5v, and messing with the DIM as well.
                  In looking at this general logic diagram graphic from a TampaTec YouTube video, after pressing the "Power' button (step 4), the Main Board sends power to the Power Board (step 5). Somewhere during and/or after step 5 is causing the problem.
                  I'm not sure what to look at on the power board next. All of the power going to the main board seems fine before the "Power" button is pressed. After that, it loses its mind.
                  All input is greatly appreciated!
                  Thank you!
                  Joe
                    • 12196
                    • U.S.
                    #29
                    Well if you are not finding any obvious differences in any voltages, redo the solder joints on bottom of board, many times they look good but can suffer from micro cracks.
                      • 12196
                      • U.S.
                      #30
                      The difference seems to be the on off and maybe the dim, can try this, try with good board then bad board. test in usual way, neg probe on ground pos probe on the on/off pin, everything connected, tv in standby/plugged in but off, take note of reading, leave probe where it is turn tv on take note of reading. It looks like there's a problem right there.
                        • 12196
                        • U.S.
                        #31
                        Don't worry about a "mid.read" it's not a factor here.
                        • cajoeg
                          TV_Newbie
                          • Feb 2025
                          • 22
                          Thank you for your reply. I will redo the solder joints as you suggested.
                          As for the testing, what you're recommending is actually exactly what I did to get the aforementioned measurements. I had the negative probe on ground, positive on the respective pin such as DIM or ON/OFF. While plugged in but not on, I took a read. Then I pressed the ON button and took a reading while the TV was trying to come up. I left the positive probe on the respective pin and took it's resting reading. I did not press the ON button again until I changed which pin I was testing.
                          But it's worth testing again to see if I get the same results.
                          And now my stupid question (I'm pretending I haven't asked one already). Below is a photo of two of the board components (I think they are transformers?). Is the discoloration of the two the sign of a problem?
                          Thank you!
                          Joe
                          • cajoeg
                            TV_Newbie
                            • Feb 2025
                            • 22
                            I just repeated the testing. On the bad board, the "plugged in" readings were the same as before, 0 (zero) on both the DIM and ON/OFF pins. But, the resting readings (after pressing the ON button) for the DIM and ON/OFF pins are 0 (zero) on both now. This is a change on the DIM pin as it had a resting read of 1.58v after the first test. I tested each pin individually with the board plugged in, and then pressing the ON button. The +5v pins and +12v had the same results as before.
                            On the good board, nothing has changed as far as readings. Everything works great.
                            Back to the schematics!
                            Thank you!
                            Joe
                              • 12196
                              • U.S.
                              #34
                              I think you refer to standby as "resting" See how the power on voltage changes when you turn tv on with the good board, that's how it should be. The bad board doesn't do that. Most times that I have seen this tho, was because the mainboard wasn't sending the power on signal. But obviously your mainboard is good. I don't know what it could be, maybe the mainboard notices something wrong and doesn't send the on signal to powerboard?? This is an interesting problem, I bet one of these pros can solve it tho.
                              • cajoeg
                                TV_Newbie
                                • Feb 2025
                                • 22
                                Last night I used the schematics to trace pin 4 (DIM) and pin 10 (ON/OFF) on the OZ9923 chip to see if any issues existed. I found no issues (shorts). Today I printed out the datasheet for the OZ9938 chip to learn more about the function of the other pins on the chip. Chip pins 5 and 6 deal with current/voltage sense feedback. It seems (logically only) as if the chip is not getting the feedback from the mainboard on the +5v lines. So I did some tracing of the +5v lines. All three +5v lines go back to the capacitor at C930, one of the Aluminum Organic Polymer Capacitors I have yet to replace. The replacement parts are scheduled to arrive today.
                                Will replacing it solve the problem? I don't know. But if the mainboard is not getting the feedback it expects, it's not going to start up (according to TampaTec). And the aforementioned capacitor has a role in the +5v.
                                During my tracing on the back of the board, I checked numerous things for shorts, and found nothing wrong.
                                We'll see what happens when I replace the Aluminum Organic Polymer Capacitor. I read that testing these type of capacitors is not the same as testing the other capacitors on the board, and that a Capacitance Resistance Inductance Digital LCR Multimeter is recommended.
                                I may be chasing the wrong thing, but I'm learning from the information that I have read, and the testing that I have done.
                                Joe
                                • cajoeg
                                  TV_Newbie
                                  • Feb 2025
                                  • 22
                                  SOLVED!!! My first TV repair!
                                  It was the Aluminum Organic Polymer Capacitor at C930 (680 10v). I replaced it this morning, and the TV came up immediately.
                                  Thank you to everyone for your guidance and help!
                                  Joe
                                    • 12196
                                    • U.S.
                                    #37
                                    Nice job congrats.
                                      • 12196
                                      • U.S.
                                      #38
                                      By the way, you can dirty test those caps the same way as the electrolytic caps.
                                      • cajoeg
                                        TV_Newbie
                                        • Feb 2025
                                        • 22
                                        I thought I did and didn't find anything out of the ordinary. But maybe I didn't?
                                        Thank you!
                                        Joe
                                        • ferah831208
                                          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                          by ferah831208
                                          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                          03-18-2025, 01:18 AM
                                        • ItepK
                                          LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                                          by ItepK
                                          Hello everyone! I've found this television, and I began troubleshooting it.
                                          First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                                          I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                                          After the recapping, all the voltages stableized, however, the issue in the title still remains.
                                          I could...
                                          01-03-2025, 09:01 AM
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
